3 Questions Regarding Bench Seat Tracks #1515695
10/12/13 12:03 AM
10/12/13 12:03 AM
Delta BC, Canada
Baller Offline OP
Baller  Offline OP
Delta BC, Canada
I purchased a bench seat for my '70 GTX and had three questions:
1)Is there supposed to be a steel cable that connects this adjuster to the one on the drivers side (labelled A in the photo)?
2)Does anyone know where I can get another of these springs? I assume the drivers side track should have one as well (labelled B).
3)Before I start pounding happily away, is there a proper way to remove these studs as one is broken (second photo)?
[image][/image]
[image][/image]
1970 GTX, work in progress...
Re: 3 Questions Regarding Bench Seat Tracks [Re: Baller] #1515696
10/12/13 01:48 PM
10/12/13 01:48 PM
Southeast Virginia
68jim Offline
68jim  Offline
Southeast Virginia
Yes, there should be a solid steel wire that connects the two. Mine is a 68 RR so I would assume it should be pretty close to your 70. The wire does not go straight across but up to a J hook in the frame - see pictures - I don't think they would be available as a repop, so unless you can find one used I would suggest to use some wire that they use for hanging heavy picture frames. My studs were good so not much help with that. I would think they are just pressed in. I would replace with a good grade bolt and have someone with a welder tack the bolt to the frame.
Re: 3 Questions Regarding Bench Seat Tracks [Re: 68jim] #1515697
10/12/13 01:49 PM
10/12/13 01:49 PM
Southeast Virginia
68jim Offline
68jim  Offline
Southeast Virginia
#2
Re: 3 Questions Regarding Bench Seat Tracks [Re: 68jim] #1515698
10/12/13 01:51 PM
10/12/13 01:51 PM
Southeast Virginia
68jim Offline
68jim  Offline
Southeast Virginia
#3
Re: 3 Questions Regarding Bench Seat Tracks [Re: 68jim] #1515699
10/12/13 01:53 PM
10/12/13 01:53 PM
Southeast Virginia
68jim Offline
68jim  Offline
Southeast Virginia
# last
Re: 3 Questions Regarding Bench Seat Tracks [Re: Baller] #1515700
10/12/13 06:12 PM
10/12/13 06:12 PM
cbusters Offline
cbusters  Offline
Stud can be cut off flush on the thread side and then a hammer should knock the head off. Replace it with a Carriage Bolt. A quick visual reproduction would to chuck it in a drill and spin the head against a bench grinder to turn it into a stud. Weld it at the square part of the shank.
Re: 3 Questions Regarding Bench Seat Tracks [Re: cbusters] #1515701
10/12/13 06:19 PM
10/12/13 06:19 PM
Delta BC, Canada
Baller Offline OP
Baller  Offline OP
Delta BC, Canada
Thanks Guys. I think I'll use some lightweight steel cable to connect both sides. I see that I am also missing the rubber(?) isolators that fit between the stud and floor. And your picture Jim confirms that I'm missing the one spring as I suspected. Any thoughts where to get the isolators (mind you I haven't looked yet)?
Re: 3 Questions Regarding Bench Seat Tracks [Re: Baller] #1515702
10/12/13 06:25 PM
10/12/13 06:25 PM
Delta BC, Canada
Baller Offline OP
Baller  Offline OP
Delta BC, Canada
Dante's has the spacers ($4 each-fair price) and Ebay has the spring $36
