Drilling and tapping Indy SB intake for bypass hose #1546481
12/11/13 04:48 PM
12/11/13 04:48 PM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
Does anybody know what size hole needs to be drilled into an intake to use a water pump bypass hose? Also, what size threads to tap for the nipple that would go into it? I picked up an Indy 360-3 intake and this area is currently closed off, and I would like to run the bypass hose since this is a street car.
Re: Drilling and tapping Indy SB intake for bypass hose [Re: mshred] #1546482
12/11/13 05:44 PM
12/11/13 05:44 PM
Delray beach, Florida
P
Performance Only Offline
P
I don't have one here in front of me to measure, but I thought the nipple was 1/2" NPT and that would need a 23/32 drill bit
machine shop owner and engine builder
Re: Drilling and tapping Indy SB intake for bypass hose [Re: mshred] #1546483
12/11/13 07:18 PM
12/11/13 07:18 PM
Q
Quicktree Offline
Quicktree  Offline
Q
what kind of water pump are you going to use? would run a meziere and forget all that mess.
Re: Drilling and tapping Indy SB intake for bypass hose [Re: mshred] #1546484
12/11/13 10:09 PM
12/11/13 10:09 PM
North, Alabama
D-50 Offline
D-50  Offline
North, Alabama
I am using the Indy intake also without the bypass hose. I drive mine on the street and it never gets over 170* if that is what you are worried about. I have a thermostat in it with the center knocked out, so the water will circulate when I am cooling between rounds. I am running a Proform electric water pump and a electric fan pushing from the outside of the radiator.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Re: Drilling and tapping Indy SB intake for bypass hose [Re: mshred] #1546485
12/11/13 10:31 PM
12/11/13 10:31 PM
Sask, Can.
72demon416 Offline
72demon416  Offline
Sask, Can.
I had my 360-3 intake drilled for the bypass hose and it required a 3/4 npt tap according to Ryan Johnson.
See our conversation about it:
Ryan, did you remember to modify it to accommodate the bypass hose?
Height wise, yeah it better damn well be about same as your M1 LOL But no spacer required on this...
Forgot about the bypass hose, you're the only person I know who still runs one... looks like I'll be breaking out the 3/4" NPT tap tomorrow. LOL [end quote]
Re: Drilling and tapping Indy SB intake for bypass hose [Re: 72demon416] #1546486
12/11/13 10:41 PM
12/11/13 10:41 PM
Indy
moparman89 Offline
moparman89  Offline
Indy
Its a 3/4 NPT nipple, I just bought one last night.
School of Automotive Machinists Racing
Re: Drilling and tapping Indy SB intake for bypass hose [Re: D-50] #1546487
12/11/13 10:52 PM
12/11/13 10:52 PM
in front of the computer
8
80arrow Offline
80arrow  Offline
Was your intake machined for a thermostat or is your goose neck machined for a thermostat? Sorry to hi-jack your thread.
Re: Drilling and tapping Indy SB intake for bypass hose [Re: D-50] #1546488
12/11/13 10:52 PM
12/11/13 10:52 PM
Mississauga, On.
Duster 371 Offline
Duster 371  Offline
Mississauga, On.
I run an eddy air gap on a 360 with no bypass and a stock rad and water pump...street car, never goes over 180F.
Re: Drilling and tapping Indy SB intake for bypass hose [Re: Duster 371] #1546489
12/11/13 11:34 PM
12/11/13 11:34 PM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
Guys, isn't the reason behind the bypass hose to keep water from the block circulating when using a thermostat to avoid building up pressure?
I would like to still run a thermostat as this is a street car, and from what I have read using a stat far outweighs using a retrictor plate or nothing at all in a street car.
I am also running an edelbrock high flow mechanical water pump.
Unless I am missing something, is there some sort of benefit to not running the bypass hose when using a thermostat?
Re: Drilling and tapping Indy SB intake for bypass hose [Re: 80arrow] #1546490
12/12/13 12:10 AM
12/12/13 12:10 AM
North, Alabama
D-50 Offline
D-50  Offline
North, Alabama
Sorry, I do not remember which one was machined for the thermostat. I got the t-housing from Mancini I think.
Re: Drilling and tapping Indy SB intake for bypass hose [Re: mshred] #1546491
12/12/13 12:39 AM
12/12/13 12:39 AM
MR_P_BODY Offline
MR_P_BODY  Offline
The reason is to keep the heat in the engine to warm
up quicker for the heater and now days for emissions
Re: Drilling and tapping Indy SB intake for bypass hose [Re: MR_P_BODY] #1546492
12/12/13 12:45 AM
12/12/13 12:45 AM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
So if I eliminate the thermostat all together (see some mention running a gutted t-stat) how much longer would it take the car to warm up on average?
Also, if the bypass gets blocked and I leave the t-stat installed but drill some holes in it, will that help the coolant to flow while the stat is still closed? or will holes not flow enough to do that?
I don't want hot spots in the engine, nor do I want to cavitate the pump
Do electric pumps require you to not run a t-stat for these reasons?
Re: Drilling and tapping Indy SB intake for bypass hose [Re: mshred] #1546493
12/12/13 01:01 AM
12/12/13 01:01 AM
Renton Washington
Triple Threat Offline
Renton Washington
Thermostat ..... HA haven't ran one in probably 8 years. Stock pump or electric.
I agree, leave it blocked off, drill some holes in the Thermostat if you wish to circulate water.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: Drilling and tapping Indy SB intake for bypass hose [Re: mshred] #1546494
12/12/13 01:08 AM
12/12/13 01:08 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I run a stat with 6 1/8" holes in it... elec pumps
dont like to be dead heated... I dont run the by
pass on my Rampage but I also plan on a heater
Re: Drilling and tapping Indy SB intake for bypass hose [Re: Triple Threat] #1546495
12/12/13 01:14 AM
12/12/13 01:14 AM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
Did you notice that it takes the car longer to warm up without one? Do you run a restrictor in its place, or nothing at all?
Re: Drilling and tapping Indy SB intake for bypass hose [Re: MR_P_BODY] #1546496
12/12/13 01:15 AM
12/12/13 01:15 AM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
What if I am ditching the heater setup totally? Will the stat with the holes drilled in it suffice, or will the pump still be dead headed technically?
Re: Drilling and tapping Indy SB intake for bypass hose [Re: mshred] #1546497
12/12/13 01:20 AM
12/12/13 01:20 AM
Renton Washington
Renton Washington
Yes it takes longer, this is only an issue if you live as close to the north pole as you do.
I ran nothing.
-Dustin
Re: Drilling and tapping Indy SB intake for bypass hose [Re: mshred] #1546498
12/12/13 01:25 AM
12/12/13 01:25 AM
MR_P_BODY Offline
MR_P_BODY  Offline
the holes are good enough to move some fluid but
still warm the engine fairly quick and not hurt the pump
Re: Drilling and tapping Indy SB intake for bypass hose [Re: Triple Threat] #1546499
12/12/13 08:06 PM
12/12/13 08:06 PM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
I ran nothing.
LOL I'm not much further north then you...your in washington, arent you?
Maybe it's worth trying without anything in there at all?
Re: Drilling and tapping Indy SB intake for bypass hose [Re: MR_P_BODY] #1546500
12/12/13 08:07 PM
12/12/13 08:07 PM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
Have you tried the drilled stat without any heater core? I just worry about creating hot spots in the motor...How much can those holes really flow is what I wonder
