Re: Disk Brakes on C-body
[Re: 72d100]
#1516080
10/23/13 01:48 PM
10/23/13 01:48 PM
Posts: 28,078 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
Yes but not quite that thick.
You can also use a drum brake hub.
Be aware that if you use a multi-piston caliper you will need to make sure the spokes on your wheels do not hit the caliper. Oz had to arrange custom wheels for the hot rod.
If you're sticking with a sliding caliper the caliper clearance is far less critical.
[Re: Den300]
#1516082
11/08/13 08:47 AM
11/08/13 08:47 AM
Posts: 2,935 Finalnd, Perkele
jyrki
Finalnd, Perkele
Have forgotten the whole thing everytime there is someone in the garage with a working digicamera..., but eventually....
Plynouth VIP '67 TT IC EFI
[Re: jyrki]
#1516083
11/09/13 08:25 AM
11/09/13 08:25 AM
Posts: 214 Hamburg / Germany
Den300
Hamburg / Germany
Are you rebuilding the VIP?
Hamburg/Germany
69 Chrysler 300 446cui Dual Quad 12.64 @ 110.7
[Re: Den300]
#1516084
11/10/13 01:36 AM
11/10/13 01:36 AM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
Why not use ford explorer brakes, dual piston calipers, 5x4.5 rotors with the right register and a simple bracket to mount them on the drum spindle. Vhalla done. Or you can look at the crown vic rotors, same deal 12.02 diameter, 2.85 center hole, dual piston calipers, and a simple bracket. Vhalla! Done
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
[Re: Den300]
#1516086
11/15/13 06:02 PM
11/15/13 06:02 PM
jyrki
Finalnd, Perkele
just a repaint and a vinyl roof! And going through the drivetrain. Anyway, I finally go some pics of the B-body wilwoods installed on C-body drum brakes They don't tell much I guess, the adpters between the caliber adapter and the spindle is two 3mm aluminum plates, so 6 mm together. Don't remeber wether I reversed the caliber attchment or not, but maybe someone with B-body assembly can tell? Anyway, the installation was pretty stright forward once I figured it out, the biggest task was making the "shims" with basic hand tools.
[Re: 73EStroker]
#1516090
12/24/13 08:15 AM
12/24/13 08:15 AM
Den300
Hamburg / Germany
@73EStroker: I do know Cass as I already ordered some from him for my 65 Dodge Coronet ![](/ubbthreads/images/graemlins/wink.gif) But I am sure I read somewhere that somebody asked him not long ago and at the moment he offers nothing for C-Bodies. Apart from that he really has great solutions for brakes! ![](/ubbthreads/images/graemlins/thumbs.gif)
Hamburg/Germany
[Re: Den300]
#1516091
01/03/14 01:46 PM
01/03/14 01:46 PM
Posts: 401 Berlin, Germany
Flo
Berlin, Germany
Also had talked to Cass, but no C-body stuff. Thanks regardless Flo
1967 Fury III 4door HT
tiny 318, late model roller block, bored and stroked to 344
[Re: AndyF]
#1516092
01/10/14 06:29 PM
01/10/14 06:29 PM
Posts: 26 Cleveland, OH
fury413rb
Cleveland, OH
I used to make a 13 inch kit for C-body cars. I stopped building the kit since it was really slow seller, but it shouldn't be too hard to duplicate if you want some good brakes.
What was the application/part number on those brake rotors?
