Page 3 of 4 1 2 3 4
Re: Indy Tunnel Ram Top Plate Version Info [Re: 440Jim] #1459863
07/03/13 07:44 AM
07/03/13 07:44 AM
pa
572charger Offline
572charger  Offline
pa
i just got a top from BG {thanks bob) for my indy tunnel ram on my hemi i bought 2 850 hp holleys aluminum carbs (they are really nice)allready tricked out ! out of the box they drive and idle perfect smooooooth ! im going to test them in october !!!
606 hemi pump gas best 9.60 at 142mph on motor
05 hemi daytona 1500 go-mango 4wd quadcab
2007 hotrod mag pump gas drags runner up, roadkill nights dodge big tire winner 2018 2019 back to back
Re: Indy Tunnel Ram Top Plate Version Info [Re: 572charger] #1459864
07/04/13 01:28 AM
07/04/13 01:28 AM
Rogue River, OR
Jeremiah Offline OP
Jeremiah  Offline OP
Rogue River, OR
I stopped at the machine shop and worked on the top for a while today. I needed to drill, tap, and install helicoils for the carb studs before milling out the center of the carb openings. It's good thing we don't plan on using it that way. The 5/16" holes that I assume were drilled for helicoils (or to be tapped 5/16-18) were not even close. I could have done better in the field with a cordless drill, hole saw, and a carb gasket.
Re: Indy Tunnel Ram Top Plate Version Info [Re: Jeremiah] #1459865
07/04/13 01:29 AM
07/04/13 01:29 AM
Rogue River, OR
Jeremiah Offline OP
Jeremiah  Offline OP
Rogue River, OR
power tap...got to be careful coming up s you don't pull out the top threads.
Re: Indy Tunnel Ram Top Plate Version Info [Re: Jeremiah] #1459866
07/04/13 01:30 AM
07/04/13 01:30 AM
Rogue River, OR
Jeremiah Offline OP
Jeremiah  Offline OP
Rogue River, OR
helicoils installed for test fitment...success!
Re: Indy Tunnel Ram Top Plate Version Info [Re: Jeremiah] #1459867
07/04/13 01:31 AM
07/04/13 01:31 AM
Rogue River, OR
Jeremiah Offline OP
Jeremiah  Offline OP
Rogue River, OR
...and a picture showing the misalignment of the carb opening. I'll scribe it with a gasket and mill the center out tomorrow.
Re: Indy Tunnel Ram Top Plate Version Info [Re: Jeremiah] #1459868
07/04/13 10:05 AM
07/04/13 10:05 AM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
While you are at it gasket match your intake ports as well!
"To Be The Man'You Have Got To Beat The Man" "T/D and Pro-Bracket Racer"
Re: Indy Tunnel Ram Top Plate Version Info [Re: MRMOPAR622] #1459869
07/04/13 02:13 PM
07/04/13 02:13 PM
Rogue River, OR
Jeremiah Offline OP
Jeremiah  Offline OP
Rogue River, OR
I am going to wait until I have the block, heads, and intake mocked up before I do anything with the ports. I put a MW Superformance gasket in the intake and the holes are WAY off compared the the gasket. Upon seeing that we decided not to mess with until checking the intake against the long block.
Re: Indy Tunnel Ram Top Plate Version Info [Re: Jeremiah] #1459870
07/08/13 02:39 AM
07/08/13 02:39 AM
Rogue River, OR
Jeremiah Offline OP
Jeremiah  Offline OP
Rogue River, OR
Hope you all had a good holiday weekend. I am back to researching this project and am trying to decide what linkage kit to purchase. It looks like AED makes a nice setup and I have also been told to look at Enderle but have not found an advertised p/n for a BBM. Do I have any other options?
I have also read about having to modify the floats in the carbs due to sideways mounting. Is this something I should be reading up on?
Thanks for all of the great replies so far.
I am also trying to get ideas for air filters so if you have pics or p/n's please share.
