Re: Indy Tunnel Ram Top Plate Version Info
[Re: Jeremiah]
#1459870
07/08/13 02:39 AM
07/08/13 02:39 AM
Posts: 9,102 Rogue River, OR
Jeremiah
Rogue River, OR
Hope you all had a good holiday weekend. I am back to researching this project and am trying to decide what linkage kit to purchase. It looks like AED makes a nice setup and I have also been told to look at Enderle but have not found an advertised p/n for a BBM. Do I have any other options? I have also read about having to modify the floats in the carbs due to sideways mounting. Is this something I should be reading up on? Thanks for all of the great replies so far. I am also trying to get ideas for air filters so if you have pics or p/n's please share.
[Re: Jeremiah]
#1459873
07/08/13 01:19 PM
07/08/13 01:19 PM
Posts: 43,315 Bend,OR USA
Cab_Burge
I'm wondering about the floats also Jeremiah, I bought some of the K&N small base air cleaners for my dual 4150 tunnel ram set up, measure your carbs between the studs for the air cleaners once you get them mounted and see how wide air cleaner bases you can use I think on the 4150 carbs, depending on the carb. centers , you can use a 11 inch drop base set I had to use a set of 9 inch diameter, I think they are, on my Dominator set due to no small base drop bases for the Dominator I did buy the Extreme lidsa also, there worth a little ET and MPH at the track
[Re: B G Racing]
#1459875
07/08/13 11:36 PM
07/08/13 11:36 PM
Posts: 80 new york
68HEMIRR
new york
what works so much better is running 2 throttle cables ....gas pedal to carbs
BORN TO BE WILD
[Re: 68HEMIRR]
#1459878
07/09/13 02:43 AM
07/09/13 02:43 AM
Jeremiah
Rogue River, OR
at firewall
Thank you for sharing this. Do you have pics of the linkage at the carbs?
