Re: Aftermarket intake under 70 Ramcharger hood?
[Re: slowpoke]
#1525573
10/29/13 09:44 PM
10/29/13 09:44 PM
Posts: 88 KS.
HairOtheDog
KS.
I think MOST, any dual plane should work, I think some single planes could be problematic...
[Re: slowpoke]
#1525576
11/03/13 12:29 PM
11/03/13 12:29 PM
Posts: 4,324 Prospect, PA
BSB67
Prospect, PA
Been without a computer for a while so just now following up... I've used the street dominator in the past and would like to use it on this car, but would like to know if it will work. Anyone actually using it for this type car/hood setup or does anyone have a height measurement vs. stock by chance? Thanks again for your help!!
SD is 1" taller than stock.
[Re: Mr.Yuck]
#1525578
11/03/13 09:31 PM
11/03/13 09:31 PM
Posts: 75,126 A Banana Republic near you.
JohnRR
You can always use a drop base if you have clearance issues.
Here is a list of intakes I know of that will clear the air box AND the hood on a 440 installed in a 70 B body ...
Stock Iron intake
ORIGINAL and DISCONTINUED M1 Dual plane ... current M1 Dual plane is a rebadged Ebrock RPM
Original style 6 pk intake
POSSIBLY the Ebrock performer 400 , NOT the RPM
and I'm sure there is an old offy with not much better than stock performance they MAY fit ...
ANYTHING else is going to require the air cleaner base to be modified .... A CH4B will have the air cleaner top hit the hood ...
[Re: slowpoke]
#1525580
11/07/13 12:12 AM
11/07/13 12:12 AM
JohnRR
Would love to be able to use the Street Dominator with the Ramcharger air cleaner setup, but I'm doubting there's an extra inch of clearance in the stock setup. Will research further...Thanks for the responses everyone,that helps a lot!
You can use it but you'll have to turn it into a drop base, Contact Steve /Paint_it_black , he makes the base out of fiberglass
