Dodge/Ram Techs Some Help Please (Long) #1482450
08/10/13 06:15 PM
08/10/13 06:15 PM
Lakewood, Colorado
runnerrt Offline OP
runnerrt  Offline OP
Lakewood, Colorado
Any Dodge or Ram techs I need some help please. I was driving my 2004 Ram 2500 with 5.7 hemi to go to one of the Mopar clubs car shows today (I call it the to broke to go to the Nats show) and stopped for a stop light. Upon accelerating when the light turned green my truck died, as I was costing to the shoulder I noticed the ETC light flashing. I tried to restart and nothing but I noticed all of my gauges were down to zero except the volt gauge which was higher than normal then it to would drop to nothing and the outside temp was showing -40 when it is really about 80. Called for a tow to get it to the shop I work at. Hooked my scan tool up to find 12 codes 5 of which were pending. Most of which are showing circuit high input for 5 different sensors, and some crazy things in the freeze frame data such as ECT at -40, spark advance at -64, IAT at -64 TPS 100% and Vehicle speed at 158 mph. I am a Ford diesel tech, and my friend who works at Dodge is out of town. Any input /ideas would be appreciated. As much as I lke driving my Super Bee, I do not want to drive it to work every day until he gets back. Thanks
1969 Super Bee High School car I got back 2004 Ram 2500
Re: Dodge/Ram Techs Some Help Please (Long) [Re: runnerrt] #1482451
08/10/13 06:25 PM
08/10/13 06:25 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Before you do anything unhook the battery for about 5 minutes. Then hook it back up and see if it starts. I had a controller lock up and do that. On some if you just power it down for a few minutes and wake everything up it would then work normal and no other problems were found. I had a couple like that where Chrysler tech line told me to just let them go and dont replace anything. I will say none of them came back. Ron
Re: Dodge/Ram Techs Some Help Please (Long) [Re: 383man] #1482452
08/10/13 06:27 PM
08/10/13 06:27 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Check the battery charge. A bad battery will drive these computer vehicles crazy.
Re: Dodge/Ram Techs Some Help Please (Long) [Re: 383man] #1482453
08/10/13 07:36 PM
08/10/13 07:36 PM
Lakewood, Colorado
runnerrt Offline OP
runnerrt  Offline OP
Lakewood, Colorado
No luck the only change is now the engine light flashes with the key on.
Re: Dodge/Ram Techs Some Help Please (Long) [Re: stumpy] #1482454
08/10/13 07:37 PM
08/10/13 07:37 PM
Lakewood, Colorado
runnerrt Offline OP
runnerrt  Offline OP
Lakewood, Colorado
The battery was down some from sitting waiting on a tow for 2 hours but charged now, still nothing.
Re: Dodge/Ram Techs Some Help Please (Long) [Re: runnerrt] #1482455
08/11/13 01:57 PM
08/11/13 01:57 PM
Lakewood, Colorado
runnerrt Offline OP
runnerrt  Offline OP
Lakewood, Colorado
Any other ideas?
Re: Dodge/Ram Techs Some Help Please (Long) [Re: runnerrt] #1482456
08/11/13 05:49 PM
08/11/13 05:49 PM
Littleton Colo
Geezer Offline
Geezer  Offline
Littleton Colo
If it is the factory original battery I would switch in a known good battery.Had 2004 and 2007 Jeeps at 2 years old batterys internally shorted but tested good and they caused strange symptoms.
Re: Dodge/Ram Techs Some Help Please (Long) [Re: runnerrt] #1482457
08/11/13 10:58 PM
08/11/13 10:58 PM
Ohio
Todd Offline
Todd  Offline
Ohio
Any other ideas?
What codes does it have now after the battery disconnect?
Re: Dodge/Ram Techs Some Help Please (Long) [Re: Todd] #1482458
08/11/13 11:07 PM
08/11/13 11:07 PM
IL,USA
bdusted440 Offline
bdusted440  Offline
IL,USA
etc light is the throttle body and when they puke that's the codes you get.The power and ground for several components run in series on newer trucks.
currently own
1976 duster deluxe
1974 gold duster
1993 Dakota sport
2000 caravan
2002 Durango
1970 v code superbee
Re: Dodge/Ram Techs Some Help Please (Long) [Re: Todd] #1482459
08/11/13 11:42 PM
08/11/13 11:42 PM
Lakewood, Colorado
runnerrt Offline OP
runnerrt  Offline OP
Lakewood, Colorado
I will pull them in the morning.
Re: Dodge/Ram Techs Some Help Please (Long) [Re: bdusted440] #1482460
08/11/13 11:46 PM
08/11/13 11:46 PM
Lakewood, Colorado
runnerrt Offline OP
runnerrt  Offline OP
Lakewood, Colorado
This seems to make sense, any way to test if this is it ?
