Re: Drilling and tapping Indy SB intake for bypass hose
[Re: mshred]
#1546482
12/11/13 05:44 PM
12/11/13 05:44 PM
Posts: 2,091 Delray beach, Florida
Performance Only
I don't have one here in front of me to measure, but I thought the nipple was 1/2" NPT and that would need a 23/32 drill bit
machine shop owner and engine builder
[Re: mshred]
#1546484
12/11/13 10:09 PM
12/11/13 10:09 PM
Posts: 1,267 North, Alabama
D-50
North, Alabama
Does anybody know what size hole needs to be drilled into an intake to use a water pump bypass hose? Also, what size threads to tap for the nipple that would go into it? I picked up an Indy 360-3 intake and this area is currently closed off, and I would like to run the bypass hose since this is a street car.
I am using the Indy intake also without the bypass hose. I drive mine on the street and it never gets over 170* if that is what you are worried about. I have a thermostat in it with the center knocked out, so the water will circulate when I am cooling between rounds. I am running a Proform electric water pump and a electric fan pushing from the outside of the radiator.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
[Re: mshred]
#1546485
12/11/13 10:31 PM
12/11/13 10:31 PM
Posts: 1,496 Sask, Can.
72demon416
Sask, Can.
I had my 360-3 intake drilled for the bypass hose and it required a 3/4 npt tap according to Ryan Johnson. See our conversation about it:
Ryan, did you remember to modify it to accommodate the bypass hose?
Height wise, yeah it better damn well be about same as your M1 LOL But no spacer required on this...
Forgot about the bypass hose, you're the only person I know who still runs one... looks like I'll be breaking out the 3/4" NPT tap tomorrow. LOL [end quote]
[Re: 72demon416]
#1546486
12/11/13 10:41 PM
12/11/13 10:41 PM
Posts: 171 Indy
moparman89
Indy
Its a 3/4 NPT nipple, I just bought one last night.
School of Automotive Machinists Racing
[Re: 80arrow]
#1546490
12/12/13 12:10 AM
12/12/13 12:10 AM
D-50
North, Alabama
Was your intake machined for a thermostat or is your goose neck machined for a thermostat? Sorry to hi-jack your thread.
Sorry, I do not remember which one was machined for the thermostat. I got the t-housing from Mancini I think.
[Re: mshred]
#1546491
12/12/13 12:39 AM
12/12/13 12:39 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Guys, isn't the reason behind the bypass hose to keep water from the block circulating when using a thermostat to avoid building up pressure?
I would like to still run a thermostat as this is a street car, and from what I have read using a stat far outweighs using a retrictor plate or nothing at all in a street car.
I am also running an edelbrock high flow mechanical water pump.
Unless I am missing something, is there some sort of benefit to not running the bypass hose when using a thermostat?
The reason is to keep the heat in the engine to warm up quicker for the heater and now days for emissions
[Re: MR_P_BODY]
#1546492
12/12/13 12:45 AM
12/12/13 12:45 AM
Posts: 3,415 Toronto
mshred
Toronto
So if I eliminate the thermostat all together (see some mention running a gutted t-stat) how much longer would it take the car to warm up on average?
Also, if the bypass gets blocked and I leave the t-stat installed but drill some holes in it, will that help the coolant to flow while the stat is still closed? or will holes not flow enough to do that?
I don't want hot spots in the engine, nor do I want to cavitate the pump
Do electric pumps require you to not run a t-stat for these reasons?
[Re: mshred]
#1546493
12/12/13 01:01 AM
12/12/13 01:01 AM
Triple Threat
Renton Washington
Thermostat ..... HA haven't ran one in probably 8 years. Stock pump or electric.
I agree, leave it blocked off, drill some holes in the Thermostat if you wish to circulate water.
[Re: mshred]
#1546494
12/12/13 01:08 AM
12/12/13 01:08 AM
MR_P_BODY
So if I eliminate the thermostat all together (see some mention running a gutted t-stat) how much longer would it take the car to warm up on average? Also, if the bypass gets blocked and I leave the t-stat installed but drill some holes in it, will that help the coolant to flow while the stat is still closed? or will holes not flow enough to do that? I don't want hot spots in the engine, nor do I want to cavitate the pump Do electric pumps require you to not run a t-stat for these reasons?
I run a stat with 6 1/8" holes in it... elec pumps dont like to be dead heated... I dont run the by pass on my Rampage but I also plan on a heater
[Re: Triple Threat]
#1546495
12/12/13 01:14 AM
12/12/13 01:14 AM
mshred
Toronto
Did you notice that it takes the car longer to warm up without one? Do you run a restrictor in its place, or nothing at all?
[Re: MR_P_BODY]
#1546496
12/12/13 01:15 AM
12/12/13 01:15 AM
mshred
Toronto
What if I am ditching the heater setup totally? Will the stat with the holes drilled in it suffice, or will the pump still be dead headed technically?
[Re: Triple Threat]
#1546499
12/12/13 08:06 PM
12/12/13 08:06 PM
mshred
Toronto
Yes it takes longer, this is only an issue if you live as close to the north pole as you do.
I ran nothing.
LOL I'm not much further north then you...your in washington, arent you?
Maybe it's worth trying without anything in there at all?
[Re: MR_P_BODY]
#1546500
12/12/13 08:07 PM
12/12/13 08:07 PM
mshred
Toronto
the holes are good enough to move some fluid but still warm the engine fairly quick and not hurt the pump
Have you tried the drilled stat without any heater core? I just worry about creating hot spots in the motor...How much can those holes really flow is what I wonder
