Re: Spool from 489 rear to 742
[Re: fasteddie]
#1479672
08/04/13 08:47 PM
08/04/13 08:47 PM
Posts: 257 Way North Idaho
1KoolBee
Way North Idaho
It should, I know the early and late Sure-Grips interchange.
'68 Bee 383/TF/Factory Air...high school sweetheart '67 GTX Clone project,500 six pack,Hemi4-speed,Dana 05 Dodge Viper, 505 V-10, 6-speed Tremec
[Re: Cab_Burge]
#1479675
08/05/13 07:06 AM
08/05/13 07:06 AM
Posts: 4,070 Mo.
racerx
Mo.
Yes, spools and the spool bearings interchange. Just the pinions and their bearings are different along with yoke spline being either way (fine/course) on any of them..
You have to use the carrier bearings and races for the 489 carriers on the spool That makes it fit in all three cases, been there done that personnally on all three cases, 741,742 and the 489
Cab:what bount the inner bearing on the pinion?do that inner change with a carrier bearing/or should i ask if the inner bearing the same on all three pinions(741,742,489)Thax.....
[Re: racerx]
#1479676
08/05/13 11:05 AM
08/05/13 11:05 AM
Posts: 75,020 U.S.S.A.
JohnRR
U.S.S.A.
If you are asking about the pinion bearing that is under the head of the gear then no that is different between the 3 different cases .
[Re: fasteddie]
#1479678
08/07/13 08:53 PM
08/07/13 08:53 PM
Posts: 549 Bristol, Va
fasteddie
Bristol, Va
Thanks all. I thought it would fit but wanted to ask before I took it apart.
2003 Bristol Dragway Sportsman Champion
2016 Bristol Dragway Power Hour Champion
