Page 1 of 3 1 2 3
4 speed cars...who runs a scattershield on the street? #147321
11/08/08 03:14 PM
11/08/08 03:14 PM
Arkansas
340727dart Offline OP
Arkansas
I'm well on my way to gathering all the parts needed for swapping in a 4 speed on my Dart Sport.
I've already got a factory aluminum bellhousing.
While I won't be racing the car due to no nearby tracks, I still plan on some acceleration testing from time to time on the back roads.
My 340 is making a little over 400 horsepower. I've got the rev limiter set at 6250 rpm.
I'm already planning on buying an SFI approved billet flywheel and pressure plate, hoping to avoid clutch explosions.
That being said, do I really need a scattershield?
Your life is not my fault.
My life is none of your business.
Speech is free only if you agree with those in control.
Re: 4 speed cars...who runs a scattershield on the street? [Re: 340727dart] #147322
11/08/08 03:20 PM
11/08/08 03:20 PM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
Need? Hard to say, but if you're erring on the side of caution with and SFI-approved flywheel, you may as well go ahead and use a scattershield. You can easily sell the Al BH to re-coup some of the cost.
Re: 4 speed cars...who runs a scattershield on the street? [Re: 340727dart] #147323
11/08/08 03:30 PM
11/08/08 03:30 PM
San Francisco Ca
SCATPK Offline
SCATPK  Offline
San Francisco Ca
In my opinion no! If you have good parts and a rev limiter the odds of having a failure will be very minimal. Look at all of the factory cars with 400+ hp and they use an aluminum bellhousing if it was not safe they surely would not be using them to avoid a lawsuit. Most failures you hear of are on race cars that are driven hard and if that is its main purpose them absolutly you need a safety bell and engine block plate. I asked the same question myself a few years back and got the same answer from most guys do you like your right foot. But again how many factory muscle cars came or come with a safety bellhousing??? Now if you are going to be putting slicks on something and going for broke at the track then yes get the scattershield, but if you are a street jockey 99% of the time then not worth the headaches in my opinion. I had a lakewood on my gtx and removed it in favor of a lightweight factory aluminum unit and feel very safe with it for my use.
Re: 4 speed cars...who runs a scattershield on the street? [Re: SCATPK] #147324
11/08/08 04:44 PM
11/08/08 04:44 PM
440Demon Offline
440Demon  Offline
The Lakewood's run around 3-400$. I used one on mine (440 4spd Demon) think it's woth every penny.
Re: 4 speed cars...who runs a scattershield on the street? [Re: 440Demon] #147325
11/08/08 04:50 PM
11/08/08 04:50 PM
Cruising!
Q
QuickDodge Offline
QuickDodge  Offline
Q
Cruising!
One other variable to consider is that tire technology has changed significantly since our muscle cars were built. What was quite safe with the tires built 40 years ago may or may not be safe with today's tires.
Re: 4 speed cars...who runs a scattershield on the street? [Re: QuickDodge] #147326
11/08/08 04:57 PM
11/08/08 04:57 PM
San Francisco Ca
SCATPK Offline
SCATPK  Offline
San Francisco Ca
Most of the stock rubber on these new mustangs and corvetts are better than anything that was available back in the day. I have an SFI flywheel,good clutch and pressure plate with quality hardware and a rev limiter and feel my setup is pretty strong. If I was running slicks and popping the clutch at 4000+ rpm then yes the shield would be a required item for safety.
Re: 4 speed cars...who runs a scattershield on the street? [Re: 340727dart] #147327
11/08/08 05:05 PM
11/08/08 05:05 PM
Answering the call of the wild
ThermoQuad Offline
ThermoQuad  Offline
no scattershield required...sfi flywheel and a good clutch is all you need
Re: 4 speed cars...who runs a scattershield on the street? [Re: ThermoQuad] #147328
11/08/08 07:38 PM
11/08/08 07:38 PM
Witness Protection Program
Kudakidd Offline
Kudakidd  Offline
No 6 grand launches, no scattershield necessary.
