gas smell.? about canister and holley hook-up #1507360
09/25/13 07:05 AM
09/25/13 07:05 AM
indiana
mcmopars Offline OP
mcmopars  Offline OP
indiana
i have a single vent gas tank going to the charcoal canister.i run a holley 750 street hp carb.is there a way i can make the canister work with this carb? the other two nipples on it i have to cap on the canister because it gets really gassy smelling.i guess my question is can i run a line off the canister to the holley if so what port?really need to tame the gas fumes down.
thanks,off to work
Re: gas smell.? about canister and holley hook-up [Re: mcmopars] #1507361
09/25/13 07:58 AM
09/25/13 07:58 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
What car and year?
Re: gas smell.? about canister and holley hook-up [Re: Challenger 1] #1507362
09/25/13 08:12 PM
09/25/13 08:12 PM
indiana
mcmopars Offline OP
mcmopars  Offline OP
indiana
73 340 duster,360 crate,
Re: gas smell.? about canister and holley hook-up [Re: mcmopars] #1507363
09/25/13 08:21 PM
09/25/13 08:21 PM
indiana
mcmopars Offline OP
mcmopars  Offline OP
indiana
i know how the factory did it,but not sure how to make it work with the holley 750 street hp series carb.like i said right now the only vent from the tank is where it should be on the canister,with plugs on the other two of canister ports.which does not seem to be helping
Re: gas smell.? about canister and holley hook-up [Re: mcmopars] #1507364
09/26/13 07:07 AM
09/26/13 07:07 AM
indiana
mcmopars Offline OP
mcmopars  Offline OP
indiana
bump,anyone?
Re: gas smell.? about canister and holley hook-up [Re: mcmopars] #1507365
09/26/13 10:18 AM
09/26/13 10:18 AM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
All you're doing right now is venting the tank into the engine compartment with the other two ports plugged.
Originally, the three hook-ups on the canister were 1. vent line from gas tank 2. carb bowl vent 3. vacuum port on carb(to pull vapors out of the canister into the engine)
Does your carb have a large fitting in the base plate?
Re: gas smell.? about canister and holley hook-up [Re: burdar] #1507366
09/26/13 09:34 PM
09/26/13 09:34 PM
indiana
mcmopars Offline OP
mcmopars  Offline OP
indiana
so keep bowl vent capped,and run a line to a full vacuum on carb?
Re: gas smell.? about canister and holley hook-up [Re: mcmopars] #1507367
09/27/13 08:12 AM
09/27/13 08:12 AM
Cincinnati, Ohio
Cincinnati, Ohio
Is the fuel tank and vents all hooked up correctly in back?
Where does your vent line end up at up front? On top of the engine by the thermostat?
Re: gas smell.? about canister and holley hook-up [Re: Challenger 1] #1507368
09/27/13 08:12 PM
09/27/13 08:12 PM
indiana
mcmopars Offline OP
mcmopars  Offline OP
indiana
t
73 has only 1 vent ,which goes to the canister marked tank.which is hooked up,do i hook the purge or bowl port marked on canister to full vaccumm on carb?
Re: gas smell.? about canister and holley hook-up [Re: mcmopars] #1507369
09/27/13 08:48 PM
09/27/13 08:48 PM
Cincinnati, Ohio
Cincinnati, Ohio
t
73 has only 1 vent ,which goes to the canister marked tank.which is hooked up, do i hook the purge or bowl port marked on canister to full vaccumm on carb?
I'd say purge and the other one is for the carb bowl vent if your carb has one?
Here are pictures of my 74 factory service manual and I believe your 73 should close if not the same. Maybe it'll help some if you can read it?
[image]http://s21.photobucket.com/user/challenger19711/media/After%202-22-2013/SDC19861.jpg.html[/image]
Re: gas smell.? about canister and holley hook-up [Re: Challenger 1] #1507370
09/27/13 10:50 PM
09/27/13 10:50 PM
indiana
mcmopars Offline OP
mcmopars  Offline OP
indiana
ill go that route then,thank you
