Re: BB screw in freeze plugs
[Re: dogdays]
#1490927
08/28/13 07:08 PM
08/28/13 07:08 PM
Posts: 75,098 A Banana Republic near you.
JohnRR
Those racecar shops must have special short taps for threading. I went back to the brass cup plugs and put my "tricking out" expertise to use somewhere else.
R.
The video above talks about shortening a tap , I have done that but not on something that big.
Mcmaster lists a tap for shallow holes so they do make them , they just are not cheap.
[Re: MR_P_BODY]
#1490928
08/28/13 08:20 PM
08/28/13 08:20 PM
Posts: 3,698 NE Oklahoma
Von
NE Oklahoma
The nut does stick out some... but to be honest I havent ever had one hit the starter.. I do use the mini Chrysler production starter
Had Osmileys order me 2 today.
What color of permatex do you use?
I have a robbmc starter, so hopefully it clears.
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72.
Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
[Re: Von]
#1490929
08/28/13 08:55 PM
08/28/13 08:55 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I use the good old red Permatex... also put a bead of it on the overlapping lip just in case ![](/ubbthreads/images/graemlins/wave.gif)
[Re: MR_P_BODY]
#1490930
08/28/13 10:30 PM
08/28/13 10:30 PM
Posts: 85 Illinois
colt340
Illinois
On a stock RB block, who has done it?
Any links to the plugs? Ive been told they need to be a shallow plug to keep from bottoming on the cylinders?
1.25 npt tap?
Thanks for any help.
This is what I use on some of my blocks that have had issues... never had one of these come out... I put Permitex on it and tighten it up
Mr P what is the name of the company that makes the freeze plug with the nut in the center?
[Re: colt340]
#1490931
08/28/13 10:34 PM
08/28/13 10:34 PM
MR_P_BODY
1.25 npt tap?
I'll have to look tomorrow but its the standard company that makes most of them... I have posted the name and P/N in other post but I forget right now ![](/ubbthreads/images/graemlins/wave.gif)
[Re: Clanton]
#1490933
08/28/13 11:16 PM
08/28/13 11:16 PM
Posts: 22,734 Bitopia
jcc
Bitopia
My alum SB's are not pipe thread, not sure of thread size, use a standard thread with o ring plug.
[Re: jcc]
#1490934
08/28/13 11:26 PM
08/28/13 11:26 PM
MR_P_BODY
Thats what my alum sprint car block used ![](/ubbthreads/images/graemlins/wave.gif)
[Re: VernMotor]
#1490935
08/28/13 11:33 PM
08/28/13 11:33 PM
Posts: 17,926 Akron, Ohio
ProSport
Akron, Ohio
Bob I think I remember that . Norwalk ?
Yes Norwalk 2010.
[Re: colt340]
#1490937
08/29/13 12:56 AM
08/29/13 12:56 AM
Von
NE Oklahoma
The ones I ordered were Dorman. PN 02483
[Re: Von]
#1490938
08/29/13 10:06 PM
08/29/13 10:06 PM
Posts: 85 Illinois
colt340
Illinois
Thanks Von I will look into doorman.