Re: Dodge/Ram Techs Some Help Please (Long) [Re: Todd] #1482461
08/12/13 09:34 AM
08/12/13 09:34 AM
Lakewood, Colorado
runnerrt Offline OP
runnerrt  Offline OP
Lakewood, Colorado
The codes are
P0073 Ambient temp sensor circuit high input
P0113 Intake air sensor 1 circuit high input
P0118 Engine coolant temp circuit high input
P0443 Evap Control circuit
P0463 fuel level sensor A high input
P0700 Trans control system
P0891 TCM power relay sense circuit high input
Re: Dodge/Ram Techs Some Help Please (Long) [Re: runnerrt] #1482462
08/12/13 01:42 PM
08/12/13 01:42 PM
Southern Oklahoma
wildman340 Offline
wildman340  Offline
Southern Oklahoma
Time for a new battery.
1974 Dodge Dart Sport 340 4 Spd Endless Project 1999 Ram 1500 CC 5.2 5 speed
Re: Dodge/Ram Techs Some Help Please (Long) [Re: wildman340] #1482463
08/12/13 02:34 PM
08/12/13 02:34 PM
Lakewood, Colorado
runnerrt Offline OP
runnerrt  Offline OP
Lakewood, Colorado
To all the advice on a new battery it is definitly not a battery, just swapped a new full charged battery and it is the same. Live data shows ambient, coolant and intake air all at -40, tps at 100%, spark advance at -64 and not showing a RPM signal when cranking.
Re: Dodge/Ram Techs Some Help Please (Long) [Re: runnerrt] #1482464
08/12/13 04:28 PM
08/12/13 04:28 PM
Ohio
Todd Offline
Todd  Offline
Ohio
Unplug the crank sensor and see if the affected sensors start reading right. Have had those in the past short out and cause all kind of no start and no communication issues.
If that's not it start unplugging one 5v sensor at a time and go from there.
Does your scanner comm over the PCI bus or generic bus?
Re: Dodge/Ram Techs Some Help Please (Long) [Re: Todd] #1482465
08/12/13 06:49 PM
08/12/13 06:49 PM
Lakewood, Colorado
runnerrt Offline OP
runnerrt  Offline OP
Lakewood, Colorado
I have unplugged all of the effected sensors and the crank sensor,with no change. I am going to try the cam sensor in a little while any others I should try? I am going to say it is the generic bus as it is just a cheapo scanner
Re: Dodge/Ram Techs Some Help Please (Long) [Re: runnerrt] #1482466
08/12/13 08:39 PM
08/12/13 08:39 PM
Lakewood, Colorado
runnerrt Offline OP
runnerrt  Offline OP
Lakewood, Colorado
Ok, I borrowed a friends good scanner and with it it brought up even more codes, they are as follows
P2016 ETC force limited power
P2111 ETC stuck open
P060B ETC A/D ground performance
P2167 APP sensor 2 max stop performance
P2116 APP sensor 2 min stop performance
P2128 APP sensor 2 circuit hi
P2123 APP sensor 1 circuit hi
On data it shows throttle position at 133% but the blade is closed.
Re: Dodge/Ram Techs Some Help Please (Long) [Re: runnerrt] #1482467
08/12/13 09:56 PM
08/12/13 09:56 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
For the Voltage high codes I would say check the grounds real close but you may have set them yourself if you unpluged the sensors or left them unplugged with the key on. The codes you said it now hs are all related to the Electronic throttle body. Make sure the throttle body has a good ground. It is nice if you have the wiring schematic so you will know which is a ground. Usually high voltage readings are a bad ground of some type. Low voltge readins can be from a shorted sensor but it does not sound like thats your problem. You may end up replacing the throttle body. Ron
Re: Dodge/Ram Techs Some Help Please (Long) [Re: bdusted440] #1482468
08/12/13 11:00 PM
08/12/13 11:00 PM
Sobieski Wi
bee1971 Online work
bee1971  Online Work
Sobieski Wi
Mine was replaced twice under warranty - Owned the truck (2004 Hemi Sport) for seven years , only had 35,000 miles on it when I traded it in on my 2011 - Throttle Bodies and the same O2 Sensor twice was the only issue I ever had on that truck
First was a known TSB on the throttle body - I cant remember the second off hand
http://dodgeram.info/tsb/2005/14-002-05.htm
1971 Dodge Charger Superbee
2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded
Siberian Huskies
Re: Dodge/Ram Techs Some Help Please (Long) [Re: 383man] #1482469
08/13/13 01:04 PM
08/13/13 01:04 PM
Lakewood, Colorado
runnerrt Offline OP
runnerrt  Offline OP
Lakewood, Colorado
The grounds all look good, I have a FSM I bought on CD years ago for my old truck but it does not show how to test the throttle body. I don't mind replacing it as long as I know its bad. How would I test it ?