Re: 4 speed cars...who runs a scattershield on the stre [Re: 340727dart] #147329
11/08/08 08:08 PM
11/08/08 08:08 PM
Rittman Ohio
fourgearsavoy Online tonguue
fourgearsavoy  Online Tonguue
Rittman Ohio
I say why chance it? When you miss a gear or break a transmission the heavy flywheel/plate assy.weighs in at close to 50 pounds and it carries alot of inertia that will surpass the rev limiter.I have a 6800 chip on the high side and my recall tach has been over 7400 when I missed a gear.If you don't have anything now I would go with a Quicktime bell.
Gus
64 Plymouth Savoy
Dana 60
Re: 4 speed cars...who runs a scattershield on the stre [Re: fourgearsavoy] #147330
11/08/08 09:18 PM
11/08/08 09:18 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
When I disassembled my Hemi RR back around 1985 to restore it, I took one look at the floor & firewall and put a scattershield in it. The shrapnel that punched holes through the floor made enough of an impression on me, and those cars had cast-iron bellhousings.
Re: 4 speed cars...who runs a scattershield on the stre [Re: topside] #147331
11/08/08 09:37 PM
11/08/08 09:37 PM
calif
cupcake Offline
cupcake  Offline
calif
u dont need a seatbelt eather dont go over 5mph
Re: 4 speed cars...who runs a scattershield on the stre [Re: cupcake] #147332
11/08/08 10:21 PM
11/08/08 10:21 PM
Beavercreek, Ohio
OA5599 Offline
OA5599  Offline
Beavercreek, Ohio
According to an old mopar mag of mine, Don Johnson wouldn't drive the Nash Bridges 'Cudas without scattershields installed on the 4 speed cars.
Re: 4 speed cars...who runs a scattershield on the stre [Re: OA5599] #147333
11/08/08 11:36 PM
11/08/08 11:36 PM
S Williamsport
therick Offline
therick  Offline
S Williamsport
Better safe than sorry. I use one on every stick car I own. Whats the going rate for a new foot?
Re: 4 speed cars...who runs a scattershield on the stre [Re: OA5599] #147334
11/08/08 11:55 PM
11/08/08 11:55 PM
San Francisco Ca
SCATPK Offline
SCATPK  Offline
San Francisco Ca
Well thats sounds just plain stupid to me. So all of those musclecars on the road today with pumped small blocks and heavy hitting big blocks with 4spds you guys think are unsafe without a heavy pain in the butt scattershield? I guess the same could be said about all those automatic transmission cars behind high hp motors without a shield????
Re: 4 speed cars...who runs a scattershield on the street? [Re: 340727dart] #147335
11/09/08 12:03 AM
11/09/08 12:03 AM
iowa
copchaser Offline
copchaser  Offline
iowa
I run a lakewood in my GTX. I figure my legs are worth more than $400 bucks. I told a friend of mine who was kicking the same thing, I told him that I would give him $400 if I could cut his right leg off at the knee. He joined the scattersheild club.
Re: 4 speed cars...who runs a scattershield on the stre [Re: copchaser] #147336
11/09/08 01:05 AM
11/09/08 01:05 AM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
If you put on a lakewood, check the location and position of the fork arm mount as they have been WAY off in some cases.
Re: 4 speed cars...who runs a scattershield on the stre [Re: RobX4406] #147337
11/09/08 01:27 AM
11/09/08 01:27 AM
San Francisco Ca
SCATPK Offline
SCATPK  Offline
San Francisco Ca
If you run a lakewood you may also need to do some triming depending on your exhaust system Here is a picture of some trimming I had to do on the lakewood that I removed on my gtx.
Re: 4 speed cars...who runs a scattershield on the stre [Re: SCATPK] #147338
11/09/08 01:43 AM
11/09/08 01:43 AM
Maryland
dduster73 Offline
dduster73  Offline
Maryland
I run one on my 73 440 Duster. Seems like a good idea. Dave
Re: 4 speed cars...who runs a scattershield on the stre [Re: dduster73] #147339
11/09/08 08:38 AM
11/09/08 08:38 AM
SoCal
jake4cars Offline
jake4cars  Offline
SoCal
Maybe you will not need it, but......do you want to take the chance, I always use them on street cars, better safe than crippled.
Joey
Re: 4 speed cars...who runs a scattershield on the stre [Re: jake4cars] #147340
11/09/08 08:46 AM
11/09/08 08:46 AM
PA
70HemiGTX Offline
70HemiGTX  Offline
PA
Have one on my Dart.
Page 1 of 3 1 2 3
