package tray with a roll bar #1497937
09/07/13 09:33 PM
09/07/13 09:33 PM
Idaho
Runner Offline OP
Runner  Offline OP
Idaho
what is everyone running for a package tray when the bar goes through the speaker holes in the package tray?. ive tried a couple different things and nothing seeems to make me happy. its hard to get something to go around the bar and be somewhat rigid. are most people using carpet? thats what im thinking now
Re: package tray with a roll bar [Re: Runner] #1497938
09/07/13 09:51 PM
09/07/13 09:51 PM
PA
70HemiGTX Offline
70HemiGTX  Offline
PA
I used a piece of aluminum and cut it to size. Cut out the holes for the rollbars and then covered it with black naugahide (vinyl).
Re: package tray with a roll bar [Re: 70HemiGTX] #1497939
09/07/13 10:01 PM
09/07/13 10:01 PM
Ft. Wayne, IN.
Q
QTR MILR Offline
QTR MILR  Offline
Q
Ft. Wayne, IN.
I used some cheap "automotive" carpet from Stuffmart....
Scott
69 Satellite, 3650lb street car... Dunnuck Racing pump gas 440. Best of 10:60@127...
Re: package tray with a roll bar [Re: QTR MILR] #1497940
09/07/13 11:04 PM
09/07/13 11:04 PM
west palm beach, florida
modelmakerinc Offline
mine is hardboard covered in very short cut pile carpet. I cut it in a way to wrap around the down bars, the package tray is three pieces held down by the speakers screws and since it is cut pile the seams disappear/blend together.
Exceptional Architectural, Yacht and Automotive scale models. e-mail modelmakerinc@att.net for a portfolio review. www.modelmakerinc.com
Re: package tray with a roll bar [Re: modelmakerinc] #1497941
09/07/13 11:17 PM
09/07/13 11:17 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
I use cardboard covered in black vinyl.
Re: package tray with a roll bar [Re: ProSport] #1497942
09/08/13 01:19 AM
09/08/13 01:19 AM
Mooresburg, Tn
'72CudaRacer Offline
Mooresburg, Tn
Alum, in two pieces. Real PITA though.
Brian
Re: package tray with a roll bar [Re: Runner] #1497943
09/08/13 03:22 PM
09/08/13 03:22 PM
Phoenix,Az.
hemicop Offline
hemicop  Offline
Phoenix,Az.
Speakerboard---it's cheap, easy to work with, gives a stock appearence to the interior & if you screw-up cutting it you can cheaply re-do it with another piece quickly.........
Re: package tray with a roll bar [Re: hemicop] #1497944
09/08/13 03:39 PM
09/08/13 03:39 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I just used the factory package tray.
Re: package tray with a roll bar [Re: justinp61] #1497945
09/09/13 01:48 PM
09/09/13 01:48 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
Here is mine on my Challenger. Re-used Factory speaker tray.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: package tray with a roll bar [Re: Runner] #1497946
09/09/13 06:07 PM
09/09/13 06:07 PM
Az
Crizila Offline
Crizila  Offline
Az
What package tray?
Fastest 300
Re: package tray with a roll bar [Re: Crizila] #1497947
09/09/13 08:51 PM
09/09/13 08:51 PM
Canton, Ohio
Crazy68Dart Offline
Crazy68Dart  Offline
Canton, Ohio
I was considering this, and thought that ABS sheets might be what I try first. Should be fairly easy to work with. Cover it with some kind of short pile carpet, vinyl, etc.
http://www.amazon.com/ABS-Plastic-Sheet-Thick-Thickness/dp/B004UBUX5C
Either way, not looking forward to it.
383, Hemi 4-Speed, AlterKtion, D60
Re: package tray with a roll bar [Re: Crazy68Dart] #1497948
09/09/13 09:47 PM
09/09/13 09:47 PM
Sunnyvale, CA
Jeepmon Offline
Jeepmon  Offline
Sunnyvale, CA
I have speakerboard right now, however the local tech guy told me it has to be metal per NHRA.. I thought it just had to be sealed..
Re: package tray with a roll bar [Re: Jeepmon] #1497949
09/09/13 10:11 PM
09/09/13 10:11 PM
Canton, Ohio
Crazy68Dart Offline
Crazy68Dart  Offline
Canton, Ohio
Really? The sub-structure/bracing underneath is metal, but the finished tray part needs to be too?
Re: package tray with a roll bar [Re: Crazy68Dart] #1497950
09/09/13 10:39 PM
09/09/13 10:39 PM
michigan
jbmopars Offline
jbmopars  Offline
michigan
Mine is aluminum covered by the factory fibre board knotched for the tubing then covered with the factory headliner material. After knotching the cut out was replaced back in its location.
Re: package tray with a roll bar [Re: Crazy68Dart] #1497951
09/09/13 10:46 PM
09/09/13 10:46 PM
Mooresburg, Tn
Mooresburg, Tn
If the battery and/or fuel cell is located in the trunk area, then yes, the bulkhead must be sealed with a min of .032" alum.
If using the stock, unaltered fuel tank and the battery remains in the stock (up front) location, then it can be left open.
Brian
Re: package tray with a roll bar [Re: '72CudaRacer] #1497952
09/09/13 10:56 PM
09/09/13 10:56 PM
Canton, Ohio
Crazy68Dart Offline
Crazy68Dart  Offline
Canton, Ohio
Brian
Thanks, even if the battery is in an approved box in the trunk?
Re: package tray with a roll bar [Re: Crazy68Dart] #1497953
09/09/13 11:10 PM
09/09/13 11:10 PM
Az
Crizila Offline
Crizila  Offline
Az
Brian
Yes, and if you do steel, I think it has to be .016" thick.
Fastest 300
Re: package tray with a roll bar [Re: Crizila] #1497954
09/09/13 11:40 PM
09/09/13 11:40 PM
Fulton County, PA
CMcAllister Online content
Mr. Helpful
CMcAllister  Online Content
Mr. Helpful
Fulton County, PA
If you use a sealed battery box, like a Moroso 74050 or a Taylor 48100, and have no fuel system stuff in the trunk, a sealed, metal bulkhead is not required.
