Re: This did not work
[Re: Clanton]
#1510075
09/30/13 05:25 PM
09/30/13 05:25 PM
Guitar Jones
Better get some tethers on there.
[Re: Challenger 1]
#1510077
09/30/13 05:38 PM
09/30/13 05:38 PM
Posts: 4,489 northern,Ohio,USA
Clanton
northern,Ohio,USA
I made them and the turnout was a after thaught.I was thinking of making the zoomies from where the collector is on insted of the collector.
[Re: Clanton]
#1510079
09/30/13 06:40 PM
09/30/13 06:40 PM
Posts: 46 Macomb Michigan
65 Belv A990
Macomb Michigan
Your evac system will never work with what looks like the almost a 70 degree bend into your collector from the primary tubes. Not only is the angle/tip cut of the tube as well as placement depth critical in creating that venturi effect, the level of vacuum production is going to be dependent on a clean high velocity stream of exhaust gas flowing by it. That flow needs to be free of disturbing changes in flow direction to create the needed low pressure in the tube.
MoPower..... Better to be a racer for a moment than a spectator for a lifetime.
[Re: Clanton]
#1510083
09/30/13 07:48 PM
09/30/13 07:48 PM
Posts: 1,267 North, Alabama
D-50
North, Alabama
This is how I did my headers. First time I ever built any also. I had no choice, they do not make any for my D-50.I wanted my collector to point back so I could run mufflers.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
[Re: Clanton]
#1510085
09/30/13 08:18 PM
09/30/13 08:18 PM
D-50
North, Alabama
I ordered 2 Summit brand under chasis SBC weld up kits.I still have a lot of bends left in the box,1 kit was not enough bends.
[Re: Clanton]
#1510088
09/30/13 09:15 PM
09/30/13 09:15 PM
Posts: 3,245 Between a rock & a hard place
cudadoug
and made a bunch of reversion.I cut it off like before I made it and will make something over the winter. lesson learned.
I'll bet it didn't work...LOL!
My question is: WHY?? A b-body with a wedge?? Almost as common as a BB in a brand X car...thus many headers are in stock everywhere. Just curious...
[Re: D-50]
#1510089
09/30/13 09:19 PM
09/30/13 09:19 PM
cudadoug
Well done! Not to hijack, but I'd like to see more pics of that truck...(in a new thread) especially the rear and engine compartment. I'm digging it!
[Re: D-50]
#1510091
09/30/13 09:24 PM
09/30/13 09:24 PM
Posts: 280 GEORGIA
barracuda7199
GEORGIA
Those look like my d50 headers! I started racing at 15 in a 87 d50 with a 340 had a buddy build me a set with a pipe bender and some 1 3/4 pipe they aren't very pretty by they worked.
