Re: Cummins D350 project. What would YOU do? [Re: WO23Coronet] #1486219
08/20/13 12:25 AM
08/20/13 12:25 AM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
The 19.5 tires I posted come in at 85lbs. The aluminum 22.5s won't weight much really. the tires are heavy. The steelies with a tire are Heavy. picked obey off the side of the road and put it in the back of the truck. What a B@(%h
Re: Cummins D350 project. What would YOU do? [Re: 300by500] #1486220
08/20/13 09:19 AM
08/20/13 09:19 AM
Sparks, Nevada
MoparMike23 Offline
MoparMike23  Offline
Sparks, Nevada
i think crew cabs are the way to go......
1969 Superbee 440-6
1977 D-150 Adventurer
2000 Jeep TJ
2018 Challenger Scat Pack Shaker
2019 Ram 2500 CTD
Re: Cummins D350 project. What would YOU do? [Re: MoparMike23] #1486221
08/20/13 02:03 PM
08/20/13 02:03 PM
Bowling Green KY / Nashville, ...
300by500 Offline OP
300by500  Offline OP
OK.... I just found one of THESE. Not a nice one like in the pic, but a solid one with nice patina.
Re: Cummins D350 project. What would YOU do? [Re: 300by500] #1486222
08/20/13 02:06 PM
08/20/13 02:06 PM
300by500 Offline OP
300by500  Offline OP
Second pic. Too bad they put it on a Chevrolet frame....
Re: Cummins D350 project. What would YOU do? [Re: 300by500] #1486223
08/21/13 12:28 AM
08/21/13 12:28 AM
300by500 Offline OP
300by500  Offline OP
OK. This will be an adventure....
Re: Cummins D350 project. What would YOU do? [Re: 300by500] #1486224
08/21/13 01:08 PM
08/21/13 01:08 PM
Milwaukee, WI
Prince_Valiant Offline
Milwaukee, WI
I have always wanted to do one of those trucks up as a maximum "over-the-road" style truck, meaning, making it as quiet, comfortable, and nice for ubber-long road trips/etc. Maybe swapping to a 4 speed auto (that gen came w/ 3 speeds right?) as well...
To me it'd work better as a crew-cab, but aside from looking rough, you've got a decent truck to work with as it is...so it's simply personal preference/money that dictates the decision to me.
I do really like that black one above
1979 Dodge Lil' Red Express - 360 rwhp, 13.2 @ 103mph
1968 Coronet: 318, 2.76, 15.2 @ 92mph! (SOLD)
1976 Valiant: 360, 3.90, 12.90 @ 106 (SOLD)
1989 Shelby CSX #500/500
Re: Cummins D350 project. What would YOU do? [Re: Prince_Valiant] #1486225
08/21/13 01:17 PM
08/21/13 01:17 PM
Canada
CTD5.9 Offline
CTD5.9  Offline
Canada
I think 91.5-93 should be a 4 speed auto
Re: Cummins D350 project. What would YOU do? [Re: Prince_Valiant] #1486226
08/21/13 02:16 PM
08/21/13 02:16 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
If you weren't so fat away Id be interested in the cab if you decide to use the retrain elsewhere
Re: Cummins D350 project. What would YOU do? [Re: CTD5.9] #1486227
08/21/13 03:19 PM
08/21/13 03:19 PM
300by500 Offline OP
300by500  Offline OP
Yep. The intercooled versions came with OD.
Re: Cummins D350 project. What would YOU do? [Re: 76dodgeboy] #1486228
08/21/13 03:26 PM
08/21/13 03:26 PM
300by500 Offline OP
300by500  Offline OP
I will be parting out a lot of it, but first I want to use it to haul the C500 home. After that I'll be selling off what I don't need.
It'll be a month or two before I can drag the C500 home. In the meantime I'm going to get all of the mechanicals fixed up so everything is roadworthy.
Go figure... "rat rod it" got the fewest votes, and that's what I've decided to do. Should make an interesting tow piece!
