Blending E85 #1495041
09/02/13 12:14 PM
09/02/13 12:14 PM
San Diego CA
65 Hemi Offline OP
65 Hemi  Offline OP
San Diego CA
Who is blending E85? What octane gas are you using? Do you blend in 55 gal drums?
Doug
MOPAR or NO CAR!!!
1965 Dodge Coronet soon a 6.1 Hemi with a Magnson blower 810 hp on pump gas
1964 Dodge Polara 582" Indy alum Block 426-1RA heads,
1933 Plymouth PE all Steel, LT1 4L60E
1959 Plymouth Savoy 33,000 mile survivor
Old cars are never done. They are ongoing projects!
Re: Blending E85 [Re: 65 Hemi] #1495042
09/02/13 04:39 PM
09/02/13 04:39 PM
San Diego CA
65 Hemi Offline OP
65 Hemi  Offline OP
San Diego CA
Anybody? I'm sure not everybody just buys it from the pump and its ok.
Doug
MOPAR or NO CAR!!!
Re: Blending E85 [Re: 65 Hemi] #1495043
09/02/13 04:49 PM
09/02/13 04:49 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I buy from the pump at Meijer and if its in the summer
I never had to do anything... its always been E-85-86
EDIT
If you come up short in testing the fuel your gonna
need to blend with 110
Re: Blending E85 [Re: 65 Hemi] #1495044
09/02/13 06:56 PM
09/02/13 06:56 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Why would you want to blend it? It's 85% ethanol and why would you want to change that?
Re: Blending E85 [Re: Challenger 1] #1495045
09/02/13 07:16 PM
09/02/13 07:16 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I think he is saying if it falls short of the E-85 rating
Re: Blending E85 [Re: MR_P_BODY] #1495046
09/02/13 09:10 PM
09/02/13 09:10 PM
San Diego CA
65 Hemi Offline OP
65 Hemi  Offline OP
San Diego CA
Yes Mr. P your correct. Sometimes it less at the pump and if you tune your car for 85% it may run lean.
Doug
MOPAR or NO CAR!!!
Re: Blending E85 [Re: 65 Hemi] #1495047
09/02/13 09:20 PM
09/02/13 09:20 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I always tested my fuel before I bought it... I would
hang around the E-85 pump and wait for a person to
buy some.. I'd ask if I could take a sample and explained
why I was doing it... I NEVER had a person say no..
especially when I could tell them the alky content
that they were buying... if it showed good(85-86)
I would then load my barrels/drums... I dont buy
it if it show low(why pay for a product that isnt right)
which it never has been at Meijer when I bought it
Re: Blending E85 [Re: 65 Hemi] #1495048
09/02/13 11:55 PM
09/02/13 11:55 PM
Dandridge TN
Dabee Online content
Dabee  Online Content
Dandridge TN
Hear in east Tenn all we can get is E70. The station owners have showen me a Letter from their supplier that states E70 is all they will ever get. To compensate I blend 98% ethanol with it. I add one gallon of 98% ethanol to the E70. This blend brings the mix up to 85% ethanol. I buy the 98% ethanol in 55 gallon drums. I can get 100% ethanol locally but at $10 a quart it gets expensive, besides the stuff I buy by the quart is better stuited for drinking. As far as mixing 110 race fuel with the ethanol you will be making yor engine run even richer if you are tuned for E85. If you end up with an E70 blend, I would jet the engine for E70, so you will need to jet down to keep from being to rich. I tune using an o2 sensor set on a Lambda scale. I tune my engine to be 15 to 20% rich when I reach the strip, so on a lambda scale you want to be between 80 and 85. Hope this helps.
Re: Blending E85 [Re: Dabee] #1495049
09/03/13 12:10 AM
09/03/13 12:10 AM
MR_P_BODY Offline
MR_P_BODY  Offline
If you can buy E-100 that is drinking alky and is taxed
based on drinking alky... thats why it comes as a max
of E-98 coming out of the ethanol plants(they dont
want to pay the drinking alky taxes)
Re: Blending E85 [Re: 65 Hemi] #1495050
09/03/13 08:33 AM
09/03/13 08:33 AM
Cincinnati, Ohio
Cincinnati, Ohio
Actually the motor would be rich, not lean if the percentage was less than 85% and you were tuned for 85%.
Re: Blending E85 [Re: Challenger 1] #1495051
09/03/13 10:11 AM
09/03/13 10:11 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I think he would be more concerned with detonation
with the lower octane(less ethanol)
Re: Blending E85 [Re: MR_P_BODY] #1495052
09/03/13 11:17 AM
09/03/13 11:17 AM
New Lenox IL
cudadon Offline
cudadon  Offline
New Lenox IL
I was told if you did that to raise octane, you need to use UNLEADED race fuel because the lead and ethanol do not mix right.
Don
Re: Blending E85 [Re: cudadon] #1495053
09/03/13 11:42 AM
09/03/13 11:42 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Don
I dont know for fact.. we use to use unleaded because
thats all we had in the lab... or E-98 and most
of the time we used E-98 for blending(if we had
it at the time)... we normally had 1 drum of it..
but if someone used it and didnt tell me we were out
I didnt order it(unless I happened to check the drum room)
Re: Blending E85 [Re: MR_P_BODY] #1495054
09/03/13 07:23 PM
09/03/13 07:23 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Any do or don'ts on type of storage drums?
What type of checking gauge?
Will it work with 13/1 ratio?
Re: Blending E85 [Re: cudadon] #1495055
09/03/13 07:47 PM
09/03/13 07:47 PM
High Ridge MO.
MOPARCHAS Offline
MOPARCHAS  Offline
High Ridge MO.
Don
thats what I was told also do not mix leaded race gas with E85 ask Mark Sullens
Re: Blending E85 [Re: cudaman1969] #1495056
09/03/13 09:00 PM
09/03/13 09:00 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Almost all the steel drums have a epoxy liner in them
now days so those work fine... if you use plastic drums
they need to have a permeation barrier(it looks like
a separate layer/liner that is molded in it)... I
use the water tester for checking the content.. I
got it from Quick Fuel or Summit... yes it will work
with 13.1... my static compression is 14.1:1 but that
doesnt mean much... my cam really lowers the compression
Re: Blending E85 [Re: MR_P_BODY] #1495057
09/03/13 10:31 PM
09/03/13 10:31 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Thanks for the reply, I plan on using two 3310 Hollys. For just a ballpark guess how much percentage should I open up jets and idle circuits, 20-30 percent?
Re: Blending E85 [Re: cudaman1969] #1495058
09/03/13 10:42 PM
09/03/13 10:42 PM
MR_P_BODY Offline
MR_P_BODY  Offline
It takes more to it that just the jets and idle...
but it needs 30% more fuel... make sure your supply
can deliver it also
Re: Blending E85 [Re: MR_P_BODY] #1495059
09/03/13 11:15 PM
09/03/13 11:15 PM
San Diego CA
65 Hemi Offline OP
65 Hemi  Offline OP
San Diego CA
Talk to Mark Sullens He know his stuff. Im going to run a 15:1 static B1 and it should not be an issue. He has a few 16:1 motor running on it.
Doug
MOPAR or NO CAR!!!
