tire movement on rim #1498541
09/08/13 09:03 PM
09/08/13 09:03 PM
Az
Crizila Offline OP
Crizila  Offline OP
Az
Got a new pair of 15X10 Convo pros that I really do not want to put screws in to. Unfortunately, this weekend I noticed about a 2" - 3" movement ( 6 runs) between the wheels and the rims. I run tubes in my Hoosier Quick Time Pros. Car seems to work best at around 12 psi. Any other solutions out there to keep this from happening - without using screws / bead locks ?
Fastest 300
Re: tire movement on rim [Re: Crizila] #1498542
09/08/13 09:06 PM
09/08/13 09:06 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Glue them to the rims
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: tire movement on rim [Re: Crizila] #1498543
09/08/13 09:07 PM
09/08/13 09:07 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
glue the tyre to the rim , I use high tack gasket sealant .
that is the most common way to deal with tyre movement
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: tire movement on rim [Re: Crizila] #1498544
09/09/13 03:42 AM
09/09/13 03:42 AM
I don't like using tubes in any of my drag race tires,no screws either Your committed so trying rotating the tires side to side and watch the movement. I inflate my new tires to between 25 and 30 lbs to seat them on the rims and let them sit overnight before using them at the lower pressures needed for racing They still move some, both the radials and bias plys The tire moving with the tube is a big No No your taking a chance on ripping the stem out of the tube
Re: tire movement on rim [Re: Crizila] #1498545
09/09/13 10:57 AM
09/09/13 10:57 AM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
I have had a couple of different tire/rim combos that the tire moved several inches each racing day. It concerned me at first, but it never presented a problem. So I ran them that way.
Is there a real risk as long as there aren't tubes?
Master, again and still
Re: tire movement on rim [Re: Cab_Burge] #1498546
09/09/13 11:06 AM
09/09/13 11:06 AM
Az
Crizila Offline OP
Crizila  Offline OP
Az
10-4 on the tire movement with tubes Cab. I would prefer to run tubes. Think I will try the glue trick and rotate side to side more often. Movement in pic is about 6 runs.
Fastest 300
Re: tire movement on rim [Re: Crizila] #1498547
09/09/13 11:28 AM
09/09/13 11:28 AM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
When I bought my new wheels this year I spent a lot of time researching this as I didn't want to drill the wheels if I didn't have to !4 inch wide wheels, 14-32's slicks). I was told if I run tubes you MUST drill wheels or risk ripping valve stem out of the tube and wrecking the car. If running tube-less seal the sidewalls with dawn soap mixed with a little water. Clean tire bead with lacquer thinner, scuff inside wheel bead with red sanding pad and clean with lacquer thinner. install tire on rim and carefully brush "high-tac" sealer on bead. Inflate slick to 20-25 pounds or tire to 35-40 pounds and let sit for 24 hours if possible. Set pressure where desired and go racing. Mine have moved approximately 1/4 inch in 4 races. The shop that mounted mine took extreme care when mounting and I had very little clean-up but I did so with some brake cleaner sprayed on a rag. The way it looks I will never drill a set of wheels again. My 60 foots are in the 1.38 range.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: tire movement on rim [Re: pittsburghracer] #1498548
09/09/13 11:51 AM
09/09/13 11:51 AM
Az
Crizila Offline OP
Crizila  Offline OP
Az
Thanks for all the good info!! Maybe I will pull the tubes and try gluing them .
Fastest 300
Re: tire movement on rim [Re: Crizila] #1498549
09/09/13 12:50 PM
09/09/13 12:50 PM
PA.
"Little"John
"Little"John
PA.
No problem. Better safe than sorry.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: tire movement on rim [Re: pittsburghracer] #1498550
09/09/13 07:36 PM
09/09/13 07:36 PM
High Ridge MO.
MOPARCHAS Offline
MOPARCHAS  Offline
High Ridge MO.
I use the permatex HY Tack on mine and they have not moved at all works great
Re: tire movement on rim [Re: MOPARCHAS] #1498551
09/09/13 11:16 PM
09/09/13 11:16 PM
Az
Crizila Offline OP
Crizila  Offline OP
Az
Pulled the tubes today and glued the tires to the rims with permatex "high-tac" as I had some in stock. we'll see what happens later this month. Tubes looked like new when I pulled them out.
Fastest 300
