Aftermarket intake under 70 Ramcharger hood? #1525571
10/29/13 05:59 PM
10/29/13 05:59 PM
Near Indy
slowpoke Offline OP
slowpoke  Offline OP
Near Indy
70 Superbee with the ramcharger hood and a warmed over 440. Would like to keep as much performance as possible along with the fresh air box for wow factor. Can anyone tell me if there are any aftermarket intakes that will work well and fit under it or am I stuck with the factory iron? Thanks in advance!
Re: Aftermarket intake under 70 Ramcharger hood? [Re: slowpoke] #1525572
10/29/13 07:08 PM
10/29/13 07:08 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
yeah... a six pack! ok ok, many intakes fit. CH4B looks almost stock and performs well with mild 440 applications. I think a Holley SD will also fit.
Coming soon!!!!
Re: Aftermarket intake under 70 Ramcharger hood? [Re: slowpoke] #1525573
10/29/13 09:44 PM
10/29/13 09:44 PM
KS.
HairOtheDog Offline
HairOtheDog  Offline
KS.
I think MOST, any dual plane should work,
I think some single planes could be problematic...
Re: Aftermarket intake under 70 Ramcharger hood? [Re: HairOtheDog] #1525574
11/03/13 10:02 AM
11/03/13 10:02 AM
Near Indy
slowpoke Offline OP
slowpoke  Offline OP
Near Indy
Been without a computer for a while so just now following up...
I've used the street dominator in the past and would like to use it on this car, but would like to know if it will work. Anyone actually using it for this type car/hood setup or does anyone have a height measurement vs. stock by chance?
Thanks again for your help!!
Re: Aftermarket intake under 70 Ramcharger hood? [Re: slowpoke] #1525575
11/03/13 12:27 PM
11/03/13 12:27 PM
KS.
HairOtheDog Offline
HairOtheDog  Offline
KS.
I've actually used the holley STreet dominator on several applications, dual plane (I REALLY like that intake btw), and its dropped right on, in the original stock location with only a SLIGHT increase in height.
I THINK it should work for your needs
Re: Aftermarket intake under 70 Ramcharger hood? [Re: slowpoke] #1525576
11/03/13 12:29 PM
11/03/13 12:29 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
SD is 1" taller than stock.
Re: Aftermarket intake under 70 Ramcharger hood? [Re: HairOtheDog] #1525577
11/03/13 02:18 PM
11/03/13 02:18 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
You can always use a drop base if you have clearance issues.
Re: Aftermarket intake under 70 Ramcharger hood? [Re: Mr.Yuck] #1525578
11/03/13 09:31 PM
11/03/13 09:31 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Here is a list of intakes I know of that will clear the air box AND the hood on a 440 installed in a 70 B body ...
Stock Iron intake
ORIGINAL and DISCONTINUED M1 Dual plane ... current M1 Dual plane is a rebadged Ebrock RPM
Original style 6 pk intake
POSSIBLY the Ebrock performer 400 , NOT the RPM
and I'm sure there is an old offy with not much better than stock performance they MAY fit ...
ANYTHING else is going to require the air cleaner base to be modified .... A CH4B will have the air cleaner top hit the hood ...
Re: Aftermarket intake under 70 Ramcharger hood? [Re: JohnRR] #1525579
11/06/13 06:50 PM
11/06/13 06:50 PM
Near Indy
slowpoke Offline OP
slowpoke  Offline OP
Near Indy
Would love to be able to use the Street Dominator with the Ramcharger air cleaner setup, but I'm doubting there's an extra inch of clearance in the stock setup. Will research further...Thanks for the responses everyone,that helps a lot!
Re: Aftermarket intake under 70 Ramcharger hood? [Re: slowpoke] #1525580
11/07/13 12:12 AM
11/07/13 12:12 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
You can use it but you'll have to turn it into a drop base, Contact Steve /Paint_it_black , he makes the base out of fiberglass
Re: Aftermarket intake under 70 Ramcharger hood? [Re: slowpoke] #1525581
11/07/13 01:12 AM
11/07/13 01:12 AM
KS.
HairOtheDog Offline
HairOtheDog  Offline
KS.
I mentioned this on another thread just now, BUT-
There's one on EBag right now, (not mine)
$60 starting bid, I think 1 person has bid on it
Re: Aftermarket intake under 70 Ramcharger hood? [Re: JohnRR] #1525582
11/07/13 05:51 PM
11/07/13 05:51 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
Stock Iron intake
As I was reading and scrolling down, I'm thinking; John knows so hopefully he'll chime in.
Wow factor, performance and ability to use a Ramcharger air box all point to the 6 pack manifold....
the M 1 is your best choice for a 4bbl, and the offy sucks (or doesn't...you know what I mean!)
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: Aftermarket intake under 70 Ramcharger hood? [Re: JohnRR] #1525583
11/07/13 06:39 PM
11/07/13 06:39 PM
Near Indy
slowpoke Offline OP
slowpoke  Offline OP
Near Indy
Thanks for the info!
