318 engine question #1543891
12/04/13 11:04 PM
12/04/13 11:04 PM
Bridgeport, WV
Michael Offline OP
Michael  Offline OP
Bridgeport, WV
On a 1970 318 engine, can the oil pan be turned around on the engine? I want to make it a rear sump. Is there an OEM rear pickup that will screw into my oil pump?
Re: 318 engine question [Re: Michael] #1543892
12/04/13 11:45 PM
12/04/13 11:45 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Your gonna need the rear sump pan and pick up
Re: 318 engine question [Re: MR_P_BODY] #1543893
12/04/13 11:51 PM
12/04/13 11:51 PM
Rudolph, Ohio
moparguy7074 Offline
Rudolph, Ohio
Truck pan?
Re: 318 engine question [Re: moparguy7074] #1543894
12/04/13 11:59 PM
12/04/13 11:59 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Truck pan?
Most truck pans were rear sump
Re: 318 engine question [Re: MR_P_BODY] #1543895
12/05/13 07:27 AM
12/05/13 07:27 AM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
'73 and up truck pans are rear sump, not sure about the earlier ones, I know some were front sump.
Truck pans hold an extra quart too.
Re: 318 engine question [Re: MR_P_BODY] #1543896
12/05/13 08:44 AM
12/05/13 08:44 AM
Tampa
DusterDave Offline
DusterDave  Offline
Tampa
Yep, you want a truck pan.
Gone to the dark side with an LS3 powered '57 Chevy 210
Re: 318 engine question [Re: DusterDave] #1543897
12/05/13 05:13 PM
12/05/13 05:13 PM
Truck and 1971 and later van pans where rear sumps
Re: 318 engine question [Re: Cab_Burge] #1543898
12/05/13 10:28 PM
12/05/13 10:28 PM
Bridgeport, WV
Michael Offline OP
Michael  Offline OP
Bridgeport, WV
I thank everyone for the info, BUT what I'd like to know is if the pan can be turned around and bolted to the block?
Re: 318 engine question [Re: Michael] #1543899
12/05/13 10:34 PM
12/05/13 10:34 PM
On The Boat, On The Lake, Wa. ...
amxautox Offline
Still Retired. Still Posting on Moparts. A Lot.
amxautox  Offline
No, different size front and rear cutouts where the seals are.
And the rear cutout is a different size than the 360.
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
Re: 318 engine question [Re: amxautox] #1543900
12/05/13 10:37 PM
12/05/13 10:37 PM
Morningside
AdventurerSport Offline
waaaay out there in left field
Morningside
Flipping the front sump pan around will not work, you need a rear sump (pickup truck style) pan and pickup. Very common.
Good luck!
JS
76 Dodge Adventurer Sport Power Wagon W100 318, 727, NP203 Fulltime 4x4 Russet Red
06 Jeep Commander Ltd 4x4, 5.7L Hemi, QuadraDrive II
06 Chrysler 300C AWD 5.7L Hemi
10 Mopar 10 Challenger R/T, #483/500, 5.7L HEMI
10 Jeep Grand Cherokee Ltd 4x4 5.7L HEMI
11 Dodge Ram 1500 LoneStar Quad Cab, 5.7L HEMI, Fulltime 4x4, Deep Cherry Red
16 Jeep Cherokee Limited 3.2L Pentastar V6, 9 Speed Torqueflite, 4x4, Black
Re: 318 engine question [Re: Michael] #1543901
12/05/13 11:08 PM
12/05/13 11:08 PM
Yes the one for that rear sump pan. The aftermarket has a bolt on bottom plate with a pickup tube that pretty much drops straight down & you cap the OE pickup hole in the pump with a 3/8 NPT male plug. For your app you'd just need the OE rear sump pickup to go with the OE rear sump pan
