Need to buy a new carb
#1508654
09/27/13 10:10 PM
09/27/13 10:10 PM
Posts: 614 ont,canada
mopartuner
ont,canada
Summit is going to take back my 850 ultra carb so I want to pick up something while I am there.What carb is going to be close ootb and perform the best?My motor is a 410 sb with ported eddys,10.5 to 1,602/624 262/274 dur inst@104 deg.Car has 410 gears,low 1st 904,28 inch tire,3130#w/driver.
410 pump gas solis flat tappet cam 10.95 so far
Re: Need to buy a new carb
[Re: mopartuner]
#1508657
09/28/13 01:43 AM
09/28/13 01:43 AM
Posts: 12,271 Overpriced Housing Central
RobX4406
Summit is going to take back my 850 ultra carb so I want to pick up something while I am there.What carb is going to be close ootb and perform the best?My motor is a 410 sb with ported eddys,10.5 to 1,602/624 262/274 dur [Email]inst@104[/Email] deg.Car has 410 gears,low 1st 904,28 inch tire,3130#w/driver.
NONE of them...
[Re: mopartuner]
#1508658
09/28/13 03:33 AM
09/28/13 03:33 AM
Posts: 43,213 Bend,OR USA
Cab_Burge
I would use the Holley 950 HP, # 80496- what ever the latest dash number is They flat work well on almost every motor I've heard of anyone using one of them on They're not a actual 950 CFM carb,they're little smaller cfm, but they still work very well
[Re: firefighter3931]
#1508664
09/28/13 11:02 AM
09/28/13 11:02 AM
Posts: 11,716 Portage,michigan
B3422W5
Portage,michigan
If Jegs or Summit have any reman 1025rs race demon(4150) that is what I would get. ran one even on my flat tappet 416 eddy motor and that 1025 was one sweet piece. Nicest carb I have ever had Faster than any even custom HP 4150 carb I tried, and ran as well as a custom dominator. I tried a number of carbs
