Re: More MP ignition talk
[Re: GTX MATT]
#1540257
11/26/13 10:42 PM
11/26/13 10:42 PM
RapidRobert
Kieth what would you suggest for my app: Circle track & heat races may be 15 minutes & feature races may be 30 minutes, mostly WOT reaching 6200 at the end of the straights. Some idling (5-10 minutes) in the pits & when setting up. Using a regular 70's electronic dist. Coil would need to be round stock appearing, any ECU & if it looks too outlandish I could hide it or camouflage it.
[Re: GTX MATT]
#1540258
11/26/13 10:44 PM
11/26/13 10:44 PM
Posts: 855 ontario canada kingston
aspenrt360
To bad the are dropping the ecu's. they had one hell of a long run! I am running a chrome box on the street right now it runs good I will pick up a spare chrome and try out either a rev or another fbo I have had the old style fbo before it was ok. don't know about the new stuff though.
2013 Chrysler 300 touring 1974 Dodge Charger SE. 360-727-8.75-3.23 sure grip 1972 Dodge Dart Swinger 1995 Dodge Ram 1500 4x4
[Re: 340SHORTY]
#1540260
11/27/13 08:14 AM
11/27/13 08:14 AM
Posts: 926 MICHIGAN
BB65Barracuda
MICHIGAN
The Revonator works great in my hemi car, that being said the MSD in my drag car also works excellent. If you are doing a track car id go with the MSD. Easy to install and you can hide it in the car or under the battery box. Wiring it up is almost as simple as plugging in the stock ECU and you don't need the lousy ballast resister.
1957 Power wagon wm300 original 10.000 mile truck, 1964 dodge Polara Convertible numbers matching
[Re: lewtot184]
#1540266
11/27/13 10:53 PM
11/27/13 10:53 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
And which ones have you tested?
[Re: Supercuda]
#1540268
11/28/13 12:51 AM
11/28/13 12:51 AM
Posts: 3,300 Northern Indiana
Dunnuck Racing
Northern Indiana
Lets see,,,..... Wells, Standard, no name parts store stamped " made in China", Old FBO,New FBO, Mopar Orange Chrome, and Gold, HiRev7500, 10 or 12 revisions of Rev N Nator, and a knockoff Orange Box from either ProForm or Jegs Then test many of them with Accel Super Coil, Accel Super Stock coil, MSD Blaster 2 and 3, MSD HVC coils, Firecore coil,stock coil, generic replacement coil, Mallory Promaster coil, with and without .085 and 1.6 ohm ballast resistors. Tested against an MSD6, Accel300 digital and Firecore ready to run distributor. Some on high compression and low compression engines. I have several hundred dyno pulls on file. So its pretty hard to give a general answer on the downfalls In most cases the ignition either pulled dwell or just did not perform well at peak torque where cylinder pressure is highest. Keith
