I purchased a bench seat for my '70 GTX and had three questions:
1)Is there supposed to be a steel cable that connects this adjuster to the one on the drivers side (labelled A in the photo)?
2)Does anyone know where I can get another of these springs? I assume the drivers side track should have one as well (labelled B).
3)Before I start pounding happily away, is there a proper way to remove these studs as one is broken (second photo)?
[image][/image]
[image][/image]
1970 GTX, work in progress...
