Re: Tricked Out Solid Flat Tappet Small Block Stuff
[Re: Sb Valiant]
#1497398
09/07/13 08:43 AM
09/07/13 08:43 AM
Posts: 20,655 in a cattle trailer down by th...
Guitar Jones
Yeah, it's kinda like trying to make a 10.5 tire leaf spring car work like a 14/32 four link car.
[Re: dizuster]
#1497400
09/07/13 11:58 AM
09/07/13 11:58 AM
Posts: 6,148 Melbourne , Australia
LA360
They would be the Fererra or Trend lifters in a different box I would imagine. The only reason you would spend that kind of $$$ on flat tappet lifters is if your class dictated flat tappet lifters. Some of the Super Stock classes here mandated the use of them, and those engine would turn to 9500 rpm. Tool steel lifters are an alternative to the Schubeck style lifter.
Alan Jones
[Re: LA360]
#1497401
09/07/13 12:06 PM
09/07/13 12:06 PM
Posts: 11,724 Portage,michigan
B3422W5
Portage,michigan
agree...I bought and ran shubecks when I was swapping flat tappets around on an eddie headed 416 a few years back....just because it saved extra work and grief... but roller is the way to go if you aren't class limited as you point out... sold the shubecks on here, might still be in use.....
