Hardware Restoration Services
#1472895
07/23/13 09:52 PM
07/23/13 09:52 PM
Posts: 1,896 New England
Q5_Ed
New England
Can anyone recommend someone to strip and re-plate body bolts and other fasteners for a full restoration? What do most folks do for a full blown "nut and bolt" restoration job? I have hardware to spare and would like to take care of this early in the process. Also, anyone use Mike Mancini for dash restoration, or other smaller stuff? Thanks Ed ![](/ubbthreads/images/graemlins/scope.gif)
WANTED : ...A New Sponsor or Winning Lottery Ticket
69 A12 road runner ,Q5, post coupe, 4 speed, former Drag car restored to "Driver" condition in the early 90's, Showing some Patina. SS/E Track Record Holder 1980 10.40 @ 130mph
Re: Hardware Restoration Services
[Re: gtx6970]
#1472899
07/24/13 10:21 AM
07/24/13 10:21 AM
Q5_Ed
New England
Bill do you refinish All mounting hardware like fender and trunk bolts,washers, clips, things that will be painted over?
[Re: Q5_Ed]
#1472901
07/24/13 03:53 PM
07/24/13 03:53 PM
Posts: 21,532 It's a dry heat
gtx6970
It's a dry heat
No, just a good cleaning,,,,usually just a soaking in evaporust or maybe a light trip thru the glass bead cabinet,,,, then paint - primer - color coat. Been thinking about picking a tumbler for just this kind of stuff. It's not cost effective to spend hours cleaning hardware at the glass bead cabinet.
I will only replate if it's is something thats not painted over after installation. Even then somethings I don't worry about 2 much at all..... the red zinc wiper pivot nuts as an example. They just get cleaned and re-used as is. As once the dash and heater box is in the car they can't be seen .
I am a dealer for AMK so I can usually replace a big portion of body fasteners with new on most of it for less than few hours cleaning the stuff. The problem becomes just how anal you really want to get when it comes to fastners head markings. I don't ---- nor have I had any customer requests in building that kind of car.
[Re: Mr D21]
#1472903
07/24/13 05:19 PM
07/24/13 05:19 PM
Q5_Ed
New England
Good info thank you all. I have alot of hardware in good condition, so I hate to toss away. Have some repop stuff, some original I'd like to save and re-use. The painted stuff especially.
Kind of have an interest in the whole fastener ID thing just as a side hobby. Bought the fastener book Wise put out. Not that my car is going to be concours, just like some of this for fun.
[Re: Q5_Ed]
#1472905
07/25/13 08:12 AM
07/25/13 08:12 AM
gtx6970
It's a dry heat
Ed, I am the same way. If I'm going to put a bolt into something I would like it to be the correct one. I have no interest to build concurs level cars. But I want mine / my customers stuff as close as I can to the casual observer,,within a reasonable effort on my part.
[Re: gtx6970]
#1472906
07/25/13 09:27 AM
07/25/13 09:27 AM
Posts: 768 Dry Heat AZ
AAR#2
Dry Heat AZ
I suppose buying the fastener book could help with getting fasteners back where they belong, since my car was in relatively complete condition and parked in 1978 I kept everything in detailed zip lock bags ( was just easier for me).
My solution was to do all my own plating, its really not that hard and horribly convenient, this way I can't confuse myself with what goes where. This way when I find a bolt or two that has been forgotten (maybe left on a sub assembly) its easy to plate, and after my car is finished it will be easy to clean up anything that starts to look a bit worn for whatever reason.
It takes a little effort to start but worth the effort in the long run, with the following you can replicate almost every finish and know when your finished you have a good protective layer against corrosion as well as a great base for painted items.
Zinc Phosphate - got it from Brownells Electro Deposited Zinc - with or without brighteners, yellow chromate, clear blue chromate, OD chromate and Black chromate, all available from Caswell.
My hat is off to those of you who can remove every nut and bolt, send them to a plater and manage to get them back whaere they belong, I just couldn't get my hands around that process and knew I'd increase my frustration.
[Re: fc7freak]
#1472909
07/26/13 12:43 PM
07/26/13 12:43 PM
Posts: 2,336 Ball Ground, Georgia
Dixie
Mike did my Dash and gauges on my 71 Duster 340. It turned out great. Seemed to have great customer service. I would use them again. I restored my own dash frame using his paint. See Ya!
Me too, but for a Charger. Highly recommend him.
[Re: Dixie]
#1472910
07/30/13 08:45 PM
07/30/13 08:45 PM
Posts: 352 Arizona
69rrgrabber
Arizona
Before tossing all of your fasteners in a bucket to get plated, take the time to document each one. I take a pic of each, along with markings on the head, with a Ziploc bag with the description written clearly on it. I also weigh each fastner on a digital scale and log it in my note book. It does take time, but when you get everything back it will be much easier to sort things out.
