Hardware Restoration Services #1472895
07/23/13 09:52 PM
07/23/13 09:52 PM
New England
Q5_Ed Offline OP
Q5_Ed  Offline OP
New England
Can anyone recommend someone to strip and re-plate body bolts and other fasteners for a full restoration? What do most folks do for a full blown "nut and bolt" restoration job? I have hardware to spare and would like to take care of this early in the process.
Also, anyone use Mike Mancini for dash restoration, or other smaller stuff?
Ed
WANTED : ...A New Sponsor or Winning Lottery Ticket 69 A12 road runner ,Q5, post coupe, 4 speed, former Drag car restored to "Driver" condition in the early 90's, Showing some Patina. SS/E Track Record Holder 1980 10.40 @ 130mph
Re: Hardware Restoration Services [Re: Q5_Ed] #1472896
07/23/13 10:09 PM
07/23/13 10:09 PM
Kentucky
fc7freak Offline
fc7freak  Offline
Kentucky
Mike did my Dash and gauges on my 71 Duster 340. It turned out great. Seemed to have great customer service. I would use them again. I restored my own dash frame using his paint. See Ya!
Re: Hardware Restoration Services [Re: fc7freak] #1472897
07/23/13 10:24 PM
07/23/13 10:24 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Look in your local yellow pages. I'm sure there is a plater near you. I dip my fasteners in muriatic acid. It will remove the rust as well as any left over zinc. Rince with backing soda water to neutralise the acid. You can pay the platers to clean up the fasteners for you but it won't be cheap.
The plating company will have a flat fee for barrel plating. I'm pretty sure you can have all the fasteners for the entire car zinc plated for one base fee. There will probably be an extra charge for any zinc dichromate because that involves dipping the parts in another solution.
There are also companies that can do phosphate coatings too. Just look in the yellow pages.
Re: Hardware Restoration Services [Re: burdar] #1472898
07/24/13 08:04 AM
07/24/13 08:04 AM
It's a dry heat
gtx6970 Online content
gtx6970  Online Content
It's a dry heat
I use either Eric (member 3404 on here) or Neil at dynamic renovation for plating parts.
Re: Hardware Restoration Services [Re: gtx6970] #1472899
07/24/13 10:21 AM
07/24/13 10:21 AM
New England
Q5_Ed Offline OP
Q5_Ed  Offline OP
New England
Bill do you refinish All mounting hardware like fender and trunk bolts,washers, clips, things that will be painted over?
Re: Hardware Restoration Services [Re: Q5_Ed] #1472900
07/24/13 12:49 PM
07/24/13 12:49 PM
NORTHERN VA
THESHAKERPROJECT Offline
NORTHERN VA
some of the hdw is avail new and already plated correctly so you may spend less overall just getting new stuff when you consider the cost of labor these days. Lots of OEM fasteners will be pitted after stripping and this pitting will show when the fastener is replated. I have used Dynamic Renovation as stated in the above post for fast turnaround and great service. Most painted (body )fasteners I toss in a pail of paint stripper and wire brush then dust with etch primer. AMK Products is one of the sources I use for replacement fasteners.
Re: Hardware Restoration Services [Re: Q5_Ed] #1472901
07/24/13 03:53 PM
07/24/13 03:53 PM
It's a dry heat
It's a dry heat
No, just a good cleaning,,,,usually just a soaking in evaporust or maybe a light trip thru the glass bead cabinet,,,, then paint - primer - color coat. Been thinking about picking a tumbler for just this kind of stuff. It's not cost effective to spend hours cleaning hardware at the glass bead cabinet.
I will only replate if it's is something thats not painted over after installation.
Even then somethings I don't worry about 2 much at all..... the red zinc wiper pivot nuts as an example. They just get cleaned and re-used as is. As once the dash and heater box is in the car they can't be seen .
I am a dealer for AMK so I can usually replace a big portion of body fasteners with new on most of it for less than few hours cleaning the stuff.
The problem becomes just how anal you really want to get when it comes to fastners head markings. I don't ---- nor have I had any customer requests in building that kind of car.
Re: Hardware Restoration Services [Re: gtx6970] #1472902
07/24/13 04:53 PM
07/24/13 04:53 PM
california
Mr D21 Offline
Mr D21  Offline
california
On my 70 Challenger - I found AMK to be almost 95% correct replacement for the original bolts (including head markings)...
I unfortunately learned about them after I dropped my 5 gallon bucket of nuts and bolts off at the platter. If I was to do another car, I would go the AMK route again... It took me almost a week to reorganize the 5 gallon bucket into small zip lock bags and I still ended up with a handful of bolts that I haven't figured out what they go for.
Re: Hardware Restoration Services [Re: Mr D21] #1472903
07/24/13 05:19 PM
07/24/13 05:19 PM
New England
Q5_Ed Offline OP
Q5_Ed  Offline OP
New England
Good info thank you all. I have alot of hardware in good condition, so I hate to toss away. Have some repop stuff, some original I'd like to save and re-use. The painted stuff especially.
Kind of have an interest in the whole fastener ID thing just as a side hobby. Bought the fastener book Wise put out. Not that my car is going to be concours, just like some of this for fun.
Re: Hardware Restoration Services [Re: Q5_Ed] #1472904
07/24/13 11:52 PM
07/24/13 11:52 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Re: Hardware Restoration Services [Re: Q5_Ed] #1472905
07/25/13 08:12 AM
07/25/13 08:12 AM
It's a dry heat
It's a dry heat
Ed,
I am the same way. If I'm going to put a bolt into something I would like it to be the correct one.
I have no interest to build concurs level cars. But I want mine / my customers stuff as close as I can to the casual observer,,within a reasonable effort on my part.
