Re: 46rh is dead. It's ugly in there. [Re: feets] #1490139
08/27/13 12:16 AM
08/27/13 12:16 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
The heat exchanger can be cleaned out with some success, but the air to air cooler needs to be changed. I've seen some messed up trannys back in the day, but none with a complete varnishing like that! I'd bet that their was more than a couple "mechanic in a can" additives thrown in that.
Re: 46rh is dead. It's ugly in there. [Re: J_BODY] #1490140
08/27/13 01:28 AM
08/27/13 01:28 AM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
My raggedy old parts washer hasn't been used in 14 years. We resurrected it for this job. Greg (owner of the transmission) had an old 5 gallon can of kerosene that he donated to the cause.
A good scrubbing got the planetary gear sets looking great. Now we need to do something about that valve body.
I'm afraid to open the OD unit. Is the goo in the splines a good indication of what we're going to find or did the tight fit keep most of the solids out?
Look at the servo spring in the background.
- Stu Harmon
Re: 46rh is dead. It's ugly in there. [Re: dogdays] #1490141
08/27/13 09:42 AM
08/27/13 09:42 AM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
My memory is a bit fuzzy but i think i remember that about ten to fifteen years ago some automatic trans Diesel Ram owners were trying Mobil One Syn 5w-20 engine oil instead of ATF+2
I think the Diesel Trans forum in Canada had a number of posts on this
Perhaps some prior owner tried non synthetic 5w-20 engine oil in that 46/47 RH ?
Castrol Superclean is an impressive degreaser but one of the two formulations will attack aluminum if left on too long.
Grease Lightning detergent spray is also impressive on a few cruddy varnishes i have used it on, but be careful about breathing the vapor.
Re: 46rh is dead. It's ugly in there. [Re: 360view] #1490142
08/27/13 09:50 AM
08/27/13 09:50 AM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
The kerosene is doing a fine job. It may take a little longer than other cleaners but it's a known entity with no hidden surprises.
We did find it a bit disturbing that the parts laying on the table actually stuck. Some of the snap rings had to be tapped sideways to break the bond. That servo spring in the second photo didn't want to be moved either. When pulled, it leaned over to the side before popping free.
It's just nasty.
- Stu Harmon
Re: 46rh is dead. It's ugly in there. [Re: feets] #1490143
08/27/13 12:22 PM
08/27/13 12:22 PM
dogdays Offline
dogdays  Offline
Carb cleaner, the stuff in a spray can, plus a little rubbing, will get varnish off quicker.
R.
Re: 46rh is dead. It's ugly in there. [Re: dogdays] #1490144
08/27/13 12:53 PM
08/27/13 12:53 PM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
R.
He's bringing over a can of Berrymans to dip the smaller parts.
It's his transmission so he's supplying the stuff and doing the scrubbing. I'm supplying the place to do it and the assembly labor.
He can scrub to his heart's content.
He's a bit particular about things. With his obsessive background in chemistry and tight wallet I only make suggestions.
- Stu Harmon
Re: 46rh is dead. It's ugly in there. [Re: feets] #1490145
08/27/13 01:07 PM
08/27/13 01:07 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
The current Berrymans stuff in the paint can isn't as good as it used to be, he'll be better off with spray cans of gunk
Re: 46rh is dead. It's ugly in there. [Re: JohnRR] #1490146
08/27/13 01:16 PM
08/27/13 01:16 PM
McGregor,Iowa 52157
500ciDuster Offline
500ciDuster  Offline
McGregor,Iowa 52157
I've seen that sometimes in the older lockup convertor 3 speed trannys, they kinda had a weird oder but didn't smell burnt.
Mitch
Re: 46rh is dead. It's ugly in there. [Re: feets] #1490147
08/27/13 01:16 PM
08/27/13 01:16 PM
Vancouver, WA
MoparMarq Offline
MoparMarq  Offline
Vancouver, WA
Is that damage on the front part of the drum? (Left side) What is that?
Re: 46rh is dead. It's ugly in there. [Re: MoparMarq] #1490148
08/27/13 03:03 PM
08/27/13 03:03 PM
dogdays Offline
dogdays  Offline
Going back to my varnish post, the varnish in the oil is soft particulate that is much smaller than any clearance in the transmission. If transmission fluid got in there, the varnish is in there too. And if it's colder, it will have deposited a thicker layer.
In my experience the carb cleaner in a bucket is inferior to any cheap WalMart carb cleaner in a spray can, for cleaning varnish off the inside of a block or transmission. You'll see what works.
R.
Re: 46rh is dead. It's ugly in there. [Re: MoparMarq] #1490149
08/27/13 03:17 PM
08/27/13 03:17 PM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
Nope! No damage. That's goo. Thick sticky goo.
Look at the pics again. The parts had been sitting on the bench for more than 24 hours. Notice the lack of fluid dripping on the table?
There was a small bit that came out of the valve body but not as much as you'd expect.
- Stu Harmon
Re: 46rh is dead. It's ugly in there. [Re: feets] #1490150
08/27/13 03:20 PM
08/27/13 03:20 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
One wonders if he's got a trans cooler that bypasses the radiator cooler.
Don't be the exception.
Re: 46rh is dead. It's ugly in there. [Re: feets] #1490151
08/27/13 04:21 PM
08/27/13 04:21 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
That's the only thing that I've found that will really clean varnished parts. Hate the smell.
Re: 46rh is dead. It's ugly in there. [Re: John_Kunkel] #1490152
08/28/13 01:18 AM
08/28/13 01:18 AM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
This isn't fluid mixing. This is fluid abuse.
Best we can figure is that a previous owner used crappy fluid and never changed it.
I got the overdrive section disassembled in the press. After it was in pieces on the bench I had to pry the spring away from the other parts. It was glued together with this goo.
The Berryman's stuff helped free up the planetary gears more than the kerosene. The OD planetary set will need serious attention before getting a bath.
So, what do you think?
Mission Impossible?
- Stu Harmon
Re: 46rh is dead. It's ugly in there. [Re: feets] #1490153
08/28/13 02:46 AM
08/28/13 02:46 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
forget my last post.... replace BOTH COOLERS!!!
Re: 46rh is dead. It's ugly in there. [Re: J_BODY] #1490154
08/28/13 11:44 AM
08/28/13 11:44 AM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
No doubt!
- Stu Harmon
Re: 46rh is dead. It's ugly in there. [Re: feets] #1490155
08/29/13 10:36 AM
08/29/13 10:36 AM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
The valve body makes a great repository for sticky nasty goo.
We worked on it until 11 last night. The valve body pieces and front pump housing are the only things needing to be defunked. I gave him a key to the shop so he can get over there and mess with it while I'm at work.
With luck it'll start going back together tomorrow.
- Stu Harmon
Re: 46rh is dead. It's ugly in there. [Re: Supercuda] #1490156
08/29/13 01:19 PM
08/29/13 01:19 PM
Joplin, MO USA
Robbins Offline
Robbins  Offline
Joplin, MO USA
Wow, could that really be the problem? That thing looks like oil or something was put in it.
Moparlee
