gas smell.? about canister and holley hook-up
#1507360
09/25/13 07:05 AM
09/25/13 07:05 AM
Posts: 1,012 indiana
mcmopars
indiana
i have a single vent gas tank going to the charcoal canister.i run a holley 750 street hp carb.is there a way i can make the canister work with this carb? the other two nipples on it i have to cap on the canister because it gets really gassy smelling.i guess my question is can i run a line off the canister to the holley if so what port?really need to tame the gas fumes down.
thanks,off to work
Re: gas smell.? about canister and holley hook-up
[Re: mcmopars]
#1507364
09/26/13 07:07 AM
09/26/13 07:07 AM
mcmopars
indiana
[Re: Challenger 1]
#1507368
09/27/13 08:12 PM
09/27/13 08:12 PM
mcmopars
indiana
Is the fuel tank and vents all hooked up correctly in back?
Where does your vent line end up at up front? On top of the engine by the thermostat?
t
73 has only 1 vent ,which goes to the canister marked tank.which is hooked up,do i hook the purge or bowl port marked on canister to full vaccumm on carb?
[Re: mcmopars]
#1507369
09/27/13 08:48 PM
09/27/13 08:48 PM
Challenger 1
Cincinnati, Ohio
t
73 has only 1 vent ,which goes to the canister marked tank.which is hooked up, do i hook the purge or bowl port marked on canister to full vaccumm on carb?
I'd say purge and the other one is for the carb bowl vent if your carb has one?
Here are pictures of my 74 factory service manual and I believe your 73 should close if not the same. Maybe it'll help some if you can read it?
[image]http://s21.photobucket.com/user/challenger19711/media/After%202-22-2013/SDC19861.jpg.html[/image]
