Power Steering Pump help needed!
#1483809
08/13/13 11:03 AM
08/13/13 11:03 AM
Posts: 1,123 Seaford Delaware
JSR1485
Seaford Delaware
I have a Stage 3 Firm Feel box in my Duster and I am using a Saginaw pump, I am on my third pump! They are all bleed correctly , I get no noise or steering problems like binding at all. All the pumps start to leak after use. When I take them apart the seals are all torn? Any idea? Too much internal pump pressure? getting to hot? I am about at a loss at this point.
Switched to the dark side...
Re: Power Steering Pump help needed!
[Re: JSR1485]
#1483810
08/13/13 11:27 AM
08/13/13 11:27 AM
Posts: 1,442 NW Chicago suburban area
Mopar Mitch
JS -- nice ride! Consider changing ps pump brand suppliers?... different store??
Mopar Mitch
"Road racers and autocrossers go in deeper and come out harder!"... and rain never stops us from having fun with our cars... in fact, it makes us better drivers!
Check out MOPAR ACTION MAGAZINE, August 2006 issue for feature article and specs on my autocross T/A!
[Re: JSR1485]
#1483812
08/13/13 12:33 PM
08/13/13 12:33 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
You don't have to go full on KRC, I'm using a circle track pump with a mounted reservoir,CV?, $200 shipped off eBay with a sh chev head mount and a couple homemade brackets.
Mopar to the bone!!!
[Re: ahy]
#1483818
08/13/13 10:03 PM
08/13/13 10:03 PM
JSR1485
Seaford Delaware
There has been no other problems-no foaming , no kink in any lines. The first pump I did my self and it was fine for a very short problem, then the front O-ring blew out and I found the can was out of round, next I picked up a Mopar NOS pump and can and that blew out the rear O rings that seal it to the can and now I picked up a complete pump from Rock Auto. The only thing I can up with is either the fluid eating the O-rings I have too much internal pump pressure or it is getting hot and boiling the fluid. It is more than a drip, when I come back from driving it the K-Frame is dripping with oil
[Re: JSR1485]
#1483819
08/13/13 11:10 PM
08/13/13 11:10 PM
Posts: 5,445 So Cal
Sinitro
So Cal
Before installing a new pump.. Be sure to purge the lines to get all the scraps out.. Just my $0.02...
[Re: Sinitro]
#1483820
08/14/13 12:05 AM
08/14/13 12:05 AM
72Swinger
Nebraska
Are these all with a new pressure relief valve as well?
[Re: 72Swinger]
#1483821
08/14/13 10:42 AM
08/14/13 10:42 AM
JSR1485
Seaford Delaware
Yes all new valves , new lines and the box is brand new. I have being some research and the fluid I was using was what they call TOP OFF fluid and has stop leak in it and I think it might have been making the seals & o rings soft. So this time I am using regular factory power steering fluid.
[Re: JSR1485]
#1483822
08/14/13 08:48 PM
08/14/13 08:48 PM
Posts: 7,664 IN
ahy
IN
Good idea. The older grates of ATF (Dexron, type F) work fine in the PS pump also. On the debris, NAPA and probably others have an in line filter for the return line. It may be worth running one for a while until you are sure any bits of seal have been captured.
[Re: ahy]
#1483823
08/17/13 07:14 PM
08/17/13 07:14 PM
JSR1485
Seaford Delaware
This pump has no leaks I put Lucas power steering fluid in and got a new cap also seems to be 100%
[Re: JSR1485]
#1483824
08/22/13 10:07 PM
08/22/13 10:07 PM
Posts: 543 Indiana, Just Off I-70
BradD
I put the driveline in a friend/customers 66 Charger. 383/edelbrock EFI/833 4SPD./Paxton Novi 1500/Doug's Headers/TTI Exh./Chrome Saginaw pump. I burnt up 2 pumps before I remembered the Saginaw has to have the larger fitting into the steering gearbox. And you have to use the proper size pressure hose to the box. The car originally had a Mopar/TRW pump which uses the 3/16" hose and fitting whereas the saginaw uses 1/4". The smaller hose and fitting used with the saginaw pump creates higher pressure and heat which burns the pump. I put the correct parts on and all is fine.
Check out the Dorn's 69 Barracuda "Switchblade" in the Nov.2010 MCG Check out the Dorn's refurbished 36 Ford in the Feb.2011 Street Rodder
