BB screw in freeze plugs #1490907
08/26/13 01:19 AM
08/26/13 01:19 AM
NE Oklahoma
V
Von Offline OP
Von  Offline OP
V
NE Oklahoma
On a stock RB block, who has done it?
Any links to the plugs? Ive been told they need to be a shallow plug to keep from bottoming on the cylinders?
1.25 npt tap?
Thanks for any help.
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: BB screw in freeze plugs [Re: Von] #1490908
08/26/13 01:54 AM
08/26/13 01:54 AM
U.S.
moparniac Offline
moparniac  Offline
U.S.
I've seen a regular freeze plug put in then the block around the freeze up was tapped in 3 places aroubd the plug and had fasteners with a washer under the head to hold plug in.
Mopar Performance
Re: BB screw in freeze plugs [Re: Von] #1490909
08/26/13 10:57 AM
08/26/13 10:57 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
I don't think that screw in plugs are NPT , if there were you'd have a tough time tapping them without some special taps because of how far the tap needs to go in to get the correct taper.
Re: BB screw in freeze plugs [Re: Von] #1490910
08/26/13 11:15 AM
08/26/13 11:15 AM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
I always just wire wheel the outside edge and JB-weld them to the block. I had one shoot out one time in 2nd gear and almost wrecked.
Re: BB screw in freeze plugs [Re: ProSport] #1490911
08/26/13 11:17 AM
08/26/13 11:17 AM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
Bob I think I remember that . Norwalk ?
Re: BB screw in freeze plugs [Re: ProSport] #1490912
08/26/13 12:20 PM
08/26/13 12:20 PM
JohnRR Offline
JohnRR  Offline
How does the JB hold up ? I have some to install in a block that some donkey gouged the holes up pretty good when removing them during the rebuild before this one
Re: BB screw in freeze plugs [Re: JohnRR] #1490913
08/27/13 04:20 PM
08/27/13 04:20 PM
NE Oklahoma
V
Von Offline OP
Von  Offline OP
V
NE Oklahoma
I wonder what thread they are?
Re: BB screw in freeze plugs [Re: Von] #1490914
08/27/13 04:37 PM
08/27/13 04:37 PM
Vermont
TrWaters Offline
TrWaters  Offline
Vermont
http://www.youtube.com/watch?v=V8_tsvQSq6k
I know its a Ford, but you get the idea. From what I understand, you would need 2 taps. One to start with, and then one that would need to be shortened, to finish the more shallow holes.
Re: BB screw in freeze plugs [Re: TrWaters] #1490915
08/27/13 05:00 PM
08/27/13 05:00 PM
JohnRR Offline
JohnRR  Offline
Thanks Tom ...
I stand corrected ... surprise ??
They are NPT , those taps aren't cheap and it looks like you need 2 , one to start the job and a second that is cut down so you can properly tap the hole so the plug is the correct depth. I have a 383 that someone gouged up the plug holes , that would be the way to fix them ...
Just checked Mcmaster , 1 1/2 -11 pipe tap is about 175 and a shallow hole tap is another 217 ...
Re: BB screw in freeze plugs [Re: JohnRR] #1490916
08/27/13 05:07 PM
08/27/13 05:07 PM
NE Oklahoma
V
Von Offline OP
Von  Offline OP
V
NE Oklahoma
A guy on the Bag has the standard tap for 10 bucks. It is used with a few chipped teeth, but will work for this job.
Also, I do believe for a Mope you need a 1.25 NPT tap, not a 1.5?
Re: BB screw in freeze plugs [Re: Von] #1490917
08/27/13 09:57 PM
08/27/13 09:57 PM
JohnRR Offline
JohnRR  Offline
I was just coming to update this .
The holes in the side of the block are 1.625 , 1 1/4 tap needs a 1.5 hole , 1 1/2 half tap needs a 1.75 hole .
I have both taps here at work , the 1 1/4 isn't going to work so you have to use a 1 1/2 after you open up the holes in the block.
Let us know how it works out ...
Re: BB screw in freeze plugs [Re: JohnRR] #1490918
08/28/13 12:36 AM
08/28/13 12:36 AM
NE Oklahoma
V
Von Offline OP
Von  Offline OP
V
NE Oklahoma
I was going off of this chart. http://www.engineeringtoolbox.com/npt-national-pipe-taper-threads-d_750.html
I thought the nominal OD of 1.660 meant the 1.25 tap should work?
Re: BB screw in freeze plugs [Re: Von] #1490919
08/28/13 01:00 AM
08/28/13 01:00 AM
MR_P_BODY Offline
MR_P_BODY  Offline
You need to look at the tap drill size so you can
get close to the number of threads in.. in your case
of 1 1/4 NPT its a 1.5 tap drill
Re: BB screw in freeze plugs [Re: Von] #1490920
08/28/13 01:14 AM
08/28/13 01:14 AM
MR_P_BODY Offline
MR_P_BODY  Offline
1.25 npt tap?
This is what I use on some of my blocks that have
had issues... never had one of these come out...
I put Permitex on it and tighten it up
Re: BB screw in freeze plugs [Re: MR_P_BODY] #1490921
08/28/13 01:16 AM
08/28/13 01:16 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Another view
Re: BB screw in freeze plugs [Re: MR_P_BODY] #1490922
08/28/13 08:12 AM
08/28/13 08:12 AM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
is there a rule mandating screw in freeze plugs? I seem to have some seapage around mine as i'm inspecting the block getting ready to reinstall.
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
Re: BB screw in freeze plugs [Re: Jerry] #1490923
08/28/13 08:24 AM
08/28/13 08:24 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I've never seen one
Re: BB screw in freeze plugs [Re: MR_P_BODY] #1490924
08/28/13 01:00 PM
08/28/13 01:00 PM
NE Oklahoma
V
Von Offline OP
Von  Offline OP
V
NE Oklahoma
I see they have one that is 1.625 and expands to 1.655. I guess that is the plug I need? f
How deep do the plugs sit in the block? I ask because the plug I need to fix is behind the starter. Im afraid there may be interference between starter and the head of the bolt.
Re: BB screw in freeze plugs [Re: Von] #1490925
08/28/13 02:58 PM
08/28/13 02:58 PM
dogdays Offline
dogdays  Offline
No doubt some racers have been doing the screw in freeze plug thing for years. I bought the books, thought it looked really trick.
So I was going to do this, back in the early '80s. It was a chevy 283, boy did I learn a lot on that engine. For example, the length of main studs have to work with the crank main journal size! (the 283's 2.30" mains didn't work with ARP main studs for a 2.45" main)
Anyway, the mechanical foreman was my buddy and regardless of cost, he gave me the right size pipe tap. I took it home, stuck it into the hole, and ran right into the backsides of the cylinders. Bummer! What do we do now? As I didn't want to admit defeat, I put the tap in my rollaround toolbox and forgot about it. It's still there.
Those racecar shops must have special short taps for threading. I went back to the brass cup plugs and put my "tricking out" expertise to use somewhere else.
That maybe when I bought my Craftsman die grinder. Now THAT was a good investment!
R.
Re: BB screw in freeze plugs [Re: Von] #1490926
08/28/13 03:34 PM
08/28/13 03:34 PM
MR_P_BODY Offline
MR_P_BODY  Offline
The nut does stick out some... but to be honest I
havent ever had one hit the starter.. I do use the
mini Chrysler production starter
