Re: should i block power valve
[Re: oldschoolracer]
#1467408
07/13/13 06:51 PM
07/13/13 06:51 PM
Quicktree
#1467411
07/13/13 08:06 PM
07/13/13 08:06 PM
Posts: 26,005 Rio Linda, CA
John_Kunkel
Rio Linda, CA
If you're not pulling a vacuum at WOT there's no reason to block the PV.
[Re: Crizila]
#1467412
07/14/13 12:20 AM
07/14/13 12:20 AM
Posts: 43,312 Bend,OR USA
Cab_Burge
On a race only engine, a power valve isn't necessary if the carb is set up properly. I've seen guys use them, but more as a crutch when they have another problem.
If you do decide to block it off, you'll need to increase the primary jets. A good starting point is go Square.
Give Quickfuel a call. They can get you pointed the right direction and save you some trouble/time and money.
Paul.
I use one ( on the primary side only ) in a race only application. IMO, it keeps the plugs cleaner idling around the pits, on the return road, and in the staging lanes.
Me to, I use the power valve restriction channel size for getting the tune correct at wide open throttle, I jet the primary jet down one or two sizes to keep the part throttle driving lean on the primarys and use the PVRC to make up for the differences in sizes at WOT ![](/ubbthreads/images/graemlins/scope.gif)
[Re: bigtimeauto]
#1467415
07/14/13 10:43 AM
07/14/13 10:43 AM
Posts: 2,008 Sweet Home Alabama
MRMOPAR622
Sweet Home Alabama
I don't like power valves on a Race engine.A race engine with high CR & big cams & lots of timing is going to spit back through the carb at times cranking and thats the end of the PV!An its seems like some times they have a mind of their own and can open & close as they please. ![](/ubbthreads/images/graemlins/biggrin.gif) Power Valves=Trouble!!!!!
"To Be The Man'You Have Got To Beat The Man"
"T/D and Pro-Bracket Racer"
[Re: MRMOPAR622]
#1467416
07/14/13 10:48 AM
07/14/13 10:48 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I dont run a PV but the carbs now days have a back fire valve to prevent the back fire to blow out the PV ![](/ubbthreads/images/graemlins/wave.gif)
[Re: emarine01]
#1467421
07/14/13 04:07 PM
07/14/13 04:07 PM
Posts: 2,646 Plymouth Meeting, PA
bigtimeauto
Trophy Winner
Trophy Winner
There is more to drag racing than full throttle. Use a power valve, learn how a carb works and you will be more consistent and be able to foot brake or trans break cleanly. I even use one in my Dart blow thru.
BB, TT5,Procharged 3300lb Street Car 4.79/154
