Spool from 489 rear to 742 #1479671
08/04/13 08:42 PM
08/04/13 08:42 PM
Bristol, Va
fasteddie Offline OP
Bristol, Va
Did a search. No help. Can a Strange spool in a 489 housing be used in a 742 housing?
Fasteddie
Re: Spool from 489 rear to 742 [Re: fasteddie] #1479672
08/04/13 08:47 PM
08/04/13 08:47 PM
Way North Idaho
1KoolBee Offline
1KoolBee  Offline
Way North Idaho
It should, I know the early and late Sure-Grips interchange.
'68 Bee 383/TF/Factory Air...high school sweetheart
'67 GTX Clone project,500 six pack,Hemi4-speed,Dana
05 Dodge Viper, 505 V-10, 6-speed Tremec
Re: Spool from 489 rear to 742 [Re: fasteddie] #1479673
08/04/13 08:48 PM
08/04/13 08:48 PM
Locomotion Offline
Locomotion  Offline
Yes, spools and the spool bearings interchange. Just the pinions and their bearings are different along with yoke spline being either way (fine/course) on any of them..
Re: Spool from 489 rear to 742 [Re: Locomotion] #1479674
08/05/13 12:27 AM
08/05/13 12:27 AM
Cab_Burge Online work
Cab_Burge  Online Work
You have to use the carrier bearings and races for the 489 carriers on the spool That makes it fit in all three cases, been there done that personnally on all three cases, 741,742 and the 489
Re: Spool from 489 rear to 742 [Re: Cab_Burge] #1479675
08/05/13 07:06 AM
08/05/13 07:06 AM
Mo.
racerx Offline
racerx  Offline
Mo.
Cab:what bount the inner bearing on the pinion?do that inner change with a carrier bearing/or should i ask if the inner bearing the same on all three pinions(741,742,489)Thax.....
Re: Spool from 489 rear to 742 [Re: racerx] #1479676
08/05/13 11:05 AM
08/05/13 11:05 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
If you are asking about the pinion bearing that is under the head of the gear then no that is different between the 3 different cases .
Re: Spool from 489 rear to 742 [Re: racerx] #1479677
08/05/13 02:41 PM
08/05/13 02:41 PM
The pinion bearings, both,front and raer, need to match the cases, not the spool or carier unit
Re: Spool from 489 rear to 742 [Re: fasteddie] #1479678
08/07/13 08:53 PM
08/07/13 08:53 PM
Bristol, Va
Bristol, Va
Thanks all. I thought it would fit but wanted to ask before I took it apart.
2003 Bristol Dragway Sportsman Champion
2016 Bristol Dragway Power Hour Champion
