Need to buy a new carb #1508654
09/27/13 10:10 PM
09/27/13 10:10 PM
ont,canada
mopartuner Offline OP
ont,canada
Summit is going to take back my 850 ultra carb so I want to pick up something while I am there.What carb is going to be close ootb and perform the best?My motor is a 410 sb with ported eddys,10.5 to 1,602/624 262/274 dur inst@104 deg.Car has 410 gears,low 1st 904,28 inch tire,3130#w/driver.
410 pump gas solis flat tappet cam 10.95 so far
Re: Need to buy a new carb [Re: mopartuner] #1508655
09/28/13 12:01 AM
09/28/13 12:01 AM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
What was wrong with the 850 ultra?
I really like the Holley 950HP, but I used it on a 451".
Re: Need to buy a new carb [Re: ProSport] #1508656
09/28/13 01:26 AM
09/28/13 01:26 AM
British Columbia
toddd Offline
toddd  Offline
British Columbia
I run a Holley Ultra 950 Hp on my 416. Nice carb, made minimal changes to it.
Re: Need to buy a new carb [Re: mopartuner] #1508657
09/28/13 01:43 AM
09/28/13 01:43 AM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
Summit is going to take back my 850 ultra carb so I want to pick up something while I am there.What carb is going to be close ootb and perform the best?My motor is a 410 sb with ported eddys,10.5 to 1,602/624 262/274 dur [Email]inst@104[/Email] deg.Car has 410 gears,low 1st 904,28 inch tire,3130#w/driver.
NONE of them...
Re: Need to buy a new carb [Re: mopartuner] #1508658
09/28/13 03:33 AM
09/28/13 03:33 AM
I would use the Holley 950 HP, # 80496- what ever the latest dash number is They flat work well on almost every motor I've heard of anyone using one of them on They're not a actual 950 CFM carb,they're little smaller cfm, but they still work very well
Re: Need to buy a new carb [Re: ProSport] #1508659
09/28/13 05:05 AM
09/28/13 05:05 AM
ont,canada
ont,canada
The Ultra 850 and 950 as well from what I see on the net are dead lean ootb.I have changed every tuning part on this carb and it still has a stumble at wot.Not just a little stumble,car goes silent for 5 seconds stumble.The hp carbs are good I guess but I cant buy another Holley product
Re: Need to buy a new carb [Re: mopartuner] #1508660
09/28/13 09:22 AM
09/28/13 09:22 AM
long island new york
K
kingdust Offline
kingdust  Offline
K
If your not happy with Holley you can call pro systems or AED and they can custom make one for you for about the same price. I'm sure you know that already though. I've also had no problems with the Holley HP 950.
LIFE IS A LESSON,YOU LEARN IT WHEN YOUR THROUGH!
Re: Need to buy a new carb [Re: kingdust] #1508661
09/28/13 09:40 AM
09/28/13 09:40 AM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
My next carb will be from Dale Cubic.
Re: Need to buy a new carb [Re: toddd] #1508662
09/28/13 09:56 AM
09/28/13 09:56 AM
ont,canada
ont,canada
you sure that was an ultra?the plain HP is s different animal
Re: Need to buy a new carb [Re: Hot 340] #1508663
09/28/13 09:59 AM
09/28/13 09:59 AM
Ontario,Canada
firefighter3931 Offline
Ontario,Canada
Re: Need to buy a new carb [Re: firefighter3931] #1508664
09/28/13 11:02 AM
09/28/13 11:02 AM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
If Jegs or Summit have any reman 1025rs race demon(4150) that is what I would get.
ran one even on my flat tappet 416 eddy motor and that 1025 was one sweet piece. Nicest carb I have ever had
Faster than any even custom HP 4150 carb I tried, and ran as well as a custom dominator. I tried a number of carbs
Re: Need to buy a new carb [Re: B3422W5] #1508665
09/28/13 11:10 AM
09/28/13 11:10 AM
Joplin, Mo
rt66jim Offline
rt66jim  Offline
Joplin, Mo
I have a PF950HP it is a very good carb. I sent it to Quick Fuel a few years ago to have them work their magic on it. It came back a immediately went 03 and 3mph slower. I tried thru tuning to get it back. I was able to get half of it back. In the end I called QF and ask if they could/would put it back like it was. I sent it back. When it returned. The car ran just like it did before I ever sent the carb to QF.
