CNC porting #1529214
11/05/13 09:46 PM
11/05/13 09:46 PM
Wisconsin
T-Fish Offline OP
T-Fish  Offline OP
Wisconsin
Who do you guys trust to do CNC porting on your cylinder heads?
Re: CNC porting [Re: T-Fish] #1529215
11/05/13 10:30 PM
11/05/13 10:30 PM
Az
Crizila Offline
Crizila  Offline
Az
I just trusted Hughes.
Fastest 300
Re: CNC porting [Re: Crizila] #1529216
11/05/13 10:35 PM
11/05/13 10:35 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
the one the only BRETT MILLER
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: CNC porting [Re: T-Fish] #1529217
11/05/13 11:10 PM
11/05/13 11:10 PM
Cab_Burge Online work
Cab_Burge  Online Work
I've had Modern Cylinder Heads,586-468-7914, do three different types of BB Mopar heads,Eddy RPM, B1-BS and two sets of 440-1 They all made great power on the dyno and went fast at the track, faster than some others on here I believe
Re: CNC porting [Re: T-Fish] #1529218
11/06/13 12:21 AM
11/06/13 12:21 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
FWIW, who I trust to work on my heads has nothing to do with whether they CNC port them or not.
What type of heads are you talking about?
Re: CNC porting [Re: BradH] #1529219
11/06/13 02:30 AM
11/06/13 02:30 AM
Wisconsin
T-Fish Offline OP
T-Fish  Offline OP
Wisconsin
Eddy Victors.
Re: CNC porting [Re: T-Fish] #1529220
11/06/13 02:43 AM
11/06/13 02:43 AM
Cincinnati, Ohio
d7cook Offline
d7cook  Offline
Cincinnati, Ohio
Here's Moderns.
1967 Coronet, 1989 Daytona tube chassis. Former cars, 66 Charger, 67 R/T, 69 Coronet, 67 Dart GT. -Banned for life from V8Buick.com-
Re: CNC porting [Re: d7cook] #1529221
11/06/13 10:14 AM
11/06/13 10:14 AM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
Why is the port divider wall so narrow?
Do you have a measurement you can share on the width of that?
Re: CNC porting [Re: roadhazard] #1529222
11/06/13 11:12 AM
11/06/13 11:12 AM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
And what head is that with no pushrod bulge?
Nice!
Joe
Re: CNC porting [Re: jlatessa] #1529223
11/06/13 11:28 AM
11/06/13 11:28 AM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
Nice!
Joe
Edelbrock Victor or Victor copy
Re: CNC porting [Re: T-Fish] #1529224
11/06/13 11:30 AM
11/06/13 11:30 AM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Modern here for both wedge and Hemi.
Master, again and still
Re: CNC porting [Re: T-Fish] #1529225
11/06/13 12:28 PM
11/06/13 12:28 PM
BradH Offline
BradH  Offline
Eddy Victors.
Standard-size port or Max Wedge?
Re: CNC porting [Re: roadhazard] #1529226
11/06/13 12:29 PM
11/06/13 12:29 PM
BradH Offline
BradH  Offline
I wondered the same thing... looks too narrow IMO for adequate gasket sealing surface.
EDIT: Yeah, I know WHY it's narrow, but still was concerned about sealing issues.
Re: CNC porting [Re: roadhazard] #1529227
11/06/13 12:45 PM
11/06/13 12:45 PM
Cincinnati, Ohio
d7cook Offline
d7cook  Offline
Cincinnati, Ohio
I don't mean to sound like a smart a$$ but to make the port bigger. Only so much space to work with. They started out life as standard port Victors.
Yes it is thin but I've ran them this thin on other heads without a problem. You have to be careful cutting out gaskets but I've never had a problem with the gasket blowing out. I'll measure the width tonight.
https://board.moparts.org/ubbthreads/showflat.php?Number=7185404
Re: CNC porting [Re: d7cook] #1529228
11/06/13 04:05 PM
11/06/13 04:05 PM
N of Detroit
DaveDudek Offline
DaveDudek  Offline
N of Detroit
Dave Dudek
1st Factory Stock legal car in the 10`s!!! [/b]
FAST & Factory Stock Rules: www.fastraces.org
FAST 69 Hemi RR 9.98@139
Re: CNC porting [Re: DaveDudek] #1529229
11/06/13 04:59 PM
11/06/13 04:59 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
I though the same thing,thin divider wall.Not only do you have to be carefull with the gasket fit but manifold match also.Keeping that alignment you may find it nescessary to add alignment dowels to the head and manifold to make sure it it returned to that precise position when it is removed and replaced.Why not start with heads that are cast for large ports to begin with?
Re: CNC porting [Re: BradH] #1529230
11/06/13 08:11 PM
11/06/13 08:11 PM
Wisconsin
T-Fish Offline OP
T-Fish  Offline OP
Wisconsin
Eddy Victors.
They are the standard ports. One of the ports has been opened up to Max Wedge size so the rest will need to be done.
Re: CNC porting [Re: B G Racing] #1529231
11/07/13 01:55 AM
11/07/13 01:55 AM
Cincinnati, Ohio
d7cook Offline
d7cook  Offline
Cincinnati, Ohio
2.725x1.44 port size. 1.1 divider. Yes it's thin but I've had them that thin before without a problem. You are correct in that I use a dowel. I always drill a dowel when I port match and intake to a set of heads. I have two intake set ups right now. One is a 400-2 with spacers and I counter sunk the inner two bolt holes and use flat head screws which locates it. I drilled and tapped two additional bolts inboard to bolt the intake to the spacers. Other wise you can't get the long bolts to work with the port wrapping around the inner two bolt holes. The other intake is a super victor that I haven't port matched yet.
As far as which ports to start with Modern asked that the std port heads be provided even though they were gong to MW. I assume its easier to take a thicker cut off the aluminum.
Re: CNC porting [Re: d7cook] #1529232
11/07/13 08:54 AM
11/07/13 08:54 AM
The Great White North
RAMM Offline
RAMM  Offline
I don't see how that is possible considering the Eddy's are two seperate castings with the pushrod hole machined in a different position. This is probably why your center divider is thin-because they are std. port Victors. J.Rob
2009 PHR\EMC Competitor
2010 PHR\EMC Competitor
2011 PHR\EMC Competitor
2012 PHR\EMC Competitor
2013 PHR\EMC Competitor
2014 HotRod/EMC Competitor
2015 HotRod/EMC NoShow
2016 HotRod/EMC 3rd place SPEC Bigblock
2018 HotRod/EMC 7th place G3
Re: CNC porting [Re: T-Fish] #1529233
11/07/13 11:20 AM
11/07/13 11:20 AM
BradH Offline
BradH  Offline
Eddy Victors.
Combination details? I'm asking because I did some research into what CNC offerings are out there for Victors (not many) and what I did find was predominantly for MW-sized ports anyway.
Some seemed focused more on big high-lift #s (e.g. Speier Racing Heads), whereas the Hughes program seems more oriented to more moderate lift requirements.
