Dodge Ram techs... question #1544523
12/07/13 12:17 AM
12/07/13 12:17 AM
NM
74fish Offline OP
74fish  Offline OP
NM
I have 2003 Hemi Ram. I had a metal on metal sound and no 4 wheel drive, The Half shaft and the Diff spline on my driver side was grinding ( both worn) I'm replacing the driverside front Half shaft .... no problem. The spline which is about 8 inches is connected to the front Diff. I believe it's just supposed to pop out with some force. no need to remove the cover. I welded a chain to the old shaft and have tried leveraging it out. Question ... Is the slide hammer the only way to get that past the C clip ? Do I really have to manhandle that thing out? Thanks in advance.
Re: Dodge Ram techs... question [Re: 74fish] #1544524
12/07/13 12:24 AM
12/07/13 12:24 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
Not messed with one of those yet, but recall that the first gen dakotas had C clips that needed removal to get stubs out of diff.
Re: Dodge Ram techs... question [Re: buildanother] #1544525
12/07/13 12:36 AM
12/07/13 12:36 AM
NM
74fish Offline OP
74fish  Offline OP
NM
I thought that was the case too... but everything I read says slide hammer
Re: Dodge Ram techs... question [Re: 74fish] #1544526
12/07/13 06:58 AM
12/07/13 06:58 AM
CJD AUTOMOTIVE Offline
Yes. They can be a pain to get out. I have never used anything but the collar tool and slide hammer, but it you can get leverage against something ( not sure id be prying against the case) and get a straight pull, it should come out. Even the slide hammer tool isn't magic. It takes some work to get it out.
Craig Scholl
CJD Automotive, LLC
Jacksonville, FL
www.CJDAUTOMOTIVE.com
904-400-1802
"I own a Mopar. I already know it won't be in stock, won't ship tomorrow, and won't fit without modification"
Re: Dodge Ram techs... question [Re: CJD AUTOMOTIVE] #1544527
12/07/13 11:06 AM
12/07/13 11:06 AM
Ohio
Todd Offline
Todd  Offline
Ohio
Chrysler has a special tool for removing them.
Its a sleeve that locks around the end of the shaft and a slide hammer screws on the end. IIRC.
Its a fairly common problem especially with truck that get used a lot off road. The small o-ring brakes and lets junk get in the end of the half shaft.
Re: Dodge Ram techs... question [Re: CJD AUTOMOTIVE] #1544528
12/07/13 01:33 PM
12/07/13 01:33 PM
NM
74fish Offline OP
74fish  Offline OP
NM
Thanks Craig just needed confirmation. I'll be trying again today. I was using a chain but I think I'm getting to much stretch on it. I'm going to weld a bolt on the spline and use a heavy slide hammer.
On that note Todd I think the C clip failed on my truck .. it looks like it popped out and eventually wore out the outer inch of the half shaft and spline. I read one guy welded a bead and joined the 2 (not what I'm planning on doing) but it sounded like a good idea.
Re: Dodge Ram techs... question [Re: 74fish] #1544529
12/07/13 01:57 PM
12/07/13 01:57 PM
Ohio
Todd Offline
Todd  Offline
Ohio
Don't see why that wouldn't work.
I've had the stub shaft come out with the CV when changing the seal.
Re: Dodge Ram techs... question [Re: Todd] #1544530
12/09/13 01:19 AM
12/09/13 01:19 AM
Southeast Pa.
SALEM1912 Offline
SALEM1912  Offline
Southeast Pa.
I've had good luck "popping" the axle out. Found a constant pull doesn't work well. You need to give it a quick jerk.
Re: Dodge Ram techs... question [Re: SALEM1912] #1544531
12/09/13 03:30 AM
12/09/13 03:30 AM
NM
74fish Offline OP
74fish  Offline OP
NM
Got it out. 2 good hits and it popped out. All I needed was a slide puller, I was too cheap so I made one. Here's the pic of my home made tool. I used some 1/2 inch steel stock along with some 3 LB weights and welded them together. Changed the seal and my brake pads while I was at it.
Re: Dodge Ram techs... question [Re: 74fish] #1544532
12/09/13 03:32 AM
12/09/13 03:32 AM
NM
74fish Offline OP
74fish  Offline OP
NM
I had some tubing that I welded to the spline and put a nut on the end.