Re: Hardware Restoration Services [Re: gtx6970] #1472906
07/25/13 09:27 AM
07/25/13 09:27 AM
Dry Heat AZ
AAR#2 Offline
AAR#2  Offline
Dry Heat AZ
Ed,
I suppose buying the fastener book could help with getting fasteners back where they belong, since my car was in relatively complete condition and parked in 1978 I kept everything in detailed zip lock bags ( was just easier for me).
My solution was to do all my own plating, its really not that hard and horribly convenient, this way I can't confuse myself with what goes where. This way when I find a bolt or two that has been forgotten (maybe left on a sub assembly) its easy to plate, and after my car is finished it will be easy to clean up anything that starts to look a bit worn for whatever reason.
It takes a little effort to start but worth the effort in the long run, with the following you can replicate almost every finish and know when your finished you have a good protective layer against corrosion as well as a great base for painted items.
Zinc Phosphate - got it from Brownells
Electro Deposited Zinc - with or without brighteners, yellow chromate, clear blue chromate, OD chromate and Black chromate, all available from Caswell.
My hat is off to those of you who can remove every nut and bolt, send them to a plater and manage to get them back whaere they belong, I just couldn't get my hands around that process and knew I'd increase my frustration.
Re: Hardware Restoration Services [Re: AAR#2] #1472907
07/25/13 10:31 AM
07/25/13 10:31 AM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
I took my car apart 15 years ago. Every nut and bolt was thrown into a big tub. NOT the right way to do it. The fastener guide really came in handy in my situation. I spent more time sorting the fasteners then I did installing them.
When I had my fasteners plated, the base fee was only $40. That would have done every zinc fastener for the entire car. If you miss a fastener or two you are SOL though.
Re: Hardware Restoration Services [Re: burdar] #1472908
07/25/13 11:22 PM
07/25/13 11:22 PM
Dry Heat AZ
AAR#2 Offline
AAR#2  Offline
Dry Heat AZ
Wow, that's incredible, I have more than $40 in making a rectifier to control the current for electro deposited plating. The big plus for me is flexibility of finishes and convieniance.
Re: Hardware Restoration Services [Re: fc7freak] #1472909
07/26/13 12:43 PM
07/26/13 12:43 PM
Ball Ground, Georgia
Dixie Offline
Dixie  Offline
Me too, but for a Charger. Highly recommend him.
Dixie Restoration Parts
Phone -(770) 975-9898
Phone Hours: M-F 10am-5pm EST
website: www.dixierestorationparts.com
email: mail@dixierestorationparts.com
Veteran owned small business
The Best Parts at a Fair Price.
Re: Hardware Restoration Services [Re: Dixie] #1472910
07/30/13 08:45 PM
07/30/13 08:45 PM
Arizona
69rrgrabber Offline
69rrgrabber  Offline
Arizona
Before tossing all of your fasteners in a bucket to get plated, take the time to document each one. I take a pic of each, along with markings on the head, with a Ziploc bag with the description written clearly on it. I also weigh each fastner on a digital scale and log it in my note book. It does take time, but when you get everything back it will be much easier to sort things out.
You will also have to separate which fastners will be zinc clear, black and yellow (gold) as they will barrel tumble each separately.
CAC
"It takes a Mopar to catch a Mopar!" 1969 Charger R/T 440 1969 Road Runner 383 1970 Cuda 440
Re: Hardware Restoration Services [Re: 69rrgrabber] #1472911
07/31/13 01:26 AM
07/31/13 01:26 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
I mostly did the same as this, except I didn't take photos - I listed all my fasteners with all attributes (kind of fastener, threads/in, length, finish, maker's mark, etc.) in a spreadsheet with reference to the AMK catalog part numbers, all of which do have photos. Every fastener belongs to a component which has its own assigned ID number (1 up), and the ID number was written on a 3 x 5 card with my disassembly notes and placed in a zip lock bag. I can find any fastener or component in a few seconds by looking in my component spreadsheet for the ID number, then going to my zip lock bag trays which are copy paper box lids. I can also pull all fasteners and components with the same finish - phosphated; zinc plated with blue, yellow rainbow, black, green, or brown chromate; body color painted; engine color painted; etc. And, after each finish is applied, I can identify each fastener and get it back into the right zip lock bag.
I prefer to do the zinc plating, chromating, and phosphating myself, since there are always some fasteners that didn't get done with the first batch.
Re: Hardware Restoration Services [Re: AAR#2] #1472912
02/13/14 10:19 AM
02/13/14 10:19 AM
CT,USA
72CUDA340 Offline
72CUDA340  Offline
CT,USA
For you folks that are plating/coating your own hardware at home would you be willing to share photos of the process or the stuff needed to do it yourself? I have a few bags of hardware I would like to restore myself over the next few weeks while I wait on parts.
Re: Hardware Restoration Services [Re: 72CUDA340] #1472913
02/13/14 10:33 AM
02/13/14 10:33 AM
Dry Heat AZ
AAR#2 Offline
AAR#2  Offline
Dry Heat AZ
You didn't mention what type of plating you want to replicate.
Zinc Phosphate can be pretty basic but electro-deposited zinc with a multitude of chromate conversion coats choices can be involved and pricey to set up.
Re: Hardware Restoration Services [Re: AAR#2] #1472914
02/13/14 01:01 PM
02/13/14 01:01 PM
CT,USA
72CUDA340 Offline
72CUDA340  Offline
CT,USA
Probably just zinc phosphate for now, I believe that was the original coating on the front lower valence pan clips and bolts. Not really looking for an accurate resto just want the hardware to be clean and not have to worry about rust for awhile.
