Re: why would a stock street hemi have only 5in vacuum ?
[Re: Teamx]
#1533369
12/01/13 03:03 AM
12/01/13 03:03 AM
Posts: 43,195 Bend,OR USA
Cab_Burge
It depends on what you are trying to acheive, The OP stated this is a resto car so ET at the track may not be his main consideration. A cam with around 220>225 @ .050 on 110>112 lobe seperation installed 2 to 4 degrees advanced will give a nice stong vaccum signal to the carbs enhancing tuning and also make plenty of vaccum to operate the power brakes.Oh and it wont burn your eyes out as much as a tight lobe cam!
I've never seen Eyeballs damaged by camshaft lobe centers, ever Rich mixtures are another subject entirely Carbs. may need modifying, tuning, when you change any of the stock parts to non stock parts, just like adding headers usually requires leaning down the carbs on all the pertinent circiuts, idle, transistion, main and sometimes the secondary jetting also That is if you want the best results from your changes You can lean the idle circuits down two diffeent ways, restrict the idle fuel feed or open up the idle bleeds to reduce the vacume signal too the idle circuits, sometimes doing both is the best answer
[Re: ogopogo]
#1533371
12/01/13 01:11 PM
12/01/13 01:11 PM
Posts: 9,841 MI, usa
dvw
MI, usa
I dont think this trailer queen will ever see over 4000 rpm anyway unless the next owner actually drives it.I can use the comp 292 in the engine Im building for my challenger (4 speed car w 4:10's)
My point exactly
[Re: dvw]
#1533372
12/02/13 05:33 PM
12/02/13 05:33 PM
Posts: 1,794 BC Canada
ogopogo
BC Canada
A quick update,I just broke in the new cam and the car is running fantastic,its a whole different car now.Idles nice with a slight lope and its making 12in vacuum at idle. I did install the cam 4 deg advanced(at 103), and the moral of the story is dont install a comp 292 cam,4 degrees retarded,in your bone stock,auto trans,3:23 geared hemi car! Thanks to everyone who helped me out!
[Re: ogopogo]
#1533374
12/02/13 05:51 PM
12/02/13 05:51 PM
Posts: 3,103 Phila Pa
scatpacktom
Phila Pa
AND THAT FOLKS IS HOW HEMI'S BECOME DUDS
[Re: RUNCHARGER]
#1533376
12/03/13 12:14 AM
12/03/13 12:14 AM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
Great news!
[Re: Cab_Burge]
#1533377
12/03/13 12:21 AM
12/03/13 12:21 AM
Posts: 4,501 Gainesville,FL
goldmember
Gainesville,FL
Isn't it amazing the differences a small change like that can make How bad do the rear tires spin now
It's far from a SMALL change but NOT unexpected.
[Re: ogopogo]
#1533378
12/03/13 12:38 AM
12/03/13 12:38 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I'm sure the cam timing was suggested to check... but was it degreed when you installed the cam(I dont recall) or was it the timing pointer was moved... which shouldnt have changed the cam timing but would have on spark timing.... anyways.... glad you found your lost power and vac
[Re: MR_P_BODY]
#1533379
12/03/13 09:34 PM
12/03/13 09:34 PM
ogopogo
BC Canada
Cmon Cab,this is an all #s matching low mile restored 71 hemi car,it is much too rare valuable etc etc to be spinning the tires.it is for static display use only !! . . . . . . . . . . . . . .. . . . . . . . . . Seriously though,it spins 'em real good now !
[Re: ogopogo]
#1533381
12/03/13 09:47 PM
12/03/13 09:47 PM
Posts: 8,273 fredericksburg,va
cudaman1969
fredericksburg,va
Cmon Cab,this is an all #s matching low mile restored 71 hemi car,it is much too rare valuable etc etc to be spinning the tires.it is for static display use only !! . . .Snow tires??? . . . . . . . . . . .. . . . . . . . . . Seriously though,it spins 'em real good now !
[Re: ogopogo]
#1533384
12/06/13 11:51 AM
12/06/13 11:51 AM
cudaman1969
fredericksburg,va
Ha ha,dont need the snow tires yet but it is getting chilly here now! these motors LOVE cold air!
Chilly??? Looks like snow on the ground now lol.
[Re: ogopogo]
#1533385
12/06/13 12:22 PM
12/06/13 12:22 PM
Posts: 595 Nashville, Tennessee
Tempest
Please tell me you washed all that salt off after the drive??? You can see it on the road.
