This did not work #1510074
09/30/13 05:18 PM
09/30/13 05:18 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
and made a bunch of reversion.I cut it off like before I made it and will make something over the winter. lesson learned.
Re: This did not work [Re: Clanton] #1510075
09/30/13 05:25 PM
09/30/13 05:25 PM
Guitar Jones Offline
Better get some tethers on there.
Re: This did not work [Re: Clanton] #1510076
09/30/13 05:32 PM
09/30/13 05:32 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Get some zoomies and exhaust it out the hood.
I would get different headers, what are they built for?
Re: This did not work [Re: Challenger 1] #1510077
09/30/13 05:38 PM
09/30/13 05:38 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I made them and the turnout was a after thaught.I was thinking of making the zoomies from where the collector is on insted of the collector.
Re: This did not work [Re: Challenger 1] #1510078
09/30/13 05:42 PM
09/30/13 05:42 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
Re: This did not work [Re: Clanton] #1510079
09/30/13 06:40 PM
09/30/13 06:40 PM
Macomb Michigan
65 Belv A990 Offline
Macomb Michigan
Your evac system will never work with what looks like the almost a 70 degree bend into your collector from the primary tubes. Not only is the angle/tip cut of the tube as well as placement depth critical in creating that venturi effect, the level of vacuum production is going to be dependent on a clean high velocity stream of exhaust gas flowing by it. That flow needs to be free of disturbing changes in flow direction to create the needed low pressure in the tube.
MoPower..... Better to be a racer for a moment than a spectator for a lifetime.
Re: This did not work [Re: 65 Belv A990] #1510080
09/30/13 07:28 PM
09/30/13 07:28 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
Mike you need to cut those primary tubes about 5" shorter then re-weld your collector on. Then you can weld the large elbow to it like these.
Re: This did not work [Re: Clanton] #1510081
09/30/13 07:33 PM
09/30/13 07:33 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
I wondered why the headers looked so strange in your launch photo. You made some nice headers for that car, now you can re-do the collectors and you'll be good to go.
Re: This did not work [Re: roadhazard] #1510082
09/30/13 07:41 PM
09/30/13 07:41 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
Ya when I made the headers the angle of thew tubes effected the collector placement but I did what I could for making my first set.
Re: This did not work [Re: Clanton] #1510083
09/30/13 07:48 PM
09/30/13 07:48 PM
North, Alabama
D-50 Offline
D-50  Offline
North, Alabama
This is how I did my headers. First time I ever built any also. I had no choice, they do not make any for my D-50.I wanted my collector to point back so I could run mufflers.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Re: This did not work [Re: D-50] #1510084
09/30/13 08:05 PM
09/30/13 08:05 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
those look nice!Good job.
Re: This did not work [Re: Clanton] #1510085
09/30/13 08:18 PM
09/30/13 08:18 PM
North, Alabama
D-50 Offline
D-50  Offline
North, Alabama
I ordered 2 Summit brand under chasis SBC weld up kits.I still have a lot of bends left in the box,1 kit was not enough bends.
Re: This did not work [Re: D-50] #1510086
09/30/13 08:45 PM
09/30/13 08:45 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
My headers took about 14 J bends to make.
Re: This did not work [Re: Clanton] #1510087
09/30/13 08:51 PM
09/30/13 08:51 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Looks like your going to need another 8 more and then you will be good to go, with a little finish work by attaching new collectors. I think you did good with your header build untill that last part.
Re: This did not work [Re: Clanton] #1510088
09/30/13 09:15 PM
09/30/13 09:15 PM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
I'll bet it didn't work...LOL!
My question is: WHY?? A b-body with a wedge?? Almost as common as a BB in a brand X car...thus many headers are in stock everywhere. Just curious...
Re: This did not work [Re: D-50] #1510089
09/30/13 09:19 PM
09/30/13 09:19 PM
cudadoug Offline
cudadoug  Offline
Well done! Not to hijack, but I'd like to see more pics of that truck...(in a new thread) especially the rear and engine compartment. I'm digging it!
Re: This did not work [Re: cudadoug] #1510090
09/30/13 09:19 PM
09/30/13 09:19 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
They are fender exit headers 2.25'
Re: This did not work [Re: D-50] #1510091
09/30/13 09:24 PM
09/30/13 09:24 PM
GEORGIA
barracuda7199 Offline
GEORGIA
Those look like my d50 headers! I started racing at 15 in a 87 d50 with a 340 had a buddy build me a set with a pipe bender and some 1 3/4 pipe they aren't very pretty by they worked.
Re: This did not work [Re: Clanton] #1510092
09/30/13 10:01 PM
09/30/13 10:01 PM
gregsdart Offline
gregsdart  Offline
I have the same situation, not enough room for collectors. You wouldn't have known unless you tried!
Re: This did not work [Re: cudadoug] #1510093
09/30/13 10:30 PM
09/30/13 10:30 PM
The Great White North
RAMM Offline
RAMM  Offline
Collector design is SUPER important for power production. You NEED to do that stuff on an engine dyno. It is no joke. You would be amazed at what you would see by messing with that stuff on a dyno. J.Rob
2009 PHR\EMC Competitor
2010 PHR\EMC Competitor
2011 PHR\EMC Competitor
2012 PHR\EMC Competitor
2013 PHR\EMC Competitor
2014 HotRod/EMC Competitor
2015 HotRod/EMC NoShow
2016 HotRod/EMC 3rd place SPEC Bigblock
2018 HotRod/EMC 7th place G3