Re: Indy Tunnel Ram Top Plate Version Info [Re: Jeremiah] #1459871
07/08/13 09:57 AM
07/08/13 09:57 AM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Indy handles TR linkage for wedge- Enderle,$110
Re: Indy Tunnel Ram Top Plate Version Info [Re: B G Racing] #1459872
07/08/13 12:45 PM
07/08/13 12:45 PM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
Enderle
Re: Indy Tunnel Ram Top Plate Version Info [Re: Jeremiah] #1459873
07/08/13 01:19 PM
07/08/13 01:19 PM
I'm wondering about the floats also Jeremiah, I bought some of the K&N small base air cleaners for my dual 4150 tunnel ram set up, measure your carbs between the studs for the air cleaners once you get them mounted and see how wide air cleaner bases you can use I think on the 4150 carbs, depending on the carb. centers , you can use a 11 inch drop base set I had to use a set of 9 inch diameter, I think they are, on my Dominator set due to no small base drop bases for the Dominator I did buy the Extreme lidsa also, there worth a little ET and MPH at the track
Re: Indy Tunnel Ram Top Plate Version Info [Re: Jeremiah] #1459874
07/08/13 06:31 PM
07/08/13 06:31 PM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
The last 2-3 years I have been running terminators,but since the 80's have run both 4150's & 4500's all side ways and never made any changes to the floats with no problems.
Re: Indy Tunnel Ram Top Plate Version Info [Re: B G Racing] #1459875
07/08/13 11:36 PM
07/08/13 11:36 PM
new york
68HEMIRR Offline
68HEMIRR  Offline
new york
what works so much better is running 2 throttle cables ....gas pedal to carbs
BORN TO BE WILD
Re: Indy Tunnel Ram Top Plate Version Info [Re: 68HEMIRR] #1459876
07/08/13 11:38 PM
07/08/13 11:38 PM
new york
68HEMIRR Offline
68HEMIRR  Offline
new york
at firewall
BORN TO BE WILD
Re: Indy Tunnel Ram Top Plate Version Info [Re: 68HEMIRR] #1459877
07/09/13 02:42 AM
07/09/13 02:42 AM
Rogue River, OR
Jeremiah Offline OP
Jeremiah  Offline OP
Rogue River, OR
Thank you all for the info. I will definitely take it all into consideration. This showed up today...light the cigar boys we have twins!
Re: Indy Tunnel Ram Top Plate Version Info [Re: 68HEMIRR] #1459878
07/09/13 02:43 AM
07/09/13 02:43 AM
Rogue River, OR
Jeremiah Offline OP
Jeremiah  Offline OP
Rogue River, OR
at firewall
Thank you for sharing this. Do you have pics of the linkage at the carbs?
Re: Indy Tunnel Ram Top Plate Version Info [Re: Jeremiah] #1459879
07/09/13 10:46 AM
07/09/13 10:46 AM
hudson valley n.y.
GEORGE68HEMIRR Offline
super street
super street
hudson valley n.y.
yes.....as you can see i have a different screen name.....tried to sigh on and couldnt get on.....went to my wifes pc and it remembered my password which i couldnt get thru.....these twin cables work awesome.....been there done that with the linkage and it never worked easy......cables are the way to go
Re: Indy Tunnel Ram Top Plate Version Info [Re: GEORGE68HEMIRR] #1459880
07/09/13 10:53 AM
07/09/13 10:53 AM
hudson valley n.y.
super street
super street
hudson valley n.y.
oh yeah.....this tunnel ram complete set up will be at 0-90 at Carlisle if anybody is interested
Re: Indy Tunnel Ram Top Plate Version Info [Re: GEORGE68HEMIRR] #1459881
07/10/13 09:27 PM
07/10/13 09:27 PM
Rogue River, OR
Jeremiah Offline OP
Jeremiah  Offline OP
Rogue River, OR
Wow, nice setup. I'll bet that hemi made some steam!
More progress on my end...
Re: Indy Tunnel Ram Top Plate Version Info [Re: Jeremiah] #1459882
07/10/13 09:28 PM
07/10/13 09:28 PM
Rogue River, OR
Jeremiah Offline OP
Jeremiah  Offline OP
Rogue River, OR
I might have to do a little trimming when the adapters show up but it's good for now.
Page 3 of 4 1 2 3 4
