Noisy Hemi valve train #1447969
06/05/13 05:00 PM
06/05/13 05:00 PM
Norrland, Sweden
Swedcharger67 Offline OP
Norrland, Sweden
A friend og mine has an original 66 Hemi-Charger. The current Hemi-engine is a 1965 model, with heads from 1968. The engine has the original mechanical flat tappet cam.
According to the service manual the exhaust valve clearance is supposed to be .032, intake .028
These gaps seem fairly big, and they seem to create a noisy valve train. Are these gaps normal and is the valve train normally noisy? Can anything be done to the noise?
Martin, 67 Charger, 512 cui, E85, MegaSquirt MS3X sequential ignition & injection
Re: Noisy Hemi valve train [Re: Swedcharger67] #1447970
06/05/13 05:12 PM
06/05/13 05:12 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Tighten the lash and see. I'd run about .024 and .028".
Re: Noisy Hemi valve train [Re: Challenger 1] #1447971
06/05/13 05:31 PM
06/05/13 05:31 PM
Rancho Cordova, California (Sa...
hemi71x Offline
hemi71x  Offline
Hemi's sound like a coffey can of nuts and bolts, being shaken around, all the time.
Nature of the beast.
RF-4C Phantom 69-370 Zweibrucken, Germany
Re: Noisy Hemi valve train [Re: hemi71x] #1447972
06/05/13 05:40 PM
06/05/13 05:40 PM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
Then why have I heard many quiet Hemis ?
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: Noisy Hemi valve train [Re: HemiRick] #1447973
06/05/13 05:58 PM
06/05/13 05:58 PM
Horsham, Pa.
Finoke Offline
Finoke  Offline
Horsham, Pa.
Thats a good question, i've heard them both ways also. Mine is loud but i have heard some that are louder and some that are quiter?
Re: Noisy Hemi valve train [Re: HemiRick] #1447974
06/05/13 06:01 PM
06/05/13 06:01 PM
hemi71x Offline
hemi71x  Offline
Maybe because they are 70-71 hydraulic lifter.
Re: Noisy Hemi valve train [Re: Swedcharger67] #1447975
06/05/13 06:03 PM
06/05/13 06:03 PM
Northeast
V
VincentVega Offline
VincentVega  Offline
V
Northeast
an original 47 year old engine, eh? that's a lot of years. Could even be noisy rods or wrist pins, that's a long time to be a performance engine.
Looking for 1975 through 1978 B body 4 door sedan sheet metal or parts cars - monaco, fury, coronet. Please let me know
Re: Noisy Hemi valve train [Re: Swedcharger67] #1447976
06/05/13 06:19 PM
06/05/13 06:19 PM
Cincinnati, Ohio
Cincinnati, Ohio
When was the last time your friend checked the lash?
Re: Noisy Hemi valve train [Re: VincentVega] #1447977
06/05/13 06:20 PM
06/05/13 06:20 PM
ILL
MLR426 Offline
MLR426  Offline
ILL
As mentioned tighten up the lash. Its common for solid lifter loose lash cams to make excessive noise. They sound like crap for sure.
MLR426
Re: Noisy Hemi valve train [Re: hemi71x] #1447978
06/05/13 07:42 PM
06/05/13 07:42 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Re: Noisy Hemi valve train [Re: JohnRR] #1447979
06/05/13 09:50 PM
06/05/13 09:50 PM
central P.A.
HEMIDOG 70 Online content
HEMIDOG 70  Online Content
central P.A.
my 528 is noisy more so when hot it's a flat tappet. Do you guy's think it's time to set the lash already? it only has around 500 mi on it since it came off the dyno. Barton used the tool steel lifters with a bullet solid cam. I did not get my cam card but the dyno sheet says 280 cam. I think the gross lift is around .667"intake and similar on the exhaust. the dyno sheet says lash set to .20 but that is crossed off and .10 is wrote on for both intake and exhaust lash. this sounds very tight can I hurt anything running the lash this tight? The engine has an iron block aluminum heads and roller rockers.
Re: Noisy Hemi valve train [Re: HEMIDOG 70] #1447980
06/05/13 10:00 PM
06/05/13 10:00 PM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
Set the valve lash as specified, you get used to the valve train noise, it's normal. It reminds me of a well oiled sewing machine. If you don't like it turn up the radio.
With a cast iron block and aluminum heads the .010/.010 is probably pretty close setting them cold.Dave
Re: Noisy Hemi valve train [Re: quickd100] #1447981
06/05/13 10:15 PM
06/05/13 10:15 PM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
OEM and most MP solid cams were .028/.032
Aftermarket cams generally have less lash, therefore quieter, ramp design has a lot to do with lash specs. The other extreme are OEM slant six solid cams, .010/.012, almost no valvetrain noise.
I like the sound of a solid cam. I'd try .002 tighter but not more, why take a chance of hurting something.
Re: Noisy Hemi valve train [Re: quickd100] #1447982
06/05/13 10:22 PM
06/05/13 10:22 PM
central P.A.
central P.A.
yup your right it does sound like a sewing machine. So .10 is definitely a cold lash setting? or cold it ever possibly be a warm lash setting.
Re: Noisy Hemi valve train [Re: Swedcharger67] #1447983
06/05/13 10:53 PM
06/05/13 10:53 PM
San Jose, CA
Blue69Charger Offline
San Jose, CA
Mine has hydraulic lifters and it still sounds like a sewing machine. That's how you can tell hemis at car shows. I've never heard one as quiet as a wedge motor. Even my 2010 challenger has some of that sound.
Re: Noisy Hemi valve train [Re: Swedcharger67] #1447984
06/06/13 01:41 PM
06/06/13 01:41 PM
When you say original engines is a 1965, what is the assembly date of the motor? If it is a race 1965 engine converted to a street hemi motor with the 1968 heads and street ehmmi intake and carbs the race cam is a lot bigger than the street hemi cams If it is a early 1966 street hemi motor with the block cast after July of 1965 try tightening the lash up .004 to .006 with the motor HOT
Re: Noisy Hemi valve train [Re: quickd100] #1447985
06/06/13 03:21 PM
06/06/13 03:21 PM
closer to Canadian beer!
torkrules Offline
I'm neurotic
torkrules  Offline
I'm neurotic
Couldn't agree more. I have alum heads and iron block. I started at .016...too noisy. Went to .013....better, but still noisy. .010 did the trick.
Dead quiet when cold, quieter mechanical noise when hot.
Re: Noisy Hemi valve train [Re: Swedcharger67] #1447986
06/06/13 04:02 PM
06/06/13 04:02 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
Noise to some, music to me. Shaft collars also reduce the noise a bit. My 66 has a "quality" sound to it, shaft collars and .024 and .028.
Sheldon
Re: Noisy Hemi valve train [Re: RUNCHARGER] #1447987
06/07/13 08:31 PM
06/07/13 08:31 PM
MICHIGAN
BB65Barracuda Offline
MICHIGAN
Whats the Problem?
All solids make noise to some degree.
He can always swap in a hydraulic
1957 Power wagon wm300 original 10.000 mile truck, 1964 dodge Polara Convertible numbers matching
