Re: why would a stock street hemi have only 5in vacuum ?
[Re: ogopogo]
#1533348
11/18/13 12:39 AM
11/18/13 12:39 AM
Posts: 2,537 PORT ALBERNI , BC., CANADA
superwrench
Just to give you a comparison of sorts.....I have a Racer Brown SSH-44 for a Hemi sitting on my shop shelf. It's a hydraulic 292* .510 lift cam that Direct Connection had 30 years ago. The reason it's on the shelf is for the very reason's you have pointed out in your post.....NO vacuum, pig rich running at idle and low speed, and all the other associated woes that a cam like that creates. My hemi car doesn't have Power brakes,but the 6" of vacuum that I had wouldn't have run them anyways. My is you need a cam down in the 276*-280* maximum (Not at .050 either) That cam made the car haul like hell up top, but you couldn't poke around town with it and enjoy the car. Just the stock solid in the car now, and that's what's staying in it.
[Re: ogopogo]
#1533358
11/28/13 12:16 PM
11/28/13 12:16 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I did some online research before buying this cam and two moparts members have it in stock resto cars and are happy with it,I thought it speced out fairly mild?
Sooo,Cab says I should install it at 102 and cudaman is saying 112? Im getting confused here ! My local engine guy as well as BGR are saying 108 is good!
NO NO... they are talking 2 different things... Cab is saying to INSTALL at 102.. Cuda is talking LSA (lobe separation angle).... from your initial post you said you moved the timing pointer.... if thats the case your timing would be based on the od pointer... when installing a cam you set TDC on the piston then slide the cover on to verify the zero... so if you moved the pointer you changed a lot of factors.... back to the cam numbers... like Cab said I would INSTALL it at 102 or so for the lower end torque A cam that is installed retarded(as in 109 or higher) will have low vac
[Re: ogopogo]
#1533360
11/28/13 01:25 PM
11/28/13 01:25 PM
Posts: 8,299 fredericksburg,va
cudaman1969
fredericksburg,va
Just looked at some cams and Crane has a 660091 cam,284-294 with 112 lobe separation - 1500-5200 rpm great idle. This is what I'm saying, a good street cam that will give you the vacuum you need for stock carbs.
[Re: cudaman1969]
#1533362
11/28/13 02:55 PM
11/28/13 02:55 PM
Posts: 43,233 Bend,OR USA
Cab_Burge
Hemiroid motors don't like wide lobe seperation angles like above 110, even a street blower motor Same thing on close lobe centers(closer than 106), them dang hemirod motors are a pain to get right
[Re: Cab_Burge]
#1533363
11/28/13 03:39 PM
11/28/13 03:39 PM
Posts: 9,861 MI, usa
dvw
MI, usa
I built a Hemi for my buddy's 69 Road Runner. A friend recommended a cam with a 114 LCA. The car Idles like a 318. Has great low end and pulls to 6000. All stock (still has the original exhaust from 69) 13.00@107. I would have never chosen this cam but he swore it would work. He was correct. Doug