Sometimes carbs are very good just as they were built. JMO
Re: Need to buy a new carb [Re: rt66jim] #1508666
09/28/13 11:21 AM
09/28/13 11:21 AM
Overland Park, KS.
Joshs68 Offline
Joshs68  Offline
Overland Park, KS.
I put a new carb and intake on this year and could not get the pump shot to come in off idle, and it was causing a stumble. I checked everything, then I took a look at the arm that pushes down the acc pump lever. The arm appeared to be bent a little sloppy, not nice 90*bends. I took it off, tweaked it a little and replaced it. The carb works great now. My point is maybe it is not always something internal, check the most basic parts first. Carb was a Holley 4150 1k annular.
Re: Need to buy a new carb [Re: Joshs68] #1508667
09/28/13 02:18 PM
09/28/13 02:18 PM
RobX4406 Offline
RobX4406  Offline
Are you using an AF meter? How's the ignition and what are the timing settings? Does it have an adveance curve or locked out.
5 seconds... really.
None of the 850 or 950 ultras I've dealt with had much in the way of tuning issues.
The 80496 950hp's are horrible on cruise and require major tweaking to get a decent A/F.
IMO, you aren't going to find anything out of the box that will perform spot on. Everything will require some tweaking. It's not a box stock 375hp 440 where the dealer has a carb on the shelf that runs on thousands of them out there.
Re: Need to buy a new carb [Re: RobX4406] #1508668
09/28/13 02:44 PM
09/28/13 02:44 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
This saves me a bunch of typing...........
Re: Need to buy a new carb [Re: mopartuner] #1508669
09/28/13 04:00 PM
09/28/13 04:00 PM
AndyF Online content
AndyF  Online Content
Drag car only? Depends on max rpm but the 850 ultra should be a good carb for you. The 750 ultra would also work pretty well on that engine.
Re: Need to buy a new carb [Re: mopartuner] #1508670
09/28/13 09:56 PM
09/28/13 09:56 PM
Burlington,Ont.
77DragracerR/T Offline
Burlington,Ont.
On my 408 the best carb has been my 750hp. I tried a 950hp & a 830hp and neither one would out perform the 750. The 750hp was a factory carb I bought and set up and the other 2 were custom builds.Some people have good luck with custom built carbs but I haven't.
77 Aspen R/T 60'@1.41 10.76 @ 123.26
http://www.youtube.com/watch?v=Eya3Ue8KoZk
Re: Need to buy a new carb [Re: 77DragracerR/T] #1508671
09/29/13 01:19 AM
09/29/13 01:19 AM
Glendale Az
Darryls-Demon Offline
Glendale Az
Another one to stay away from if you have a street car is a 80676 950 ultra HP they take a LOT of work to get the cruise AFRs right.
There is a very long thread on Yellow bullet about them.
Re: Need to buy a new carb [Re: RobX4406] #1508672
09/29/13 03:12 AM
09/29/13 03:12 AM
ont,canada
ont,canada
I dont expect to get a carb that is perfect out of the box..............You should maybe change some jets,squirters,air bleeds?The 850 ultra I had had every tuning part changed and it still was crap.I gave a good effort to get it right.I did a search on here and found another guy who had exactly the same problems with a friends 850.Many the same on Yellow Bullet as well,not just me.
Re: Need to buy a new carb [Re: mopartuner] #1508673
09/29/13 12:46 PM
09/29/13 12:46 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
I'll second the suggestion that you contact AED (Richmond, VA, USA) about a carb suitable for your application.
