Re: BB screw in freeze plugs [Re: dogdays] #1490927
08/28/13 07:08 PM
08/28/13 07:08 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Those racecar shops must have special short taps for threading. I went back to the brass cup plugs and put my "tricking out" expertise to use somewhere else.
R.
The video above talks about shortening a tap , I have done that but not on something that big.
Mcmaster lists a tap for shallow holes so they do make them , they just are not cheap.
Re: BB screw in freeze plugs [Re: MR_P_BODY] #1490928
08/28/13 08:20 PM
08/28/13 08:20 PM
NE Oklahoma
V
Von Offline OP
Von  Offline OP
V
NE Oklahoma
The nut does stick out some... but to be honest I
havent ever had one hit the starter.. I do use the
mini Chrysler production starter
Had Osmileys order me 2 today.
What color of permatex do you use?
I have a robbmc starter, so hopefully it clears.
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: BB screw in freeze plugs [Re: Von] #1490929
08/28/13 08:55 PM
08/28/13 08:55 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I use the good old red Permatex... also put a bead
of it on the overlapping lip just in case
Re: BB screw in freeze plugs [Re: MR_P_BODY] #1490930
08/28/13 10:30 PM
08/28/13 10:30 PM
Illinois
colt340 Offline
colt340  Offline
Illinois
On a stock RB block, who has done it?
Any links to the plugs? Ive been told they need to be a shallow plug to keep from bottoming on the cylinders?
1.25 npt tap?
Thanks for any help.
This is what I use on some of my blocks that have
had issues... never had one of these come out...
I put Permitex on it and tighten it up
Mr P what is the name of the company that makes the freeze plug with the nut
in the center?
Re: BB screw in freeze plugs [Re: colt340] #1490931
08/28/13 10:34 PM
08/28/13 10:34 PM
MR_P_BODY Offline
MR_P_BODY  Offline
1.25 npt tap?
in the center?
I'll have to look tomorrow but its the standard company
that makes most of them... I have posted the name
and P/N in other post but I forget right now
Re: BB screw in freeze plugs [Re: Von] #1490932
08/28/13 11:11 PM
08/28/13 11:11 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
I had to re tap my screw in plugs and cut off 4 threads of the tap to clear the cylinder wall.I posted about it here a few yrs ago when I did it.
Re: BB screw in freeze plugs [Re: Clanton] #1490933
08/28/13 11:16 PM
08/28/13 11:16 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
My alum SB's are not pipe thread, not sure of thread size, use a standard thread with o ring plug.
Re: BB screw in freeze plugs [Re: jcc] #1490934
08/28/13 11:26 PM
08/28/13 11:26 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Thats what my alum sprint car block used
Re: BB screw in freeze plugs [Re: VernMotor] #1490935
08/28/13 11:33 PM
08/28/13 11:33 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Bob I think I remember that . Norwalk ?
Yes Norwalk 2010.
Re: BB screw in freeze plugs [Re: JohnRR] #1490936
08/28/13 11:37 PM
08/28/13 11:37 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
I always just wire wheel the outside edge and JB-weld them to the block. I had one shoot out one time in 2nd gear and almost wrecked.
How does the JB hold up ? I have some to install in a block that some donkey gouged the holes up pretty good when removing them during the rebuild before this one
Seems to hold up fine, mine have always been installed by someone else with some kind of sealer, then after my incident on the track I started grinding the block and outside edge of the freeze plugs down to bare metal and then putting a bead of JB-Weld around the perimeter of each freeze plug. May not be the best way but it makes me feel better that they're probably not gonna shoot out of the block at over 100 mph.
Re: BB screw in freeze plugs [Re: colt340] #1490937
08/29/13 12:56 AM
08/29/13 12:56 AM
NE Oklahoma
V
Von Offline OP
Von  Offline OP
V
NE Oklahoma
in the center?
The ones I ordered were Dorman. PN 02483
Re: BB screw in freeze plugs [Re: Von] #1490938
08/29/13 10:06 PM
08/29/13 10:06 PM
Illinois
colt340 Offline
colt340  Offline
Illinois
in the center?
Thanks Von I will look into doorman.
