More MP ignition talk #1540251
11/26/13 08:19 PM
11/26/13 08:19 PM
Northern Indiana
Dunnuck Racing Offline OP
Northern Indiana
Well if my information is correct, Mopar Performance is discontinuing their ignition boxes. We are left with installation of a complete new ignition system or one of only a couple of aftermarket replacement plug in ICU boxes.
I have been testing every type of parts store replacement boxes I can get my hands on,and none of them are good for performance. I have tested a couple of boxes that are supposed to be performance replacement ICU's that I wouldn't run in a stock vehicle.
We are left with the Rev N Nator and the new FBO , or old stock.
Just letting you know while you can still get something
Keith
Re: More MP ignition talk [Re: Dunnuck Racing] #1540252
11/26/13 08:39 PM
11/26/13 08:39 PM
Kieth how did they do?
Re: More MP ignition talk [Re: RapidRobert] #1540253
11/26/13 08:58 PM
11/26/13 08:58 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
There are a few guys installing the 4 pin GM HEI ecu in a stock mopar ECU box, $20 bucks for a part store one and I think MSD and accel make some.
Re: More MP ignition talk [Re: ademon] #1540254
11/26/13 09:10 PM
11/26/13 09:10 PM
That's my choice, a speedway motors aftermarket "dynamod" HEI module mounted on a piece of aluminum with Radio Shack heat sink paste hidden (as all chebby parts should be) under the dist. Someone even makes that plate but it's pricey
Re: More MP ignition talk [Re: RapidRobert] #1540255
11/26/13 09:24 PM
11/26/13 09:24 PM
Northern Indiana
Northern Indiana
You have to remember the original HEI was designed back when Mopar ignition systems were designed. They weren't much better . An Accel module is an okay choice but current through it is still limited due to its size.
I have never been a fan of GM HEI because it dropped current at high rpm. Okay for a strock engine but thats about it.
I like and use the Rev N Nator the newest FBO box is a decent performance piece I just dont personally like the looks of it or how the Rev limiter his set.
Keith
Re: More MP ignition talk [Re: Dunnuck Racing] #1540256
11/26/13 09:42 PM
11/26/13 09:42 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
What a surprise
Thanks for letting us know Keith
Re: More MP ignition talk [Re: GTX MATT] #1540257
11/26/13 10:42 PM
11/26/13 10:42 PM
Kieth what would you suggest for my app: Circle track & heat races may be 15 minutes & feature races may be 30 minutes, mostly WOT reaching 6200 at the end of the straights. Some idling (5-10 minutes) in the pits & when setting up. Using a regular 70's electronic dist. Coil would need to be round stock appearing, any ECU & if it looks too outlandish I could hide it or camouflage it.
Re: More MP ignition talk [Re: GTX MATT] #1540258
11/26/13 10:44 PM
11/26/13 10:44 PM
ontario canada kingston
aspenrt360 Offline
aspenrt360  Offline
To bad the are dropping the ecu's. they had one hell of a long run! I am running a chrome box on the street right now it runs good I will pick up a spare chrome and try out either a rev or another fbo I have had the old style fbo before it was ok. don't know about the new stuff though.
2013 Chrysler 300 touring 1974 Dodge Charger SE. 360-727-8.75-3.23 sure grip 1972 Dodge Dart Swinger 1995 Dodge Ram 1500 4x4
Re: More MP ignition talk [Re: aspenrt360] #1540259
11/27/13 12:05 AM
11/27/13 12:05 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
MSD4me
I am truckless..
Re: More MP ignition talk [Re: 340SHORTY] #1540260
11/27/13 08:14 AM
11/27/13 08:14 AM
MICHIGAN
BB65Barracuda Offline
MICHIGAN
The Revonator works great in my hemi car, that being said the MSD in my drag car also works excellent.
If you are doing a track car id go with the MSD.
Easy to install and you can hide it in the car or under the battery box.
