Quote: LOL...Yeah you're probably right Dom! Keep it simple is a good creed to stick to.
If you drive ALOT on the street the advance is well worth the time to figure it out... even at .5 more miles per gal... its just a balancing act between the carb and the dist... whats the max timing it will take at that amount of load.. when I get the time I will be running a mech advance along with vac advance just to get the mileage up.. right now I just have mech advance
