Re: package tray with a roll bar
[Re: 70HemiGTX]
#1497939
09/07/13 10:01 PM
09/07/13 10:01 PM
Posts: 240 Ft. Wayne, IN.
QTR MILR
Ft. Wayne, IN.
I used some cheap "automotive" carpet from Stuffmart....
Scott
69 Satellite, 3650lb street car... Dunnuck Racing pump gas 440. Best of 10:60@127...
[Re: justinp61]
#1497945
09/09/13 01:48 PM
09/09/13 01:48 PM
Posts: 4,585 Motor City
6PKRTSE
Motor City
Here is mine on my Challenger. Re-used Factory speaker tray.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: Crizila]
#1497947
09/09/13 08:51 PM
09/09/13 08:51 PM
Posts: 1,212 Canton, Ohio
Crazy68Dart
Canton, Ohio
I was considering this, and thought that ABS sheets might be what I try first. Should be fairly easy to work with. Cover it with some kind of short pile carpet, vinyl, etc. http://www.amazon.com/ABS-Plastic-Sheet-Thick-Thickness/dp/B004UBUX5CEither way, not looking forward to it.
383, Hemi 4-Speed, AlterKtion, D60
[Re: Crazy68Dart]
#1497951
09/09/13 10:46 PM
09/09/13 10:46 PM
Posts: 2,054 Mooresburg, Tn
'72CudaRacer
Mooresburg, Tn
I have speakerboard right now, however the local tech guy told me it has to be metal per NHRA.. I thought it just had to be sealed..
Really? The sub-structure/bracing underneath is metal, but the finished tray part needs to be too?
If the battery and/or fuel cell is located in the trunk area, then yes, the bulkhead must be sealed with a min of .032" alum. If using the stock, unaltered fuel tank and the battery remains in the stock (up front) location, then it can be left open.
Brian
[Re: '72CudaRacer]
#1497952
09/09/13 10:56 PM
09/09/13 10:56 PM
Crazy68Dart
Canton, Ohio
Brian
Thanks, even if the battery is in an approved box in the trunk?
[Re: Crazy68Dart]
#1497953
09/09/13 11:10 PM
09/09/13 11:10 PM
Posts: 7,506 Az
Crizila
Az
Brian
Yes, and if you do steel, I think it has to be .016" thick.
Fastest 300
[Re: Crizila]
#1497954
09/09/13 11:40 PM
09/09/13 11:40 PM
Posts: 11,706 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
If you use a sealed battery box, like a Moroso 74050 or a Taylor 48100, and have no fuel system stuff in the trunk, a sealed, metal bulkhead is not required.