Wiring it up is almost as simple as plugging in the stock ECU and you don't need the lousy ballast resister.
1957 Power wagon wm300 original 10.000 mile truck, 1964 dodge Polara Convertible numbers matching
Re: More MP ignition talk [Re: BB65Barracuda] #1540261
11/27/13 12:24 PM
11/27/13 12:24 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
MSD for a performance build, pertronix to replace points .
Re: More MP ignition talk [Re: ademon] #1540262
11/27/13 12:37 PM
11/27/13 12:37 PM
dogdays Offline
dogdays  Offline
And a suitable re-curve for all!
R.
Re: More MP ignition talk [Re: dogdays] #1540263
11/27/13 02:55 PM
11/27/13 02:55 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
what are the EXACT coil requirements for a revanator?
Re: More MP ignition talk [Re: lewtot184] #1540264
11/27/13 08:16 PM
11/27/13 08:16 PM
Northern Indiana
Northern Indiana
There are no EXACT requirements for the coil on the Rev N Nator. But as a disclaimer I'm not the one of the people that designed it. The intent was to make a nice performance replacement that would work with all coils. To the best of my knowledge,the coil that FBO sold with his original system is the only one that doesn't work well with it.
I personally have tested many different coils and even a stock electronic ignition coil worked okay with it. Very high rpm is where coil selection gets a little pickier
I tested a different brand ICU recently that told you you had to use a certain resistance coil and a certain resistance ballast resistor. But you cant find that out until you order the ICU and read the enclosure
Keith
Re: More MP ignition talk [Re: Dunnuck Racing] #1540265
11/27/13 10:38 PM
11/27/13 10:38 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
specifically what are the deficiencies your finding in the ICU's?
Re: More MP ignition talk [Re: lewtot184] #1540266
11/27/13 10:53 PM
11/27/13 10:53 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
And which ones have you tested?
Don't be the exception.
Re: More MP ignition talk [Re: Supercuda] #1540267
11/27/13 11:47 PM
11/27/13 11:47 PM
USA
Rollin Hand Offline
Rollin Hand  Offline
USA
Have you tested it against a magneto?
Re: More MP ignition talk [Re: Supercuda] #1540268
11/28/13 12:51 AM
11/28/13 12:51 AM
Northern Indiana
Northern Indiana
Lets see,,,.....
Wells, Standard, no name parts store stamped " made in China", Old FBO,New FBO, Mopar Orange Chrome, and Gold, HiRev7500, 10 or 12 revisions of Rev N Nator, and a knockoff Orange Box from either ProForm or Jegs
Then test many of them with Accel Super Coil, Accel Super Stock coil, MSD Blaster 2 and 3, MSD HVC coils, Firecore coil,stock coil, generic replacement coil, Mallory Promaster coil, with and without .085 and 1.6 ohm ballast resistors.
Tested against an MSD6, Accel300 digital and Firecore ready to run distributor. Some on high compression and low compression engines.
I have several hundred dyno pulls on file. So its pretty hard to give a general answer on the downfalls
In most cases the ignition either pulled dwell or just did not perform well at peak torque where cylinder pressure is highest.
Keith
Re: More MP ignition talk [Re: Dunnuck Racing] #1540269
11/28/13 02:20 AM
11/28/13 02:20 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
I bought a Rev-N-Nator box last year and ran it a short time. I've had detonation problems that prevented me from being able to take advantage of the dang thing. I'm working on lowering my compression ratio. I'm going to try the Rev box once my car is back together.
Re: More MP ignition talk [Re: Kern Dog] #1540270
11/28/13 10:32 AM
11/28/13 10:32 AM
SD
Z
zrxkawboy Offline
zrxkawboy  Offline
Z
SD
I'm curious if anyone has tried the Jeg's boxes. They have an "orange" one and a "chrome" one. The "chrome" one says Made in USA.
http://www.jegs.com/i/JEGS-Performance-P...759#moreDetails
It's Swifty! Swifty, you toad sucker!
