Power Steering Pump help needed! #1483809
08/13/13 11:03 AM
08/13/13 11:03 AM
Seaford Delaware
JSR1485 Offline OP
JSR1485  Offline OP
Seaford Delaware
I have a Stage 3 Firm Feel box in my Duster and I am using a Saginaw pump, I am on my third pump! They are all bleed correctly , I get no noise or steering problems like binding at all. All the pumps start to leak after use. When I take them apart the seals are all torn?
Any idea? Too much internal pump pressure? getting to hot? I am about at a loss at this point.
Switched to the dark side...
Re: Power Steering Pump help needed! [Re: JSR1485] #1483810
08/13/13 11:27 AM
08/13/13 11:27 AM
NW Chicago suburban area
Mopar Mitch Offline
Mopar Mitch  Offline
JS -- nice ride! Consider changing ps pump brand suppliers?... different store??
Re: Power Steering Pump help needed! [Re: Mopar Mitch] #1483811
08/13/13 11:43 AM
08/13/13 11:43 AM
Seaford Delaware
JSR1485 Offline OP
JSR1485  Offline OP
Seaford Delaware
I just got another one , I am going try one from Rock Auto.
If this one fails , I guess I have no choice but to buy a KRC set up
http://www.krcpower.com/ecommerce/comple...tor-bracket.asp
Re: Power Steering Pump help needed! [Re: JSR1485] #1483812
08/13/13 12:33 PM
08/13/13 12:33 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
You don't have to go full on KRC, I'm using a circle track pump with a mounted reservoir,CV?, $200 shipped off eBay with a sh chev head mount and a couple homemade brackets.
Mopar to the bone!!!
Re: Power Steering Pump help needed! [Re: 72Swinger] #1483813
08/13/13 01:12 PM
08/13/13 01:12 PM
Seaford Delaware
JSR1485 Offline OP
JSR1485  Offline OP
Seaford Delaware
72swinger I would like to see pictures of that
Re: Power Steering Pump help needed! [Re: JSR1485] #1483814
08/13/13 01:59 PM
08/13/13 01:59 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Here it is on my BB.
Re: Power Steering Pump help needed! [Re: 72Swinger] #1483815
08/13/13 02:31 PM
08/13/13 02:31 PM
Seaford Delaware
JSR1485 Offline OP
JSR1485  Offline OP
Seaford Delaware
Thanks that is very cool setup!
Re: Power Steering Pump help needed! [Re: JSR1485] #1483816
08/13/13 05:47 PM
08/13/13 05:47 PM
So Cal
autoxcuda Online content
autoxcuda  Online Content
So Cal
Reseal the pump yourself. The kit is like $15-20. The rebuild kit just come with a replacement bronze plain bushing/bearing that presses in. Then you can inspect the vanes and guts. Vanes don't really go bad unless you completely blow it and parts scatter all over the inside.
Inspect the surface on the can were it seals to the large O-ring. Rust or dents can cause leakage.
Re: Power Steering Pump help needed! [Re: autoxcuda] #1483817
08/13/13 07:59 PM
08/13/13 07:59 PM
IN
ahy Offline
ahy  Offline
IN
FF rebuilt my Saginaw pump. It was a premium over a parts store but has been trouble free. That said, I haven't heard of widespread problems with parts store pumps. I've used them without problem on other projects.
I wonder if there are any other problems? Signs of debris, kink in the return line, heating/foaming ect?
Re: Power Steering Pump help needed! [Re: ahy] #1483818
08/13/13 10:03 PM
08/13/13 10:03 PM
Seaford Delaware
JSR1485 Offline OP
JSR1485  Offline OP
Seaford Delaware
There has been no other problems-no foaming , no kink in any lines.
The first pump I did my self and it was fine for a very short problem, then the front O-ring blew out and I found the can was out of round, next I picked up a Mopar NOS pump and can and that blew out the rear O rings that seal it to the can and now I picked up a complete pump from Rock Auto.
The only thing I can up with is either the fluid eating the O-rings
I have too much internal pump pressure or it is getting hot and boiling the fluid.
It is more than a drip, when I come back from driving it the K-Frame is dripping with oil
Re: Power Steering Pump help needed! [Re: JSR1485] #1483819
08/13/13 11:10 PM
08/13/13 11:10 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
Before installing a new pump..
Be sure to purge the lines to get all the scraps out..
Just my $0.02...
Re: Power Steering Pump help needed! [Re: Sinitro] #1483820
08/14/13 12:05 AM
08/14/13 12:05 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Are these all with a new pressure relief valve as well?
