powerglide in an a-body
#1463531
07/06/13 01:12 PM
07/06/13 01:12 PM
Posts: 428 Mountain City, TN
JesseR
Mountain City, TN
for those of you who run a glide in an a-body, what kind of fitment issues are they? had given thought to making a removable trans tunnel, but really don't want to cut on the car if there is enough room to work on the thing. any pictures would be great,thanks
82' dodge pickup with a 499 low deck
Re: powerglide in an a-body
[Re: JesseR]
#1463532
07/06/13 01:30 PM
07/06/13 01:30 PM
Posts: 740 WA
JD Dart
WA
They are a lot smaller footprint then the 727 shouldn't be a problem tranny lines of course are on the wrong side.
best so far 8.53 @ 158.59 MPH 60'1.240
[Re: JD Dart]
#1463533
07/06/13 04:48 PM
07/06/13 04:48 PM
Posts: 926 MICHIGAN
BB65Barracuda
MICHIGAN
We used a coan adapter plate and a Glide in the 65. Best thing I ever did to the car.
1957 Power wagon wm300 original 10.000 mile truck, 1964 dodge Polara Convertible numbers matching
[Re: dennismopar73]
#1463535
07/07/13 12:48 AM
07/07/13 12:48 AM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
I think he is running a 904.
If you run an aftermarket JW case you should clear real easy. An ATI or Reid case may get close on the bolt together portion. Probably not. A stock case with shield should still fit but be close.
You wanna buy a good glide that bolts to your small block?
[Re: Mulehead]
#1463539
07/07/13 09:54 AM
07/07/13 09:54 AM
JesseR
Mountain City, TN
thanks for the pics. I will be using a jw ultra bell with a stock case for now. I've had good service out of my 904 but with the direction we're going with the duster a glide is the best option. Leon, do you need a good low 1st gear 904 for that high winding p7!!
[Re: 440Jim]
#1463541
07/07/13 11:42 AM
07/07/13 11:42 AM
Posts: 8,094 Sunnyvale, CA
Jeepmon
Sunnyvale, CA
I will let those that have done it give the details, but remember these changes ($):
- PG Transmission
- PG Torque converter
- Shifter
- Driveshaft
- Cross member/mount
- block adapter plate or adapter bellhousing/case
- Crankshaft adapter hub
- Special adapter flexplate (with ring gear)
- Cooler line routing change
- Flexplate shield or SFI bellhousing
- Transmission shield or SFI PG case
About 2 months ago, I took a serious look at the conversion.. I just couldnt justify the $5500 expense at this time..
[Re: tboomer]
#1463546
07/07/13 04:23 PM
07/07/13 04:23 PM
Posts: 3,502 SOUTH JERSEY
HEMIFRED
SOUTH JERSEY
for 7 years and over 300 runs I have the same all stock P/G in my Duster. 5 clutch,factory gears etc, handles 6000 launches and 8 seond passes. never broke a part.
home of the Sox and Martin Hemi Duster
[Re: HEMIFRED]
#1463547
07/08/13 06:28 AM
07/08/13 06:28 AM
JesseR
Mountain City, TN
thanks for the replies fellas. I excited to see how the car reacts with the glide. If I don't hit any snags, i'll have way less than 5 grand in the swap.