Re: Cummins D350 project. What would YOU do? [Re: 300by500] #1486229
08/22/13 11:53 AM
08/22/13 11:53 AM
Coeur d Alene, Idaho
jimbob101 Offline
jimbob101  Offline
Put a 70s body on it!! : )
Re: Cummins D350 project. What would YOU do? [Re: jimbob101] #1486230
08/22/13 01:24 PM
08/22/13 01:24 PM
300by500 Offline OP
300by500  Offline OP
That truck looks great, Jimbob!
As for this one, I'm putting the 1963 C500 body on it. I want it to look similar to the green / white one in the pic, but I plan on leaving the paint as-is if possible, just a few touch ups, a light scuff, and some satin clear.
I'm not going to put a utility bed on it like the one in the pic. I want a long stepside bed painted/ aged to match the cab with big fenders on it, so I'll have to come up with something. I'd rather leave the wheelbase right where it is for a better ride and towing, so it'll be a loooong bed. I want mine to have a little more forward rake as well, but the tire / wheel combo should take care of that.
Re: Cummins D350 project. What would YOU do? [Re: 300by500] #1486231
08/22/13 01:27 PM
08/22/13 01:27 PM
300by500 Offline OP
300by500  Offline OP
The inspiration came from this '54 IH fire truck I saw on ebay a while back. I like the long look with the big/little rollers - so I want to run 16 inch wheels up front and matching 22.5s in the rear; either stockers up front with big steel Budds painted shiny the same color as the truck, or matching big / little 10-hole Alcoas like on the fire truck. The bed will need to be higher to cover the rear wheels, but mine wont be sitting on the ground like the IH, so it should work.
Re: Cummins D350 project. What would YOU do? [Re: 300by500] #1486232
08/22/13 01:30 PM
08/22/13 01:30 PM
300by500 Offline OP
300by500  Offline OP
The plan is to use it as a daily driver with tools and parts on board to service my small delivery truck fleet, and occasional use towing my cars around. With that in mind, I'll try to keep the running gear / chassis as original as possible... basically a funny-looking stock '92 D350.
She sure doesn't look like much right now....
Re: Cummins D350 project. What would YOU do? [Re: 300by500] #1486233
08/22/13 01:34 PM
08/22/13 01:34 PM
300by500 Offline OP
300by500  Offline OP
The best part is that once I sell or scrap everything I'm not using, the '63 stuff will basically be FREE!
Re: Cummins D350 project. What would YOU do? [Re: 300by500] #1486234
08/22/13 02:41 PM
08/22/13 02:41 PM
CA, Proprietor; The "PALOMINO"...
dynotune440 Offline
dynotune440  Offline
thats going to be sweet!!!
Dinuba, California, Home of the PALOMINO ranch and 440 truck farm, where dodge trucks have a home. Have Four 1979 dodge PALOMINO trucks now.
Re: Cummins D350 project. What would YOU do? [Re: dynotune440] #1486235
08/22/13 03:11 PM
08/22/13 03:11 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
See now you can do the 22.5 conversion
Re: Cummins D350 project. What would YOU do? [Re: 300by500] #1486236
08/22/13 09:08 PM
08/22/13 09:08 PM
Chicagoland
Cooter Offline
Cooter  Offline
Chicagoland
So you're the one who bought that one! I wanted it bad, but timing wasn't right.
Re: Cummins D350 project. What would YOU do? [Re: Cooter] #1486237
08/25/13 12:27 AM
08/25/13 12:27 AM
SD
Z
zrxkawboy Offline
zrxkawboy  Offline
Z
SD
Cool project. Keep us updated!
It's Swifty! Swifty, you toad sucker!
Re: Cummins D350 project. What would YOU do? [Re: zrxkawboy] #1486238
08/25/13 04:23 PM
08/25/13 04:23 PM
300by500 Offline OP
300by500  Offline OP
