4 speed cars...who runs a scattershield on the street?
#147321
11/08/08 03:14 PM
11/08/08 03:14 PM
Posts: 8,144 Arkansas
340727dart
Arkansas
I'm well on my way to gathering all the parts needed for swapping in a 4 speed on my Dart Sport. I've already got a factory aluminum bellhousing. While I won't be racing the car due to no nearby tracks, I still plan on some acceleration testing from time to time on the back roads. My 340 is making a little over 400 horsepower. I've got the rev limiter set at 6250 rpm. I'm already planning on buying an SFI approved billet flywheel and pressure plate, hoping to avoid clutch explosions. That being said, do I really need a scattershield?
Your life is not my fault. My life is none of your business.
Speech is free only if you agree with those in control.
Re: 4 speed cars...who runs a scattershield on the stre
[Re: 340727dart]
#147329
11/08/08 08:08 PM
11/08/08 08:08 PM
Posts: 10,555 Rittman Ohio
fourgearsavoy
Rittman Ohio
I say why chance it? When you miss a gear or break a transmission the heavy flywheel/plate assy.weighs in at close to 50 pounds and it carries alot of inertia that will surpass the rev limiter.I have a 6800 chip on the high side and my recall tach has been over 7400 when I missed a gear.If you don't have anything now I would go with a Quicktime bell. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: OA5599]
#147334
11/08/08 11:55 PM
11/08/08 11:55 PM
Posts: 6,570 San Francisco Ca
SCATPK
San Francisco Ca
According to an old mopar mag of mine, Don Johnson wouldn't drive the Nash Bridges 'Cudas without scattershields installed on the 4 speed cars.
Well thats sounds just plain stupid to me. So all of those musclecars on the road today with pumped small blocks and heavy hitting big blocks with 4spds you guys think are unsafe without a heavy pain in the butt scattershield? I guess the same could be said about all those automatic transmission cars behind high hp motors without a shield????
[Re: jake4cars]
#147340
11/09/08 08:46 AM
11/09/08 08:46 AM
Posts: 2,363 PA
70HemiGTX
PA
