should i block power valve #1467407
07/13/13 06:50 PM
07/13/13 06:50 PM
pa
O
oldschoolracer Offline OP
O
pa
should i block power valve in primary race only car. secondary is already blocked. it's a 1050 quick fuel ser 4150.
Re: should i block power valve [Re: oldschoolracer] #1467408
07/13/13 06:51 PM
07/13/13 06:51 PM
Q
Quicktree Offline
Quicktree  Offline
Q
i do
Re: should i block power valve [Re: oldschoolracer] #1467409
07/13/13 07:15 PM
07/13/13 07:15 PM
Rowlett, TX
74DusterP457 Offline
mopar addict
mopar addict
Rowlett, TX
On a race only engine, a power valve isn't necessary if the carb is set up properly. I've seen guys use them, but more as a crutch when they have another problem.
If you do decide to block it off, you'll need to increase the primary jets. A good starting point is go Square.
Give Quickfuel a call. They can get you pointed the right direction and save you some trouble/time and money.
Paul.
Re: should i block power valve [Re: 74DusterP457] #1467410
07/13/13 07:55 PM
07/13/13 07:55 PM
Az
Crizila Offline
Crizila  Offline
Az
Paul.
I use one ( on the primary side only ) in a race only application. IMO, it keeps the plugs cleaner idling around the pits, on the return road, and in the staging lanes.
Fastest 300
Re: should i block power valve [Re: oldschoolracer] #1467411
07/13/13 08:06 PM
07/13/13 08:06 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
If you're not pulling a vacuum at WOT there's no reason to block the PV.
Re: should i block power valve [Re: Crizila] #1467412
07/14/13 12:20 AM
07/14/13 12:20 AM
Paul.
Me to, I use the power valve restriction channel size for getting the tune correct at wide open throttle, I jet the primary jet down one or two sizes to keep the part throttle driving lean on the primarys and use the PVRC to make up for the differences in sizes at WOT
Re: should i block power valve [Re: John_Kunkel] #1467413
07/14/13 12:21 AM
07/14/13 12:21 AM
Re: should i block power valve [Re: Cab_Burge] #1467414
07/14/13 01:43 AM
07/14/13 01:43 AM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
Keep it, It will make your engine happier and crisper keeping the plugs cleaner.
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: should i block power valve [Re: bigtimeauto] #1467415
07/14/13 10:43 AM
07/14/13 10:43 AM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
I don't like power valves on a Race engine.A race engine with high CR & big cams & lots of timing is going to spit back through the carb at times cranking and thats the end of the PV!An its seems like some times they have a mind of their own and can open & close as they please.
Power Valves=Trouble!!!!!
"To Be The Man'You Have Got To Beat The Man" "T/D and Pro-Bracket Racer"
Re: should i block power valve [Re: MRMOPAR622] #1467416
07/14/13 10:48 AM
07/14/13 10:48 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I dont run a PV but the carbs now days have a back fire
valve to prevent the back fire to blow out the PV
Re: should i block power valve [Re: MR_P_BODY] #1467417
07/14/13 11:22 AM
07/14/13 11:22 AM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
They may have a valve now to keep the back fire from blowing out the valve,but I bet they still have a mind of their own and can open an close at will. All joking aside I have never been able to get them to work right and work right all the time on any engine,but some times on a street engine you just have to settle for as best/close as you can get things.
PS thats why I am becoming a bigger & bigger fan of FI!
Re: should i block power valve [Re: MRMOPAR622] #1467418
07/14/13 11:23 AM
07/14/13 11:23 AM
Q
Quicktree Offline
Quicktree  Offline
Q
PV's fail all the time. just another thing to worry about on a race car. they are not needed.
Re: should i block power valve [Re: MRMOPAR622] #1467419
07/14/13 11:43 AM
07/14/13 11:43 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Same here.. I was on the FI from the start at Chrysler
but that system isnt designed for change.. if I could
buy a nice aftermarket system at a REASONABLE price
I would but not at close to $3000 .. I can buy ALOT
of fuel for that
Re: should i block power valve [Re: MR_P_BODY] #1467420
07/14/13 03:07 PM
07/14/13 03:07 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
No PVs here, race only, I can live without one @ low rpm, I don't cruise @ all, its WOT or idle except for a quick blip going up the ramps while loading, PVs are just one more thing to mess up, its easy to just square jet.
Re: should i block power valve [Re: emarine01] #1467421
07/14/13 04:07 PM
07/14/13 04:07 PM
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
There is more to drag racing than full throttle. Use a power valve, learn how a carb works and you will be more consistent and be able to foot brake or trans break cleanly. I even use one in my Dart blow thru.
