Page 1 of 3 1 2 3
Vacuum advance or not??? #1476774
07/31/13 01:44 AM
07/31/13 01:44 AM
Way North Idaho
1KoolBee Offline OP
1KoolBee  Offline OP
Way North Idaho
First off thanks to all who have helped me with my engine build so far. Its coming together slowly, but I'm almost there. Trying to decide if there is a benefit to running a vacuum advance on my street/strip motor. Its 500 cubes, 11.2 static compression, MP .557 cam, 1.6 rockers, Eddie Heads, sixpack induction, 4-speed trans. should I stick to straight mechanical advance, or is there a good reason to keep vacuum advance?
'68 Bee 383/TF/Factory Air...high school sweetheart
'67 GTX Clone project,500 six pack,Hemi4-speed,Dana
05 Dodge Viper, 505 V-10, 6-speed Tremec
Re: Vacuum advance or not??? [Re: 1KoolBee] #1476775
07/31/13 04:54 AM
07/31/13 04:54 AM
sweden
sshemi Offline
sshemi  Offline
sweden
Only reason for vac advance is a little better milage.
But then the carb have to be calibrated for vac advance.
Re: Vacuum advance or not??? [Re: 1KoolBee] #1476776
07/31/13 07:37 AM
07/31/13 07:37 AM
Andrews,In. U.S.of A.
67_Satellite Offline
What fuel? At that compression probably better than standard pump swill. If it doesn't ping, run it to manifold vacuum.It will give you the extra timing for a better idle/mileage and automatically goes away under heavy/full throttle.
Re: Vacuum advance or not??? [Re: 67_Satellite] #1476777
07/31/13 08:39 AM
07/31/13 08:39 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
my build is close to the OP, even the 11.2:1, I run 38* all in by 2200 and NO vac advance. But I also run meth/H2O injection to reduce detonation. A tad OT but how do yo uhave the 6-pack set-up?
Coming soon!!!!
Re: Vacuum advance or not??? [Re: 1KoolBee] #1476778
07/31/13 08:50 AM
07/31/13 08:50 AM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Absolutely not...Too inconsistant...And as for mileage. I did a test on one of my street/strip vehicles, and I think that is a wives tale. If you have a cam more geared for racing than stock, it will never happen.
On mine I did the mileage check back to back one week with a distributer without vacuum advance, and the next week a distributer with vacuum advance. If I saw .4mpg difference it was a lot....Since it had a small 11g tank, and my drive to work is almost 30 miles I typically put fuel in it every day and checked the mileage...11mpg without, 11.4 with it...and it didn't always get the extra mileage...yippy....less then 1/2mpg on one of the five days, saving the world now. It even ran better without it.
Re: Vacuum advance or not??? [Re: Dragula] #1476779
07/31/13 10:01 AM
07/31/13 10:01 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
FWIW if you are building a 440 w/ milage in mind you should have your head checked..... I can tell you w/ the 6-pack you'll do fine. I avg almost 15mpg to and from the track. Back roads, constant 45-50mph 727, 3.91's Now once you stand on it and the ouboards open that changes drastically... but in a good way.
Re: Vacuum advance or not??? [Re: 1KoolBee] #1476780
07/31/13 10:51 AM
07/31/13 10:51 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
... is there a good reason to keep vacuum advance?
Yes, but the carb & distirbutor have to be tuned to work together to see the benefits.
A typical factory vacuum advance setup and standard "quick" mechanical ignition curve are generally a recipe for over-advancing a performance engine under high vacuum conditions.
Done right, better idle and fuel consumption. Done wrong, detonation from too much ignition lead under part-throttle use.
Even on my Challenger (mid-10 second street/strip car), if I could find a good distributor w/ fully tuneable vacuum advance (amount of advance x vacuum level) & mechanical curves, I'd like to run one. I think there's something out there that would work, the new Crane electronic distributors, but they're not cheap.
Re: Vacuum advance or not??? [Re: 1KoolBee] #1476781
07/31/13 10:59 AM
07/31/13 10:59 AM
Az
Crizila Offline
Crizila  Offline
Az
Your set up leans more to race than street operation so it's a tough call. If you are going to drive a lot of street miles, it might save you a little in fuel costs to use it. With that cam, you would want to run ported vacuum for idle stability and you would probably have to recurve the distributor accordingly.
Fastest 300
Re: Vacuum advance or not??? [Re: Crizila] #1476782
07/31/13 02:55 PM
07/31/13 02:55 PM
sweden
sshemi Offline
sshemi  Offline
sweden
Dist and carb should be calibrated for it.
