46rh is dead. It's ugly in there.
#1490119
08/25/13 02:32 AM
08/25/13 02:32 AM
Posts: 28,067 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
I dug into a friend's 46rh today. The 165,000 mile truck is a recent low-buck purchase that would not move in any gear. No unusual sounds. He pulled the transmission, drained it, and did a thorough cleaning before bringing it over. He said the pan was full of thick nasty stuff.
The first thing I noticed is that there is a heavy varnish on everything. The second thing was that the fluid was not red. In fact, it looked about like relatively clean engine oil. The fluid in the servos was slightly pinker than the rest. The fluid does not smell burned.
After tearing it down, I found no broken parts. Nothing was burned. A few of the bearings are worn as was the thrust bearing for the rear planetary. All the friction surfaces look serviceable. The filter, however, was absolutely disgusting. The bottom of the drums were caked with garbage. In fact, most things are caked with the stuff. There are signs of rust on many of the parts. The ends of the pinions for the planetary gears are especially nasty.
I did notice slight pitting on the gear and rotor for the pump. Those parts will be replaced.
He has had the converter rebuilt with an upgraded clutch and tighter pitch to better suit the stock Cummins.
Any idea what the culprit might have been? All I can think of is improper lube and a horribly clogged filter.
The fluid and varnish can be seen in this pic:
Re: 46rh is dead. It's ugly in there.
[Re: goldmember]
#1490122
08/25/13 03:25 AM
08/25/13 03:25 AM
feets
Senior Management
Senior Management
Irving, TX
All the cooler lines are getting a good flush after seeing the guts of this thing.
I suspected converter clutch failure due to the amount of gunk despite having good friction materials. However, I wasn't there when the rebuilder cut the converter open.
[Re: gdonovan]
#1490127
08/25/13 10:11 AM
08/25/13 10:11 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
HOw long had it been sitting without being moved?
Sounds like that's where the rust came from to me.
[Re: Supercuda]
#1490128
08/25/13 10:50 AM
08/25/13 10:50 AM
feets
Senior Management
Senior Management
Irving, TX
I think it sat for a while after the transmission quit. The front drum has minor surface rust on the band contact surface. You can see it in the attached pic.
All I did was tear the transmission down. I was not around when he dropped the pan and cleaned the outside of the transmission.
[Re: challengermike]
#1490129
08/25/13 12:10 PM
08/25/13 12:10 PM
Posts: 75,004 U.S.S.A.
JohnRR
U.S.S.A.
To me it looks like it just got hot from sitting and idling, Remember it doesn't pump in park and seeing it's a diesel it probably did that a lot. I would install a manual valve that make's pump in park, Many trans suppliers sell them.
Mike its a 46rh , they didn't put those behinds the Cummins , it's a gasser trans.
They do pump in park , but it's not the same volume like it does in neutral.
[Re: JohnRR]
#1490131
08/25/13 12:19 PM
08/25/13 12:19 PM
feets
Senior Management
Senior Management
Irving, TX
My FSM calls the trans a 46rh but it did come out of a Cummins.
[Re: feets]
#1490132
08/25/13 01:21 PM
08/25/13 01:21 PM
Posts: 10,847 Oakdale CT
gdonovan
Oakdale CT
46RH was used behind the small blocks, should be a 48RH.
The "8" indicates higher torque capacity.
[Re: gdonovan]
#1490133
08/25/13 01:34 PM
08/25/13 01:34 PM
feets
Senior Management
Senior Management
Irving, TX
Either way, it's not pretty. Unless it's fluid related I don't see any reason for the failure.
[Re: gdonovan]
#1490134
08/25/13 02:21 PM
08/25/13 02:21 PM
JohnRR
U.S.S.A.
47RH, I dodn't think they were 48 till the release of the HP common rail motors .
My bad and missing that this was behind a cummins .
[Re: dogdays]
#1490137
08/26/13 06:20 PM
08/26/13 06:20 PM
feets
Senior Management
Senior Management
Irving, TX
Getting that varnish out of there is going to be quite a chore. It's so thick that I had to fight the servos to get them apart after the snap rings were removed.
[Re: J_BODY]
#1490140
08/27/13 01:28 AM
08/27/13 01:28 AM
feets
Senior Management
Senior Management
Irving, TX
My raggedy old parts washer hasn't been used in 14 years. We resurrected it for this job. Greg (owner of the transmission) had an old 5 gallon can of kerosene that he donated to the cause. A good scrubbing got the planetary gear sets looking great. Now we need to do something about that valve body. I'm afraid to open the OD unit. Is the goo in the splines a good indication of what we're going to find or did the tight fit keep most of the solids out? Look at the servo spring in the background.
[Re: 360view]
#1490142
08/27/13 09:50 AM
08/27/13 09:50 AM
feets
Senior Management
Senior Management
Irving, TX
The kerosene is doing a fine job. It may take a little longer than other cleaners but it's a known entity with no hidden surprises.
We did find it a bit disturbing that the parts laying on the table actually stuck. Some of the snap rings had to be tapped sideways to break the bond. That servo spring in the second photo didn't want to be moved either. When pulled, it leaned over to the side before popping free.
It's just nasty.
[Re: feets]
#1490147
08/27/13 01:16 PM
08/27/13 01:16 PM
Posts: 1,168 Vancouver, WA
MoparMarq
Vancouver, WA
Is that damage on the front part of the drum? (Left side) What is that?
[Re: feets]
#1490150
08/27/13 03:20 PM
08/27/13 03:20 PM
Supercuda
About to go away
About to go away
up yours
One wonders if he's got a trans cooler that bypasses the radiator cooler.
[Re: John_Kunkel]
#1490152
08/28/13 01:18 AM
08/28/13 01:18 AM
feets
Senior Management
Senior Management
Irving, TX
This isn't fluid mixing. This is fluid abuse. Best we can figure is that a previous owner used crappy fluid and never changed it. I got the overdrive section disassembled in the press. After it was in pieces on the bench I had to pry the spring away from the other parts. It was glued together with this goo. The Berryman's stuff helped free up the planetary gears more than the kerosene. The OD planetary set will need serious attention before getting a bath. So, what do you think? Mission Impossible?
[Re: feets]
#1490155
08/29/13 10:36 AM
08/29/13 10:36 AM
feets
Senior Management
Senior Management
Irving, TX
The valve body makes a great repository for sticky nasty goo. We worked on it until 11 last night. The valve body pieces and front pump housing are the only things needing to be defunked. I gave him a key to the shop so he can get over there and mess with it while I'm at work. With luck it'll start going back together tomorrow.