You will also have to separate which fastners will be zinc clear, black and yellow (gold) as they will barrel tumble each separately.
CAC
"It takes a Mopar to catch a Mopar!"
1969 Charger R/T 440
1969 Road Runner 383
1970 Cuda 440
[Re: 69rrgrabber]
#1472911
07/31/13 01:26 AM
07/31/13 01:26 AM
Posts: 1,655 Cut and Shoot, TX
kentj340
Cut and Shoot, TX
I mostly did the same as this, except I didn't take photos - I listed all my fasteners with all attributes (kind of fastener, threads/in, length, finish, maker's mark, etc.) in a spreadsheet with reference to the AMK catalog part numbers, all of which do have photos. Every fastener belongs to a component which has its own assigned ID number (1 up), and the ID number was written on a 3 x 5 card with my disassembly notes and placed in a zip lock bag. I can find any fastener or component in a few seconds by looking in my component spreadsheet for the ID number, then going to my zip lock bag trays which are copy paper box lids. I can also pull all fasteners and components with the same finish - phosphated; zinc plated with blue, yellow rainbow, black, green, or brown chromate; body color painted; engine color painted; etc. And, after each finish is applied, I can identify each fastener and get it back into the right zip lock bag.
I prefer to do the zinc plating, chromating, and phosphating myself, since there are always some fasteners that didn't get done with the first batch.
[Re: 72CUDA340]
#1472915
02/13/14 11:09 PM
02/13/14 11:09 PM
AAR#2
Dry Heat AZ
Phosphating comes with 2 options, Zinc and Manganese, both of these produce varying levels of gray to almost black (depending on the concentrate, age of bath, length of time in solution, and base material). The biggest difference between the two is level of porosity at the microstructure level and depth of color. Automotive hardware is generally Zinc while many Guns use manganese. Zinc also makes a good base for painted surfaces or can be oiled (sealed) for a nice grey finish. As an alternative to oil I use a water soluble sealer available from Caswell plating. The sealer can be left natural for a beautiful zinc finish or painted over at a later date. Phosphating will require stainless steel or porcelain pot, bowl . . . , needs to be heated to approx 180-200 and you'll need to season the bath prior to first use (1 time only as long as you continue to use a portion of your previously seasoned bath for future jobs). This is easily accomplished with iron filings, or shavings and a coffee filter. Phosphating can be accomplished by the average home user pretty easily for minimal investment. The process is horribly convenient when doing a restoration and can be easily stored in plastic containers for long periods, making it easy to use at a later date to freshen up details. I tend to refinish even brand new hardware if it doesn't have a good finish. Hardware prep can vary but in general I blast mine first and will often hit it with a wire wheel to get a nice finish prior to plating. The exception is if I intend to paint it then you may elect to skip the wire polish. I suggest you try the process both ways and make an informed decision what works best for your needs. Zinc phosphate is not a great corrosion protector and the reason you may receive new parts in a box with corrosion. It's ability to deter corrosion is largely reliant on the oil or sealer placed on the porous surface. Though its outstanding compared to black oxide. I purchased Zinc phosphate from Brownells (yes, the gun company). Remember your buying concentrate, the pint bottle will make gallons of parkerizing Zinc phosphate solution. http://www.brownells.com/gunsmith-tools-...g-prod1106.aspxI don't recommend performing the process in your home, a garage is the better location, buy an old stove or electric portable burner.
[Re: AAR#2]
#1472916
02/14/14 06:06 AM
02/14/14 06:06 AM
kentj340
Cut and Shoot, TX
. . . needs to be heated to approx 180-200 deg...buy an old stove or electric portable burner.
Yep, exactly, and an excellent summary. I got my phosphating solution from http://www.shootersolutions.com, because he claims his solution/method is darker, but it's manganese. Next time I'll get the zinc solution and compare. There are lots of videos about phosphating, also called Parkerizing, on You Tube.
At first I tried a propane camp stove but found it impossible to keep the temperature from creeping over the boiling point. Now I use a candy thermometer and double boiler method with a large electric skillet from a garage sale. The skillet has water in it, and the solution is in a stainless pot sitting in the water. Temperature control is good. A Teflon skillet with water will work okay when sitting a stainless pot inside.
I don't blast. I just degrease and dunk in vinegar for half day periods to clean. Then wire brush with a brass brush and chase threads if needed. I wear gloves to prevent finger prints.
Since some time may pass between cleaning the fasteners and Parkerizing them, I re-clean. Immediately before dunking in the Parkerizing solution, I dunk in acid for a few seconds or minutes, spray with oven cleaner, and dunk in hot water.
There is discussion above about no need to restore fasteners that are going to get painted, such as body bolts, and I agree totally with that. I coat them with phosphoric acid named Rust Cure, re-coat a week later, wipe, and they are ready for paint in one week.
I've started doing zinc plating and will offer a write up on recommendations later.
