A NEW alignment question! #1464847
07/08/13 03:50 PM
07/08/13 03:50 PM
Kirkland, Washington
Pacnorthcuda Offline OP
At least I think its new: More and more alignment equipment is using degrees and minutes for specing toe during an alignment. Thats good because the angle doesnt change with the diameter of the wheel / tire. BUT...determining the desired angle doesnt see to be so simple.
Does anybody know what 1/16" - 1/8" equates to for a 26 inch tire on a 15 inch rim?
So far I THINK 14 minutes or about 0.25 of a degree equates to 1/16"
Anybody gone down this road?
Re: A NEW alignment question! [Re: Pacnorthcuda] #1464848
07/08/13 10:08 PM
07/08/13 10:08 PM
Nobody has dealt with toe being expressed as degrees instead of inches?
Re: A NEW alignment question! [Re: Pacnorthcuda] #1464849
07/08/13 11:05 PM
07/08/13 11:05 PM
WV
JohnH Offline
JohnH  Offline
WV
A good toe in will be about 1/4" toe in.. The reason for the toe in is that centrifugal force will put it at zero when you are going down the road.. Don't know about the degrees..
Re: A NEW alignment question! [Re: Pacnorthcuda] #1464850
07/08/13 11:24 PM
07/08/13 11:24 PM
Ohio
Todd Offline
Todd  Offline
Ohio
I've always used degrees instead of inches when I do alignments. I guess its what I got used to years ago. But anyway, every 1/32 of an inch of toe is 0.12 degrees or 7 minutes. Should get you close.
Edit..I just looked it up on my machine at work and 1/16 =.13°
Re: A NEW alignment question! [Re: Todd] #1464851
07/09/13 01:02 AM
07/09/13 01:02 AM
Oak Harbor, WA
W
Wicked49670dart Offline
W
Oak Harbor, WA
I do all of my alignments in degree's also, pretty sure 1/16 is .06, I'll check tomorrow at work....Matt
70 Dart 3400 496 New Best 6.15@110.37 660ft, 9.76@135 with a 1.34 60ft
Re: A NEW alignment question! [Re: Wicked49670dart] #1464852
07/09/13 04:40 AM
07/09/13 04:40 AM
colorado
a12superbee Offline
a12superbee  Offline
colorado
Could someone explain what you mean by 'minutes'? Please.
I can't afford this. mark
Re: A NEW alignment question! [Re: a12superbee] #1464853
07/09/13 09:12 AM
07/09/13 09:12 AM
Ohio
Todd Offline
Todd  Offline
Ohio
For every degree there are 10 minutes. So .5 minutes is 1/2 degree
Re: A NEW alignment question! [Re: Todd] #1464854
07/09/13 09:58 AM
07/09/13 09:58 AM
Minn
SportF Offline
SportF  Offline
Minn
Actually for every degree there is 60 minutes, for every minute there is 60 seconds. And the tire diameter affects the toe in when measured at the tread. A 1/4 inch toe on a 20" tire would be far greater degrees than a 1/4 inch toe on a 28 inch tire. Which is why degrees is a better way to measure toe, its consistant no matter the tire size.
Re: A NEW alignment question! [Re: Todd] #1464855
07/09/13 10:08 AM
07/09/13 10:08 AM
Ohio
Todd Offline
Todd  Offline
Ohio
DUH...Your right I was thinking of tenths...Not enough coffee.
Re: A NEW alignment question! [Re: Todd] #1464856
07/09/13 11:07 AM
07/09/13 11:07 AM
Minn
SportF Offline
SportF  Offline
Minn
Well, when I read your post I had to think about it, even though I used to work with minutes and seconds everyday. So, I had another cup of starting fluid myself before I was sure. Whatever, it is obvious you know what you are talking about.