Re: Power Steering Pump help needed! [Re: 72Swinger] #1483821
08/14/13 10:42 AM
08/14/13 10:42 AM
Seaford Delaware
JSR1485 Offline OP
JSR1485  Offline OP
Seaford Delaware
Yes all new valves , new lines and the box is brand new.
I have being some research and the fluid I was using was what they call TOP OFF fluid and has stop leak in it and I think it might have been making the seals & o rings soft. So this time I am using regular factory power steering fluid.
Re: Power Steering Pump help needed! [Re: JSR1485] #1483822
08/14/13 08:48 PM
08/14/13 08:48 PM
IN
ahy Offline
ahy  Offline
IN
Good idea. The older grates of ATF (Dexron, type F) work fine in the PS pump also. On the debris, NAPA and probably others have an in line filter for the return line. It may be worth running one for a while until you are sure any bits of seal have been captured.
Re: Power Steering Pump help needed! [Re: ahy] #1483823
08/17/13 07:14 PM
08/17/13 07:14 PM
Seaford Delaware
JSR1485 Offline OP
JSR1485  Offline OP
Seaford Delaware
This pump has no leaks I put Lucas power steering fluid in and got a new cap also seems to be 100%
Re: Power Steering Pump help needed! [Re: JSR1485] #1483824
08/22/13 10:07 PM
08/22/13 10:07 PM
Indiana, Just Off I-70
BradD Offline
BradD  Offline
I put the driveline in a friend/customers 66 Charger. 383/edelbrock EFI/833 4SPD./Paxton Novi 1500/Doug's Headers/TTI Exh./Chrome Saginaw pump. I burnt up 2 pumps before I remembered the Saginaw has to have the larger fitting into the steering gearbox. And you have to use the proper size pressure hose to the box. The car originally had a Mopar/TRW pump which uses the 3/16" hose and fitting whereas the saginaw uses 1/4". The smaller hose and fitting used with the saginaw pump creates higher pressure and heat which burns the pump. I put the correct parts on and all is fine.
Check out the Dorn's 69 Barracuda "Switchblade" in the Nov.2010 MCG
Check out the Dorn's refurbished 36 Ford in the Feb.2011 Street Rodder
Re: Power Steering Pump help needed! [Re: JSR1485] #1483825
08/22/13 11:55 PM
08/22/13 11:55 PM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
I used a slightly different oval track set up, I think mine is a Sweet Mfg pump (exact company slips my mind right now) with divorced tank. I may add a cooler in the near future.
Old pick from my '67 after we pulled the engine.
Re: Power Steering Pump help needed! [Re: BradD] #1483826
08/23/13 10:13 AM
08/23/13 10:13 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Interesting, I swapped Saginaw pumps into both my 64 300 and my 72 Swinger, reused the existing hoses. Never burned anything up.
Don't be the exception.
Re: Power Steering Pump help needed! [Re: Supercuda] #1483827
08/23/13 12:25 PM
08/23/13 12:25 PM
Nevada
dezduster Offline
dezduster  Offline
Nevada
I hope you are not using Lucas stop leak in your pump, as this will foam up badly causing possible problems you are experiencing.
Does the firm feel box use smaller piston or reduce pressure? If it's reduction in psi, at higher rpms you could be bypassing in the pump always heating the fluid badly and creating high internal pressures.
Possible solutions would be larger pump pulley our smaller crank pulley. If your new pump starts to have issues that is.
Re: Power Steering Pump help needed! [Re: dezduster] #1483828
08/29/13 11:25 PM
08/29/13 11:25 PM
Montreal PQ, Canada
74_360_Cuda Offline
74_360_Cuda  Offline
Montreal PQ, Canada
I have the same problem, brand new chrome pump from Tuff Stuff, brand new steering box from Borgeson, New Hoses with proper diameter, Pump is leaking but not from the hoses, suspect overheating although I have the March pulley kit that I think is under drive (1.2 ratio).
I have done some research and I am suspecting my new pump with key way pulley shaft has more flow and generate too much heat but I don't have proof since nobody publish the flow of their pumps. The can/reservoir is also probably too small. I might consider a remote reservoir & a cooler but If I could just find a pump with a key way pulley shaft but with less flow I would be very happy.
I have also noticed that the OEM hoses had a weird loop in metal tubing going up and down right after the pump and I am now wondering if this was not some kind of OEM cooler... My custom hoses don't have that metal loop.