Lean mixtures burn slower so the benfit is to lean the carb at highway speed (too lean without vac) and with the increased timing ot should run with better milage.
Re: Vacuum advance or not??? [Re: 1KoolBee] #1476783
07/31/13 03:20 PM
07/31/13 03:20 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I don`t like variable timing on anything not stock and my dist. is locked out and starts fine even at 12.1.1 comp. Call me I`m close and can help you out..........760-900-3895........
Re: Vacuum advance or not??? [Re: Thumperdart] #1476784
07/31/13 09:47 PM
07/31/13 09:47 PM
...gently down the stream
LAR_414 Offline
LAR_414  Offline
Do it.
15.5 mpg here. 11 sec 34 degr mech and 50 with vacuum.
Re: Vacuum advance or not??? [Re: BradH] #1476785
07/31/13 10:01 PM
07/31/13 10:01 PM
Way North Idaho
1KoolBee Offline OP
1KoolBee  Offline OP
Way North Idaho
"if I could find a good distributor w/ fully tuneable vacuum advance (amount of advance x vacuum level) & mechanical curves, I'd like to run one."
Earlier today I was checking out the MSD 6AL-2 Programmable (6530)...interestingly enough it has several advance and retard curve features including one that works off a MAP sensor (vacuum or boost). Also burnout, Launch, and Max RPM limiters. All tunes with a laptop, so you could probably have different pump gas and race gas timing curves? not cheap, ~$350, but I need an ignition box anyway. Maybe "electronic" vacuum advance control? hmmmmmmmm.........
Re: Vacuum advance or not??? [Re: 1KoolBee] #1476786
07/31/13 10:42 PM
07/31/13 10:42 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Really.............? I guess if you`ve got all that time on your hands but you are REALLY over complicating things in my opinion but hey, it`s your car..............
Re: Vacuum advance or not??? [Re: Thumperdart] #1476787
08/01/13 01:15 AM
08/01/13 01:15 AM
Way North Idaho
1KoolBee Offline OP
1KoolBee  Offline OP
Way North Idaho
LOL...Yeah you're probably right Dom! Keep it simple is a good creed to stick to.
Re: Vacuum advance or not??? [Re: 1KoolBee] #1476788
08/01/13 01:38 AM
08/01/13 01:38 AM
MR_P_BODY Offline
MR_P_BODY  Offline
If you drive ALOT on the street the advance is well
worth the time to figure it out... even at .5 more
miles per gal... its just a balancing act between the
carb and the dist... whats the max timing it will
take at that amount of load.. when I get the time I
will be running a mech advance along with vac advance
just to get the mileage up.. right now I just have
mech advance
Re: Vacuum advance or not??? [Re: 1KoolBee] #1476789
08/01/13 01:44 AM
08/01/13 01:44 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
It`s all good man but these are musclecars and the extra mpg`s can`t hurt but just seem minute to me w/the hastles of the balancing act that`s needed to make it work. Good luck either way man............
Re: Vacuum advance or not??? [Re: Thumperdart] #1476790
08/01/13 02:03 AM
08/01/13 02:03 AM
MR_P_BODY Offline
MR_P_BODY  Offline
You do know all it is is sticking a allen wrench in
the vac port on the vac can and turning in less or more
per given load(usually set for cruise load).. some
times it takes a delay valve in the vac line
Re: Vacuum advance or not??? [Re: 1KoolBee] #1476791
08/01/13 02:05 AM
08/01/13 02:05 AM
Az
Crizila Offline
Crizila  Offline
Az
If you decide to go with a vacuum advance set up, here would be a good starting point: initial advance around 17 degrees, starting around 1200 rpm. total mechanical around 34 degrees ( 8 1/2 distributor degrees )and all in around 2200rpm. Limit the vacuum advance to around 12 degrees, which would give you a total of 46 degrees at cruise. An adjustable vacuum can would make that part easy. Go for it!
Fastest 300
Re: Vacuum advance or not??? [Re: MR_P_BODY] #1476792
08/01/13 02:17 AM
08/01/13 02:17 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I have trouble focusing sometimes so this stuff drives me plus vac. adv. is for wussy cars NOT muscle cars..............
Re: Vacuum advance or not??? [Re: Thumperdart] #1476793
08/01/13 02:30 AM
08/01/13 02:30 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Maybe they are for wussies but now days I'll take that
extra 1/2 to 1 mile a gal any day... it might take
a few hours to fine tune it.. well worth the effort
to me.. once I'm up and running good I hope to have time
to dial in a vac advance before DW
Page 1 of 3 1 2 3
