Re: CNC porting
[Re: T-Fish]
#1529224
11/06/13 11:30 AM
11/06/13 11:30 AM
Posts: 12,085 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Modern here for both wedge and Hemi.
Master, again and still
Re: CNC porting
[Re: roadhazard]
#1529227
11/06/13 12:45 PM
11/06/13 12:45 PM
Posts: 290 Cincinnati, Ohio
d7cook
Cincinnati, Ohio
Why is the port divider wall so narrow? Do you have a measurement you can share on the width of that?
I don't mean to sound like a smart a$$ but to make the port bigger. Only so much space to work with. They started out life as standard port Victors.
Yes it is thin but I've ran them this thin on other heads without a problem. You have to be careful cutting out gaskets but I've never had a problem with the gasket blowing out. I'll measure the width tonight.
https://board.moparts.org/ubbthreads/showflat.php?Number=7185404
1967 Coronet, 1989 Daytona tube chassis.
Former cars, 66 Charger, 67 R/T, 69 Coronet, 67 Dart GT.
-Banned for life from V8Buick.com-
Re: CNC porting
[Re: BradH]
#1529230
11/06/13 08:11 PM
11/06/13 08:11 PM
Posts: 203 Wisconsin
T-Fish
Wisconsin
Eddy Victors.
Standard-size port or Max Wedge?
They are the standard ports. One of the ports has been opened up to Max Wedge size so the rest will need to be done.
Re: CNC porting
[Re: d7cook]
#1529232
11/07/13 08:54 AM
11/07/13 08:54 AM
Posts: 1,051 The Great White North
RAMM
I don't see how that is possible considering the Eddy's are two seperate castings with the pushrod hole machined in a different position. This is probably why your center divider is thin-because they are std. port Victors. J.Rob
2009 PHR\EMC Competitor 2010 PHR\EMC Competitor 2011 PHR\EMC Competitor 2012 PHR\EMC Competitor 2013 PHR\EMC Competitor 2014 HotRod/EMC Competitor 2015 HotRod/EMC NoShow 2016 HotRod/EMC 3rd place SPEC Bigblock 2018 HotRod/EMC 7th place G3