Re: A NEW alignment question! [Re: Pacnorthcuda] #1464857
07/09/13 04:03 PM
07/09/13 04:03 PM
I like to use 1/16 inch Toe In on all my Hi Po older cars with stock front ends I have the alignment shop set that with the front of the car raised up one inch above the sitting hieghts on the rack to simulate actual driving conditions under normal power Radial tires don't need as much toe in as the original OEM bias ply tires did back in the day
Re: A NEW alignment question! [Re: Cab_Burge] #1464858
07/09/13 05:57 PM
07/09/13 05:57 PM
MA
steve70 Offline
steve70  Offline
MA
I just drew it out on MasterCam and you're very close, .25 degree comes out to .0568 inches or just a nick under 1/16
1970 Challenger T/A 4 speed
Re: A NEW alignment question! [Re: steve70] #1464859
07/13/13 01:11 AM
07/13/13 01:11 AM
Montana
Y
Yancy Derringer Offline
Y
Montana
I've never understood why toe was not ALWAYS in degrees. The size of the front tires, indeed, whether you are the proper height inline with the spindle center will change toe ANGLE even though the inch measurement is "the same."
Re: A NEW alignment question! [Re: Yancy Derringer] #1464860
07/13/13 03:12 AM
07/13/13 03:12 AM
colorado
a12superbee Offline
a12superbee  Offline
colorado
I almost missed this thread, thanks for the explanation of minutes.
I've never heard of minutes and seconds used for any measurement other than time. Tick. Tock.
Re: A NEW alignment question! [Re: a12superbee] #1464861
07/16/13 03:12 AM
07/16/13 03:12 AM
Montana
Y
Y
Montana
I'll bet you have, just didn't realize.
Used in Navigation, depending on the "format" of the figures
Used in expression of bullet path (I'm sure you've heard the term "minute of angle" re: shooting)
Here's about KREM channel 2 tower location in Spokane:
47° 35′ 40.9″ N, 117° 17′ 56.8″ W
The first is degrees of elevation from the equator, which is zero degrees, 90 being the N pole, so the tower (near Spokane) is 47 degrees, 35 MINUTES, and 40.9 seconds toward the N from the equator.
The second half, is east - west, so 117 degrees 17 MINUTES and 56.8 seconds west of the 0 degree longitude point on earth which is called the Greenwich meridian. This is an arbitrary point on earth that is designated as being the zero degree point, and dates back to the early days of navigation, Europe being the "important" area at the time.
Google longitude, latitude, "prime meridian," "Greenwich Meridian" and have a day.
Re: A NEW alignment question! [Re: JohnH] #1464862
07/16/13 03:32 AM
07/16/13 03:32 AM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
1/4" toe will KILL a set of tires. 1/8" MAX toe in.
Re: A NEW alignment question! [Re: Pacnorthcuda] #1464863
07/16/13 11:33 AM
07/16/13 11:33 AM
Jefferson State
srt Offline
ESYC
srt  Offline
ESYC
Jefferson State
for an easy conversion to decimal degrees
divide minutes by 60 and add to degrees 2*45' = 45/60 =.75 + 2 = 2.75*
To change decimal degrees to d*min' multiply the decimal portion by 60 and result is minutes then write the degrees.
2.5* = 0.5* x 60 = 30' + 2* = 2*30'
By converting to decimal degrees and back converting back to minutes it makes it easier to determine how much angle needs to be adjusted.
For examples above
2.5* - 2.75* = (-)0.25*, then multiply 0.25* x 60 (to convert to minutes) or (-)15'.
One can also include seconds if needed, or desired, but this takes additional steps that I could explain if anyone needs to know pm me.
Re: A NEW alignment question! [Re: Yancy Derringer] #1464864
07/16/13 11:39 AM
07/16/13 11:39 AM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
Cuz when your pitted out in the south forty where the track lights don't shine, you wacked the lead car in the last heat race, and bent a tie rod and you need to get it replaced and buttoned back up before the main, and you've got a flashlight and your working in the dirt, you whip out the tape measure and jack stands and get to it.
Re: A NEW alignment question! [Re: TC@HP2] #1464865
07/18/13 01:02 AM
07/18/13 01:02 AM
Montana
Y
Y
Montana
I can assure that when Ma "wrote the books," there was no thought of you being in that condition
Re: A NEW alignment question! [Re: Jeremiah] #1464866
07/18/13 11:40 AM
07/18/13 11:40 AM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
He's in tire sales...
Kevin
